ROS2: How to use custom message in project where it's declared?
I’ve created C++ ROS2 project with a custom message as explained here: GitHub - ros2/ros2: The Robot Operating System, is a meta operating system for robots.
I can see the message is generated properly and .h.hpp files are installed.
Now I want to use this custom message in the same project where it’s generated. But I can’t reference the header file of my generated message from the same project.
Here is my CMakeList.txt:
cmake_minimum_required(VERSION 3.5)
project(bridge_test_msgs)
if(NOT WIN32)
  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++14 -Wall -Wextra -Wpedantic")
endif()
find_package(ament_cmake REQUIRED)
find_package(rosidl_default_generators REQUIRED)
find_package(std_msgs REQUIRED)
find_package(rclcpp REQUIRED)
find_package(rclcpp_lifecycle REQUIRED)
set(msg_files
  "msg/BridgeTestMessage.msg"
rosidl_generate_interfaces(${PROJECT_NAME}
  ${msg_files}
  ADD_LINTER_TESTS
include_directories(
  ${rclcpp_INCLUDE_DIRS}
  ${rclcpp_lifecycle_INCLUDE_DIRS}
  ${std_msgs_INCLUDE_DIRS}
#    ${${PROJECT_NAME}_INCLUDE_DIRS}
add_executable(my_publisher
    src/my_publisher.cpp
target_link_libraries(my_publisher
  ${rclcpp_LIBRARIES}
  ${rclcpp_lifecycle_LIBRARIES}
  ${std_msgs_LIBRARIES}
#        ${PROJECT_NAME}
#        ${PROJECT_NAME}_LIBRARIES
#        ${${PROJECT_NAME}_LIBRARIES}
add_dependencies(my_publisher ${PROJECT_NAME})
ament_target_dependencies(my_publisher
        "rclcpp"
        "rclcpp_lifecycle"
        "std_msgs"
        "${PROJECT_NAME}"
install(TARGETS
        my_publisher
        DESTINATION bin
ament_export_dependencies(rosidl_default_runtime)
ament_package()
Inside src/my_publisher.cpp I have a line:
#include “bridge_test_msgs/msg/bridge_test_message.hpp”
Command ‘ament build’ fails with message:
my_publisher.cpp:7:56: fatal error: bridge_test_msgs/msg/bridge_test_message.hpp: No such file or directory
compilation terminated.
CMakeFiles/my_publisher.dir/build.make:62: recipe for target 'CMakeFiles/my_publisher.dir/src/my_publisher.cpp.o' failed
make[2]: *** [CMakeFiles/my_publisher.dir/src/my_publisher.cpp.o] Error 1
CMakeFiles/Makefile2:288: recipe for target 'CMakeFiles/my_publisher.dir/all' failed
make[1]: *** [CMakeFiles/my_publisher.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
I can see header file exists:
$ ls install/include/bridge_test_msgs/msg/bridge_test_message.hpp
-rw-r--r-- 1 mc mc 415 Jun 27 15:00 install/include/bridge_test_msgs/msg/bridge_test_message.hpp
Could you hint me how to reference custom message from the project itself?
It’s true that most our message package are pure message packages and thus do not try to include/link against themselves. The trick here is that you need to use the macro rosidl_target_interfaces
rosidl_target_interfaces(MY_TARGET_NAME
      ${PROJECT_NAME} "rosidl_typesupport_cpp")
You can look at the composition demo CMake code for an example.
I agree that this is not well documented and that an addition to GitHub - ros2/ros2: The Robot Operating System, is a meta operating system for robots. would be valuable
Yeah. That worked for me. Thank you!
For closure: I added this documentation: adding explicit directions for rosidl_target_interfaces to custom interfaces tutorial by SteveMacenski · Pull Request #339 · ros2/ros2_documentation · GitHub
That works. Many thanks : )
@mch the link in your first post is broken. Now it redirects to ros2 on GitHub - ros2/ros2: The Robot Operating System, is a meta operating system for robots.. I’m looking for your example
This post is 8 years old, so that’s a bit unsurprising! The equivalent tutorial in the current ROS 2 docs would probably be this one: Creating custom msg and srv files — ROS 2 Documentation: Rolling documentation
edit: and to use the interface in the same package it’s declared in: Implementing custom interfaces — ROS 2 Documentation: Rolling documentation
