Building a Rust tool for zero-allocation Serial Autobauding & Protocol Detection
Problem:
Integrating unknown hardware into the companion computer (a custom 1D LiDAR for altitude hold, telemetry radio from decades ago, and a mysterious motor controller) involves lots of frustration trying to find the baud rate manually. The autobaud solutions that I have come across rely on human-readable ASCII and are therefore of no use in determining the baud rate of binary streams.
Solution (autobaud-core):
I’m developing a cross-platform Rust-based autobaud detector as a library and CLI daemon that can be called programmatically to detect baud rates without user interaction.
As opposed to cycling through possible rates blindfolded, my solution involves a two-tier strategy based on:
  • Hardware Framing Validation: For Linux systems, I use the nix crate to access termios PARMRK flags. In case the baud rate is incorrect, the software detects it almost immediately at the hardware framing level (the electrical framing is faulty), and it does not waste CPU cycles running the loop.
  • Zero-Allocation Matching Heuristics: With the electrical framing established, it proceeds to examine the raw &[u8] byte buffer for protocol-specific “magic” bytes (MAVLink v2 = 0xFD, TFmini LiDAR = 0x59 0x59, NMEA = $GPGGA).
I have used ROS2 myself but I am a beginner but could come up with this idea from my experience with working with drones and sensor fusion
Questions from me:
  • Validation: Would such a CLI utility be a real-world thing used when adding new physical devices?
  • ROS 2 Integration: I would like to see some integration beyond a command-line utility here. Could we wrap this into a ROS 2 node, e.g., “Dynamic Serial Bridge” that autobauds the connection, determines the protocol, and immediately starts publishing the raw binary data on a certain topic for parsing further?
  • Protocols missing in action: Besides the aforementioned MAVLink, NMEA, ASCII protocols, what other raw serial protocols are common when interfacing between hardware and ROS?
Typically, I would google the product and check the manual for the baud rate.
Even if you had to determine a device’s baud rate, you would probably only do so once, so I don’t really see the point of a dynamic serial bridge.
I think it’s cool that you’re going so low-level with software and hardware, but I would not waste time making it fancier than it needs to be.
Typically, the job is not done after determining the baud rate and getting data.
Properly integrating a sensor is quite a bit of extra work.
Thank you for your feedback
It really means a lot
