Build ROS 2 Lyrical with Bazel: new ROS Central Registry release and a call for a working group
Hi everyone,
@Andrew_Symington shared some exciting news on Zulip that deserves a wider audience: a new release of the ROS Central Registry (RCR), lyrical.2026-10-05.rcr.0, is available at https://bazel.ros.org.
The RCR is a community Bazel build for ROS, from Lyrical onward. It’s designed to complement colcon, pixi and other build tools, not replace them. It’s still a proof of concept, and community adoption and involvement will decide its future.
Why Bazel
As teams and projects grow, there are good reasons to consider Bazel for build orchestration. Andrew covers them in the ROSCon 2026 talk. Several open-source Bazel rule sets for ROS already exist, and some companies maintain their own private ones. The RCR is an effort to consolidate this work.
It uses Bazel modules for federation, and hermetic C++, Python and Rust toolchains for determinism.
What’s in this release
  • Packages: a lot of rosdistro is working, including message pipelines, nodes, components, launch, rviz2, MoveIt, Nav2 and Gazebo
  • Platforms: Linux (aarch64 and x86_64) and macOS (aarch64)
  • GUIs: Qt 6 built from source
  • Build cache: Intrinsic provides a read-only GCS-backed cache, which CI warms on every commit to main, to keep builds fast by default. If you’d rather build everything locally, edit .bazelrc before building.
Try it
Get involved
There are likely still bugs, and patching, rollup and release tooling is in place to fix them. To contribute a fix, read the docs in the ros-central-registry repo, or point your agentic coding tool at AGENTS.md and the .agent/skills folder. They explain how to provision a workspace, vendor a package, fix the source and roll up a patch. CI checks that no breaking changes are introduced.
Andrew intends to start a working group to coordinate developers and maintainers. If you’re interested in joining, send @Andrew_Symington a DM to be added to the list.
This work builds on a lot of previous effort, notably by the Bazel team and by Milan Vukov through rules_ros2. Andrew specifically recognizes Milan’s design for the IDL aspects that traverse message dependency chains to generate language bindings, one of the hardest parts to get right.
Thanks, Andrew, for all this work!
Alejandro
how realistic is this?
Maintenance of the mentioned tools is already quite challenging (I’m not directly involved, but based on observations).
Wouldn’t all effort not going towards the established tools essentially complicate that even further? Less potential contributors, less interactions, less users, etc. If someone is happily using this new alternative, why bother ‘caring’ about anything else?
Or do we assume the target audience (ie: those that have expressed or are interested in Bazel) would not fall in the potential contributors pool anyway?
My (very biased) observation is that this is indeed the case. Bazel is very compelling for a number of reasons if you have a large group of developers, the infrastructure team to support them, and a monorepo. And that set of people will probably contribute to the Bazel rules, and the Bazel rules only.
But in my experience, Bazel is also immensely complex. So if you are a smaller team, or in academia, the complexity outweighs the advantages. For those type of teams, the existing tooling is an easier on-ramp, and I would expect these groups to contribute to the already-established tooling.
I think a lot of this used to be true. With the creation of bzlmod, it has become much easier to federate code development and distribute maintenance responsibility (take a look at the number of contributors to the BCR: Contributors to bazelbuild/bazel-central-registry · GitHub ). In 2026 “monorepo mandate” argument no longer holds up.
Many of the sharp edges encountered with Bazel stem from its design philosophy, and there are reasons behind all of the choices. The big ones are, firstly, it enforces a concrete dependency chain – even between targets across module boundaries. This decouples build behavior from the execution environment. Secondly, it forces you to explicitly list all files generated in the build – you can’t simply execute_process and file(GLOB ...) like you would in CMake. This is a good thing because if the output set of files is produced nondeterministically, then they can’t be hashed properly and so you cannot cache any derived targets. Thirdly, it sandboxes your build from the host, so you cannot simply probe for features like “am I running an aarch64 processor”. While inconvenient, this decouples the build from your architecture, and enables sysroot-less cross-compilation with a single flag like --platform @llvm//platforms:linux_aarch64_gnu.2.39.
Traditionally, with colcon the install folder tends to be a dumping ground for assets – and a lot of the time we just get lucky about asset availability because we build the whole workspace before we try and run anything. As a though exercise, consider how many packages in ROS install launch files but don’t exec_depend on launch_ros (eg. image_proc, lifecycle etc.). Bazel’s runfile design choice symlinks on the declared dependencies into the execution sandbox, ensuring reproducible builds. So, adding a launch_ros_binary() target puts a dep on launch_ros, ensuring that it is built and available in the sandbox when the launch is run.
I’d push back on this a little. I think there’s appetite for deploying ROS in products and we’re all trying to minimize crashes and bugs. The ideal place to land fixes is upstream.
Bazel modules preserve patches as part of their metadata, and I think it’s low effort to move these to the source origin. In fact, I plan to run through all patches I needed to stabilize desktop_full in Bazel and move them upstream to the rolling branches.
Concretely, I used --jobs and --runs_per_test flags in Bazel to catch nondeterminism under load, which can help find race conditions, like this one (where the xacro command needs to complete before the simulator launches).
Yes it is. But that is the nature of robotics, and the reason ROS is such a powerful ecosystem. Because, we share this maintenance burden through collective tools. We should not shy away from problems because they are complex. I believe we should remain open to new ideas and tools that can benefit our ecosystem, even if they feel uncomfortable or different.
In its current form, Bazel support is implemented as an augmentation (the build files live in modules outside of the repos) and so the risk of adoption is very low. However, it does take considerable effort maintaining these Bazel build files, but agentic tooling has simplified this work considerably. With enough examples in place – I hand-ported the base code to Bazel :grimacing: – LLMs are pretty good at transforming diffs to CMakeLists.txt and setup.py files to Bazel build file updates.
I think open source works because we each care about a specific aspect of the system that contributes to the whole. The group of Bazel developers care about fast and reproducible builds; the only thing worse than a hard bug is a hard bug that presents 1 our1500 runs, right? And a lot of the work that is put into making this happen can be pushed upstream to packages with zero destructive interference to the Colcon and Pixi builds. The nature of these fixes will be formalizing dependency chains, fixing sources of nondeterminism, etc. I would consider this a form of care, although perhaps just not along the build system axis.
I don’t see ROS developers a resource pool, and maintenance as a resource allocation problem. I see Bazel support as an opportunity to onboard developers from industry to work on ROS.
How would this complement colcon and pixi? If you can build your workspace with bazel you wouldn’t need colcon for building and you wouldn’t use pixi for installing dependencies.
