Hello everyone,
I would like to share my current project: the development of an autonomous pallet jack, with the goal of exploring how robotics and autonomous navigation can be applied to pallet handling and material transport.
The project is currently under development, and I am documenting its progress, design choices and technical aspects on my blog.
Project page:
I am sharing this project here to connect with the robotics community, exchange ideas and learn from people working on autonomous mobile robots, navigation, perception and industrial automation.
I would be particularly interested in feedback and discussions about the technical challenges involved in developing this type of mobile robot.
Thank you for your time, and I look forward to exchanging ideas with the community!
Thanks for your insightful comment! I’ve only been using ROS for a few months, so I’m trying to identify potential pitfalls as early as possible.
My use case involves a shuttle moving between a production area and a logistics zone, primarily through corridors within a relatively small building. It’s an ideal setup for a 2D LiDAR: localization is based on a pre-existing map (supplemented by a “forbidden zones” filter), with the sensor mounted at 1.70m to avoid interference from pallets. Odometry combines wheel encoders and a gyroscope, utilizing an Ackermann-style model that incorporates the measured steering angle. Long, featureless corridors remain a point of concern, and I haven’t yet conducted any tests under load.
Regarding path planning, I’m currently fine-tuning parameters and weighing TEB against RPP. To detect low-lying obstacles, I’m using an HP60C camera paired with a non-persistent voxel layer.
In terms of safety, the traction power supply is routed through a safety relay and a contactor. A “heartbeat” mechanism between the Teensy, the Jetson, and the PLC ensures that power is cut if communication is lost; an emergency stop is also in place. Lateral obstacle detection will be added at a later stage.
I would be very interested to hear about your own experiences and what has worked well for you.
