Anyone working with IsaacLab?
Hello guys,
Is anyone working entirely on Nvidia’s IsaacLab framework. I have ported all the assets to IL, making sure its equivalent to gazebo framework including the cartesian impedance controller.
I was able to teleop and do the port insertion.
ezgif-8f300b5fda6fb898
ezgif-853fa7c97e8421cc
Looking to connect with people working on similar lines.
Hi, have you tested whether very large forces occur during insertion in Isaac Lab? I ran into this before when doing reinforcement learning training, mainly because the coordinate frames were not aligned at the beginning. At that stage, I only worked out a ground-truth setup by trial and error.
Are you talking about FT sensor readings? If so those are stable for me.
Yes, I’m referring to the force sensor. What teleoperation device/setup are you using? Would you be willing to share your modified Isaac Lab environment? I opened a GitHub issue before, but nobody has addressed it.
Sure,I will release the setup.
Thank you! Can you share me your setup? My email is e1520658@u.nus.edu, I want to try RL and IL in isaaclab.
Hi, did you end up releasing the setup? It would be much appreciated!
Hi @blue_dot , I would also love to chat to discuss if you are willing!
I’m thinking of giving the IL setup a try. Gazebo has been hogging all my GPU space. @blue_dot , would much appreciate it if you’re willing to share your IL environment? Beers on me when we meet…
Zipped the IL codebase.
Guys, just don’t surpass me in the rankings. :stuck_out_tongue:
Also the assets have been updated..you might need to download the latest asset pack. Difference between IsaacLab and Gazebo gravity comp forces · Issue #434 · intrinsic-dev/aic · GitHub
