Note: I posted a similar question to robotic.stackexchange
I am using Gazebo Harmonic. Can anyone help me figure out why:
My actor’s pose does not change, even though the world pose changes and the actor with a trajectory moves? I’m aware that, according to the Gazebo Sim documentation, “If the actor has a trajectory, this will only return the origin pose of the trajectory and not the actual world pose of the actor.” However, this leads me to my second question.
I tried to read the world pose, but I can’t seem to find it, as shown below. Also find my PostUpdate implementation below.
[Dbg] [MonitorMovingActorPlugin.cc:109] Box position: (0, 0, 0.5)
[Dbg] [MonitorMovingActorPlugin.cc:128] WorldPose component not found for entity: 4
[Dbg] [MonitorMovingActorPlugin.cc:135] Box position (using wrapper): (0, 0, 0.5)
[Dbg] [MonitorMovingActorPlugin.cc:153] Could not get world pose using Actor wrapper
[Dbg] [MonitorMovingActorPlugin.cc:166] TrajectoryPose component not found for entity: 4
[Dbg] [MonitorMovingActorPlugin.cc:171] [TrajectoryPose] present (wrapper): 0
if (_info.paused)
return;
// Increment the counter
this->iterationCount++;
// Only print every 1000 iterations
if (this->iterationCount % 1000 == 0) {
// Use the ECM directly to get the pose component
auto poseComp = _ecm.Component<gz::sim::components::Pose>(this->actorEntity);
if (poseComp) {
const gz::math::Pose3d &pose = poseComp->Data();
// Print the actor's position (X, Y, Z) to console
gzdbg << "Box position: ("
<< pose.Pos().X() << ", "
<< pose.Pos().Y() << ", "
<< pose.Pos().Z() << ")\n";
else {
gzdbg << "Pose component not found for entity: " << this->actorEntity << std::endl;
// Get position using WorldPose
auto worldPoseComp = _ecm.Component<gz::sim::components::WorldPose>(this->actorEntity);
if (worldPoseComp) {
const gz::math::Pose3d &worldPose = worldPoseComp->Data();
gzdbg << "Box world position: ("
<< worldPose.Pos().X() << ", "
<< worldPose.Pos().Y() << ", "
<< worldPose.Pos().Z() << ")\n";
else {
gzdbg << "WorldPose component not found for entity: " << this->actorEntity << std::endl;
// Or using the wrapper class Actor
// Get position using Actor wrapper Pose() method
auto pose = this->actorWrapper.Pose(_ecm);
if (pose) {
gzdbg << "Box position (using wrapper): ("
<< pose->Pos().X() << ", "
<< pose->Pos().Y() << ", "
<< pose->Pos().Z() << ")\n";
else {
gzdbg << "Could not get pose using Actor wrapper" << std::endl;
// Get position using Actor wrapper WorldPose() method
auto worldPose = this->actorWrapper.WorldPose(_ecm);
if (worldPose) {
gzdbg << "Box world position (using wrapper): ("
<< worldPose->Pos().X() << ", "
<< worldPose->Pos().Y() << ", "
<< worldPose->Pos().Z() << ")\n";
else {
gzdbg << "Could not get world pose using Actor wrapper" << std::endl;
// Check for TrajectoryPose using Component template
auto trajComp = _ecm.Component<gz::sim::components::TrajectoryPose>(this->actorEntity);
if (trajComp) {
const gz::math::Pose3d &trajPose = trajComp->Data();
gzdbg << "Box trajectory position: ("
<< trajPose.Pos().X() << ", "
<< trajPose.Pos().Y() << ", "
<< trajPose.Pos().Z() << ")\n";
else {
gzdbg << "TrajectoryPose component not found for entity: " << this->actorEntity << std::endl;
// Check for TrajectoryPose using wrapper
auto traj = this->actorWrapper.TrajectoryPose(_ecm);
gzdbg << "[TrajectoryPose] present (wrapper): " << bool(traj) << "\n";
Here is my SDF file:
<?xml version="1.0" ?>
<sdf version="1.6">
<world name="moving_box_world">
<plugin
filename="gz-sim-scene-broadcaster-system"
name="gz::sim::systems::SceneBroadcaster">
</plugin>
<actor name="moving_box">
<pose>0 0 0.5 0 0 0</pose>
<link name="moving_box_link">
<visual name="moving_box_visual">
<geometry>
<box>
<size>1 1 1</size>
</box>
</geometry>
</visual>
</link>
<script>
<loop>true</loop>
<delay_start>1.0</delay_start>
<auto_start>true</auto_start>
<trajectory id="0" type="moving_box_trajectory">
<!-- start at X=0 -->
<waypoint>
<time>0.0</time>
</waypoint>
<!-- move to X=5 over 10 s -->
<waypoint>
<time>10.0</time>
<pose>5 0 0.5 0 0 0</pose>
</waypoint>
</trajectory>
</script>
<plugin
filename="MonitorMovingActorPlugin"
name="monitor::MonitorMovingActorPlugin">
<speed>1.0</speed>
</plugin>
</actor>
</world>
</sdf>
