If you we’re not aware you can call your own config.yaml file.
/entrypoint.sh ground_truth:=true start_aic_engine:=true
aic_engine_config_file:=/home/jollyroot/ws_aic/src/aic/aic_engine/config/nqr_nic_card_mount0_config.yaml
So I made this simple trial template generator it will create just the trials in a yaml file, just copy and paste into your config. It’s super simple to modify for task, just modify the template body.
from pathlib import Path
OUTPUT_FILE = "generated_nic_card_mount_0_trials.yaml"
X_MIN = 0.0
X_MAX = 0.3
Y_MIN = -0.35
Y_MAX = 0.20
GRID_X_COUNT = 3
GRID_Y_COUNT = 3
YAW_VALUES = [
3.1415,
3.05,
3.23,
2.95,
3.33,
2.75,
3.53,
2.55,
3.73,
2.35,
3.9444,
def linspace(min_value, max_value, count):
if count <= 1:
return [round(min_value, 6)]
step = (max_value - min_value) / (count - 1)
return [
round(min_value + (step * i), 6)
for i in range(count)
def generate_grid_positions():
x_values = linspace(X_MIN, X_MAX, GRID_X_COUNT)
y_values = linspace(Y_MIN, Y_MAX, GRID_Y_COUNT)
positions = []
for x in x_values:
for y in y_values:
positions.append((x, y))
return positions
def build_trial_block(trial_num, x, y, yaw):
return f""" trial_{trial_num}:
scene:
task_board:
pose:
x: {x}
y: {y}
z: 1.14
roll: 0.0
pitch: 0.0
yaw: {yaw}
nic_rail_0:
entity_present: True
entity_name: "nic_card_0"
entity_pose:
translation: 0.036
roll: 0.0
pitch: 0.0
yaw: 0.0
nic_rail_1:
entity_present: False
nic_rail_2:
nic_rail_3:
nic_rail_4:
sc_rail_0:
entity_name: "sc_mount_0"
entity_pose:
translation: 0.042
roll: 0.0
pitch: 0.0
yaw: 0.1
sc_rail_1:
lc_mount_rail_0:
entity_name: "lc_mount_0"
entity_pose:
translation: 0.02
roll: 0.0
pitch: 0.0
yaw: 0.0
sfp_mount_rail_0:
entity_name: "sfp_mount_0"
entity_pose:
translation: 0.03
roll: 0.0
pitch: 0.0
yaw: 0.0
sc_mount_rail_0:
entity_pose:
translation: -0.02
roll: 0.0
pitch: 0.0
yaw: 0.0
lc_mount_rail_1:
entity_name: "lc_mount_1"
entity_pose:
translation: -0.01
roll: 0.0
pitch: 0.0
yaw: 0.0
sfp_mount_rail_1:
sc_mount_rail_1:
cables:
cable_0:
pose:
gripper_offset:
x: 0.0
y: 0.015385
z: 0.04245
roll: 0.4432
pitch: -0.4838
yaw: 1.3303
attach_cable_to_gripper: True
cable_type: "sfp_sc_cable"
tasks:
task_1:
cable_type: "sfp_sc"
cable_name: "cable_0"
plug_type: "sfp"
plug_name: "sfp_tip"
port_type: "sfp"
port_name: "sfp_port_0"
target_module_name: "nic_card_mount_0"
time_limit: 180
def build_trials(start_trial=1):
blocks = []
trial_num = start_trial
for x, y in generate_grid_positions():
for yaw in YAW_VALUES:
blocks.append(build_trial_block(trial_num, x, y, yaw))
trial_num += 1
return "\n".join(blocks), trial_num - start_trial
def main():
yaml_text, trial_count = build_trials(start_trial=1)
Path(OUTPUT_FILE).write_text(yaml_text, encoding="utf-8")
print("=== MFS TRIAL GENERATOR ===")
print(f"Grid: {GRID_X_COUNT} x {GRID_Y_COUNT}")
print(f"Yaw Trials: {len(YAW_VALUES)} per grid space")
print(f"Total Trials: {trial_count}")
print(f"Output File: {OUTPUT_FILE}")
print(f"X Values: {linspace(X_MIN, X_MAX, GRID_X_COUNT)}")
print(f"Y Values: {linspace(Y_MIN, Y_MAX, GRID_Y_COUNT)}")
if __name__ == "__main__":
main()
