Teleop2servo: gamepad and keyboard teleoperation for MoveIt 2 Servo
Hello there!
I’d like to present (yet another) tool, created because of the lack of similar ones: a ROS 2 package that takes gamepad :video_game: or keyboard :keyboard: input and sends TwistStamped or JointJog messages to MoveIt 2 Servo to control the robot :mechanical_arm:/:robot:.
It all started with the MoveIt 2 tutorial “Realtime Arm Servoing” for Humble. There was a time when the “entire code” link in the tutorial pointed to this file, but today it’s broken. Unfortunately, the new tutorial uses a keyboard instead of a gamepad. Of course, this is a trade-off: it’s easier to get a keyboard working than a gamepad, but you can’t drive multiple axes at the same time (with standard input). Since we wanted a way to teleoperate our robot, we took inspiration from these two examples and created a unified way to run and control it with MoveIt 2 Servo.
This project is a byproduct of our R&D work at the Center of Excellence in Artificial Intelligence at AGH University of Krakow, distributed under the Apache 2.0 license:
teleop2servo
teleop2servo logo hid controlers
Preview: Teleoperation in action
t2s_usage_preview
Preview: CLI UI
t2s_gamepad_preview t2s_keyboard_preview
Features :sparkles:
  • :video_game::keyboard: Two input devices, one package: a terminal keyboard (no extra drivers needed) or a gamepad via the joy package. Switch between them with a single launch argument: teleop_device:=keyboard (default) or teleop_device:=gamepad.
  • :mechanical_arm: Direct MoveIt 2 Servo integration: publishes TwistStamped (Cartesian) and JointJog (joint) commands to the Servo node.
  • Three control modes: JOINT (single joints), BASE (Cartesian, base frame), and TOOL (Cartesian, end-effector frame).
  • Two speed modes: STEP (one fixed step per press) and CONT (continuous motion at 5, 10, 25, 50, 75, or 100% of the configured maximum).
  • Safety first: the device starts blocked and has to be unblocked explicitly. Blocking it stops the motion immediately.
  • :counterclockwise_arrows_button: Optional automatic Servo activation: on unblock, it switches the controllers and calls start_servo. On block or Ctrl+C, it calls stop_servo and restores the original controllers.
  • :house: Go home: moves the robot to a joint position defined in the YAML file, planned and executed by MoveIt. Blocking the device cancels the move.
  • :pinching_hand: Gripper control: opens and closes the gripper through a GripperCommand action.
  • Live CLI UI: shows the current state (blocked/ready), mode, speed, and the controls available in the current mode.
  • Configurable via YAML: velocity steps and limits, frame names, joint names, publishing rate, and more (config/teleop_keyboard.yaml and config/teleop_gamepad.yaml).
  • :electric_plug: Extensible design: ready to be extended with other input devices.
  • :scroll: Apache 2.0 license, targeting ROS 2 Humble.
Thanks & feedback :raising_hands:
The project consists mostly of the work of Antoni Radomiński-Lasek (GitHub, LinkedIn), done during his first steps with ROS 2 and the MoveIt 2 ecosystem (reiterated multiple times).
I’d like to say, once again, that I’m proud of Antoni and his results on this project. We hope that this small tool will help other teams prepare their teleoperation demos. Feedback, issues, and PRs are warmly welcome!
See also our other open source projects:
Robotiq Hand-E gripper ROS 2 Humble driver
Wled_ros_driver: control WLED LED strips from ROS 2
