ROS2 Parameter Value Querying
I need a much better way of grabbing the current value of every parameter of every node running on my system. Not just the dynamic ones, but the defaults and overrides from the launch system. From an experiment documentation standpoint, this is extremely important to understanding exactly how things are configured when producing data and later if data is changing figuring if one of these changed. Sure some nodes may be less important and their parameters not matter much, but there would remain many that are important, so I just want to query all of them. Unfortunately in ROS2 this is extremely disruptive to the node graph and it causes data I’m recording to have gaps. I’ve already played around with QoS to make this a little better, but the entire problem is so frustrating regardless. It was so much better in ROS1. Does anyone have a low impact method to achieve this? Or are there plans to make the parameter system smarter in the future? Is there perhaps an easy way behind the scenes to mod source code and do something like write the parameters values to a field/database on startup?
Can you provide a bit more context like host OS, a rough idea of the system configuration, and what ROS distro?
Parameters were a fairly sizable work surface in Lyrical. There might be some updates there that improve the situation.
What do you do currently? Getparam on all existing params and then subscribe to parameter events?
@engnfrc
thanks for posting.
complaints are welcome, but i do not see what your pain point is. i need more detailed problem description, especially what your expected behavior is.
  • Why ROS1 is better? what is the difference you can see?
  • How do you do that for now? and what is the exact pain?
  • Why QoS matters? (i really do not see why you bring this up…)
thanks,
In case it helps others that come along looking at this topic later, I was referred to the Zulip chat by the CLWG and they got me pointed in a good direction. In short, pulling parameters by way of service clients is expensive, doesn’t scale well, and leads to noticeable data loss in my recordings. I was able to subscribe to the /parameter_events topic early in the startup sequence and relay those messages to a new topic with a transient local QoS in order to get a low overhead snapshot of all of the parameters in my system. More can be found here: Public view of Open Source Robotics Foundation | Zulip team chat
