I am trying to build my python package in ROS2. I have copied the code from minimal_publisher example and just changed some names. After building and trying to run it I get: No executable found.
I am building using src/ament/ament_tools/scripts/ament.py build --symlink-install --only-package rtcm_publisher
and running source ~/ros2_ws/install/local_setup.bash after build.
What am I doing wrong?
My code here:
setup.py
package_name = 'rtcm_publisher'
setup(
name=package_name,
version='0.4.0',
packages=[],
py_modules=[
'rtcm_publisher_old'],
data_files=[
('share/ament_index/resource_index/packages',
['resource/' + package_name]),
('share/' + package_name, ['package.xml']),
install_requires=['setuptools'],
author='Mikael Arguedas',
author_email='mikael@osrfoundation.org',
maintainer='Mikael Arguedas',
maintainer_email='mikael@osrfoundation.org',
keywords=['ROS'],
classifiers=[
'Intended Audience :: Developers',
'License :: OSI Approved :: Apache Software License',
'Programming Language :: Python',
'Topic :: Software Development',
description='Examples of minimal publishers using rclpy.',
license='Apache License, Version 2.0',
entry_points={
'console_scripts': [
'rtcm_publisher_old = rtcm_publisher_old:main'
package.xml
<?xml-model href="http://download.ros.org/schema/package_format2.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?>
<package format="2">
<name>rtcm_publisher</name>
<version>0.4.0</version>
<description>Examples of minimal publishers using rclpy.</description>
<maintainer email="mikael@osrfoundation.org">Mikael Arguedas</maintainer>
<license>Apache License 2.0</license>
<exec_depend>rclpy</exec_depend>
<exec_depend>std_msgs</exec_depend>
<!-- These test dependencies are optional
Their purpose is to make sure that the code passes the linters -->
<!-- <test_depend>ament_copyright</test_depend>
<test_depend>ament_flake8</test_depend>
<test_depend>ament_pep257</test_depend> -->
<export>
<build_type>ament_python</build_type>
</export>
</package>
rtcm_publisher_old.py
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
from time import sleep
import rclpy
from std_msgs.msg import String
# We do not recommend this style as ROS 2 provides timers for this purpose,
# and it is recommended that all nodes call a variation of spin.
# This example is only included for completeness because it is similar to examples in ROS 1.
# For periodic publication please see the other examples using timers.
def main(args=None):
rclpy.init(args=args)
node = rclpy.create_node('rtcm_publisher')
publisher = node.create_publisher(String, 'topic')
msg = String()
i = 0
while rclpy.ok():
msg.data = 'Hello World: %d' % i
i += 1
node.get_logger().info('Publishing: "%s"' % msg.data)
publisher.publish(msg)
sleep(0.5) # seconds
# Destroy the node explicitly
# (optional - otherwise it will be done automatically
# when the garbage collector destroys the node object)
node.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
