The next ROS 2 Rust Meeting will be 2026-03-09T14:00:00Z
The meeting room will be at https://meet.google.com/rxr-pvcv-hmu
In the unlikely event that the room needs to change, we will update this thread with the new info!
cargo + colcon integration.Instructions from Scott on reproducing the demo
The Containerfile is really just for setting up a pristine environment for testing. You should be able to use the
colcon.reposfile on a developer machine normally.https://gist.githubusercontent.com/cottsay/0a683196c96d1b169ffc8136d5eac79b/raw/Containerfile
https://gist.githubusercontent.com/cottsay/88178b1804a8c2b7af7dc9e40bea97e5/raw/colcon.reposThe
.reposfile is “living”, so I’ll try to keep it up-to-date as we merge changes. If a branch for one of these repos disappears, that’s probably what happened.Caveats for the current state:
- We still haven’t landed the version awareness in pallet-patcher, but it’s super close. The version parsing in colcon-cargo also has some known bugs.
- Circular dev dependencies are broken when using the sequential executor. Still deciding which solution to go with on this one, but it should be fixed soon.
