'robot_name' KeyError in get_data when running RMF demo on ROS 2 Jazzy (#698)
Posted by @rajgavhale52:
Hi RMF team,
I’m trying to run an Open-RMF demo on ROS 2 Jazzy, but I’m encountering the following repeated error in the fleet adapter logs:
[fleet_adapter-15] Other error for tinyRobot1 in get_data: ‘robot_name’
[fleet_adapter-15] Other error for tinyRobot2 in get_data: ‘robot_name’
This seems to be a KeyError: ‘robot_name’, likely caused when the fleet adapter attempts to parse the robot status data and does not find the expected ‘robot_name’ field.
What I’ve Checked:
The server-side /status endpoint is running and returning JSON.
However, in some cases, the data field in the response lacks 'robot_name', which causes the error.
This is being caught by client-side checks added to the adapter:
if 'robot_name' not in data:
    print(f"[ERROR] Malformed 'data' content for {robot_name}: missing key 'robot_name'")
    return None
:hammer_and_wrench: My Setup:
ROS 2 distro: Jazzy
RMF version: latest from source (or binary, please clarify here)
Running: rmf_demos with simulated robots (tinyRobot1, tinyRobot2)
FastAPI backend used for robot status updates
Posted by @xiyuoh:
Hello @rajgavhale52 , this is likely an incompatibility with rmf_simulation leading to the fleet adapter unable to discover the robots. I notice your RMF version is a little ambiguous, unsure if you’re using source or binary. Assuming you’re building latest from source, please ensure that you have rmf_simulation and rmf_traffic_editor checked out to jazzy branch before doing a clean build. You can use main for all the other repos. This is documented in our Systems Requirements. Let me know if this works for you.
Let me ask one more thing i want to modify the slotcar plugin but i found difficult to build the rmf_simulation packages in humble having vendor packages error please provide me some idea about this
Hey there! Check out the answer here [Bug]: Build Issue: Missing gz_vendor dependencies in RMF source installation (ROS 2 Humble, Ubuntu 22.04) · Issue #713 · open-rmf/rmf · GitHub
