In this article, I will share the process of bringing a Python-based robotic arm QR code tracking system into ROS and running this project in a simulation environment.
Youtube:
Environment Setup
For this project, it is recommended to use the following development environment and dependency versions:
● Operating System : Ubuntu 20.04 LTS
● ROS Version : Noetic
● Python Version : Python 3.8 or higher
● Library Version Requirement : pymycobot 3.6 or higher
Installing Key Dependencies
Run the following commands in the terminal to install the necessary Python libraries:
pip install stag-python opencv-python scipy numpy pymycobot
Creating a Workspace and Package in ROS
Creating a ROS Workspace
- Open the terminal and create a new ROS workspace called catkin_ws:
mkdir -p ~/catkin_ws/src
- Enter the workspace directory and initialize it:
cd ~/catkin_wscatkin_make
- Set up the environment variables to ensure ROS can locate the workspace:
echo "source ~/catkin_ws/devel/setup.bash" >> ~/.bashrcsource ~/.bashrc
Tip : This configuration will load the workspace settings automatically each time a new terminal is opened.
Creating a ROS Package
- In the src directory, create a new ROS package called qr_tracking with required dependencies (such as rospy and std_msgs):
cd ~/catkin_ws/srccatkin_create_pkg qr_tracking rospy std_msgs
2.Verify the package creation. The qr_tracking directory should contain a standard ROS package structure, including CMakeLists.txt and package.xml files.
- Update dependencies: Open the package.xml file and ensure the following dependencies are included:
<?xml version="1.0"?>
<package format="2">
<name>mycobot_280</name>
<version>0.3.0</version>
<description>The mycobot 280 package</description>
<author email="lijun.zhang@elephantrobotics.com">ZhangLijun</author>
<maintainer email="lijun.zhang@elephantrobotics.com">ZhangLijun</maintainer>
<license>BSD</license>
<url type="website">https://github.com/elephantrobotics/mycobot_ros</url>
<buildtool_depend>catkin</buildtool_depend>
<build_depend>roscpp</build_depend>
<build_depend>rospy</build_depend>
<build_depend>std_msgs</build_depend>
<build_depend>actionlib</build_depend>
<build_depend>mycobot_description</build_depend>
<build_depend>mycobot_communication</build_depend>
<build_export_depend>mycobot_communication</build_export_depend>
<build_export_depend>mycobot_description</build_export_depend>
<exec_depend>roscpp</exec_depend>
<exec_depend>rospy</exec_depend>
<exec_depend>std_msgs</exec_depend>
<exec_depend>actionlib</exec_depend>
<exec_depend>joint_state_publisher</exec_depend>
<exec_depend>joint_state_publisher_gui</exec_depend>
<exec_depend>robot_state_publisher</exec_depend>
<exec_depend>xacro</exec_depend>
<exec_depend>joy</exec_depend>
<exec_depend>rviz</exec_depend>
<exec_depend>controller_manager</exec_depend>
<exec_depend>python-tk</exec_depend>
<exec_depend>mycobot_description</exec_depend>
<exec_depend>mycobot_communication</exec_depend>
<export>
<!-- Additional information for other tools can be added here -->
</export>
</package>
- Rebuild the workspace to apply the ROS package configuration updates:
Ensure that the URDF file for the robotic arm is correctly configured within the ROS package to display the model accurately.
Importing Python Files into the ROS Package
Setting Up the Scripts Directory
In your ROS package qr_tracking, create a folder named scripts to store the Python scripts. Use the following commands:
cd ~/catkin_ws/src/qr_tracking
mkdir scripts
Move your Python files (such as camera_detect.py, uvc_camera.py, marker_utils.py, etc.) to this scripts directory:
mv /path/to/camera_detect.py ~/catkin_ws/src/qr_tracking/scripts/
mv /path/to/uvc_camera.py ~/catkin_ws/src/qr_tracking/scripts/
mv /path/to/marker_utils.py ~/catkin_ws/src/qr_tracking/scripts/
Modifying Python Files for ROS Compatibility
To ensure the Python scripts work with ROS, you need to make some adjustments, such as importing ROS libraries, initializing ROS nodes, and defining message publishers/subscribers. Using camera_detect.py as an example, here are the primary modifications needed:
- Import ROS Libraries
At the top of your Python file, add imports for rospy and any necessary ROS message types:
import rospy from std_msgs.msg import String
- Initialize the ROS Node
Initialize a ROS node at the beginning of your code:
rospy.init_node('camera_detection_node', anonymous=True)
- Define Topic Publisher/Subscriber
Based on the requirements, define a publisher or subscriber. For example, to publish QR code detection results:
pub = rospy.Publisher('qr_detection', String, queue_size=10) rate = rospy.Rate(10) # 10 Hz
Then, you can set up a function to detect QR codes and publish the results. For example:
# Assuming there is a function to detect QR codes
def detect_qr_code():
while not rospy.is_shutdown():
# Detection logic here
detection_result = "QR code detected" # This is the detection result
rospy.loginfo(detection_result)
pub.publish(detection_result)
rate.sleep()
Code Example
Below is a simplified code snippet showing how to publish QR code detection results in camera_detect.py:
#!/usr/bin/env python
import rospy
# Replace with actual detection logic
detection_result = "QR code detected" # Simulated detection result
rate.sleep()
if __name__ == '__main__':
try:
detect_qr_code()
except rospy.ROSInterruptException:
pass
Note : Ensure the Python files are executable by running
chmod +x ~/catkin_ws/src/qr_tracking/scripts/*.py.
Configuring the CMakeLists.txt File
Overview of CMake Configuration
In ROS, the CMakeLists.txt file is a core configuration file for each package, specifying how to compile and install files within the package. It includes configuration details like compiler options, library dependencies, and installation paths. For Python scripts to function as ROS nodes, we need to make a few necessary adjustments to this file.
Modifying CMakeLists.txt
To make the Python scripts executable within ROS, follow these steps:
- Add Catkin Build Dependencies
Ensure CMakeLists.txt includes a find_package statement to locate catkin and the necessary ROS dependencies, such as rospy and std_msgs. Here’s an example:
cmake_minimum_required(VERSION 2.8.3)
project(mycobot_280)
add_compile_options(-std=c++11)
## Find catkin and any catkin packages
find_package(catkin REQUIRED COMPONENTS
roscpp
rospy
std_msgs
actionlib
image_transport
cv_bridge
- Install Python Scripts
Use catkin_install_python to specify the installation path for Python scripts and to ensure they have executable permissions. Assuming your Python scripts are located in the scripts directory, add the following section to CMakeLists.txt:
catkin_install_python(PROGRAMS
scripts/follow_display.py
scripts/slider_control.py
scripts/teleop_keyboard.py
scripts/listen_real.py
scripts/listen_real_of_topic.py
scripts/simple_gui.py
scripts/follow_display_gripper.py
scripts/slider_control_gripper.py
scripts/listen_real_gripper.py
scripts/detect_stag.py
DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
This command installs the Python scripts to the ROS package’s binary directory and ensures they have executable permissions after compilation.
- Add Dependencies
Before calling catkin_package(), declare the dependencies to ensure ROS correctly resolves them. For example:
catkin_package( CATKIN_DEPENDS std_msgs actionlib )
- Complete Example
Here is a sample configuration for the CMakeLists.txt file:
roscpp
rospy
std_msgs
actionlib
image_transport
cv_bridge
## Declare a catkin package
catkin_package(
## Include directories
include_directories(include ${catkin_INCLUDE_DIRS} ${OpenCV_INCLUDE_DIRS})
## Install Python scripts
## Install launch and config directories
install(DIRECTORY launch DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
PATTERN "setup_assistant.launch" EXCLUDE)
install(DIRECTORY config DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION})
## OpenCV requirements
find_package(OpenCV REQUIRED)
add_executable(opencv_camera src/opencv_camera)
target_link_libraries(opencv_camera ${catkin_LIBRARIES} ${OpenCV_LIBRARIES})
add_executable(camera_display src/camera_display)
target_link_libraries(camera_display ${catkin_LIBRARIES} ${OpenCV_LIBRARIES})
With these modifications, the Python scripts will be part of the ROS package, given executable permissions, and runnable using ROS tools such as rosrun.
This section is crucial for guiding users on how to compile, start, and verify the project’s functionality in ROS.
6. Compiling and Running
Compiling the Workspace
After configuring all aspects of your ROS package, you need to compile the workspace to generate and configure the necessary resources.
- Ensure you are in the root directory of the workspace:
cd ~/catkin_ws
- Run
catkin_maketo compile the workspace:
catkin_make
If the compilation succeeds, you should see output similar to:
[100%] Built target qr_tracking
Launching the Node
Once compilation is complete, you can use rosrun to start the QR code tracking node.
- Ensure that the workspace environment variables are loaded, and launch the simulation model:
cd ~/catkin_ws source devel/setup.bash roslaunch mycobot_280 detect_marker_with_topic.launch port:=/dev/ttyUSB0 baud:=115200
- Use
rosrunto start thecamera_detect.pyscript:
rosrun qr_tracking camera_detect.py
You should see output indicating that the ROS node has been initialized, and it will begin publishing QR code detection results.
GitHub:
