Hi all,
I’ve open-sourced OpenDroneLab, a sim-first drone autonomy lab. My goal was a current PX4 + ROS 2 SITL setup where every flight gets a score instead of just being watched.
What it is
- PX4 v1.17 SITL, ROS 2 Jazzy, and Gazebo Harmonic in one locally built Docker dev image
- A C++ OFFBOARD square-flight mission as the main mission path
- Optional OpenVINS (GPL-3, kept isolated) running in shadow, with vision fusion into EKF2 as an opt-in
- Every official flight is graded against Gazebo ground truth with an evo Umeyama RMSE fit. The regression gates fail loudly, and they live in
config/regression_thresholds.yaml - Stress worlds (
low_texture,faster_motion,wind), rosbag2/mcap recording, and a Foxglove layout for replay
Current numbers (documented SITL runs)
mc_gps(GPS only, x500): EKF2 Umeyama xy mean 0.2572 ± 0.0022 m over N=5 runs, against a 0.39 m gate, pass@1 5/5baseline(x500 mono cam): EKF2 xy 0.258 m and VIO xy 0.445 m, against gates of 0.40 / 0.70 mlow_texturegets a score but doesn’t gate yet. It’s a known limitation, and so is a VIO jump on the far side of the baseline square, which is on the roadmap.
Try it in 2 minutes, no SITL needed: grab the 294 KB mc_gps sample bag from the v0.1.0 release and open it in Foxglove with the layout in the repo.
Full SITL: build the dev image, run the headless unit tests, then run HEADLESS=1 ./scripts/run-regression.sh for the scored suite (this needs an NVIDIA GPU).
It’s software-in-the-loop only and not flight-certified. License: AGPL-3.0-only.
- Repo: github.com/palcode/opendronelab
- Docs: palcode.github.io/opendronelab
- Release: github.com/palcode/opendronelab/releases/tag
I’d really value feedback on the scoring approach (global Umeyama xy versus something like RPE), on which scenarios you’d want gated next, and on any rough edges in setup. Good first issues and Discussions are open.
