Nerian Vision Technologies has released SceneScan – a new ROS-compatible 3D sensor system that is based on stereo vision. Unlike conventional depth cameras, stereo vision is a passive technology, which also works robustly in bright daylight and over long distances.
SceneScan is an embedded system that uses a powerful FPGA and state-of-the-art image processing algorithms to convert the imagery of a stereo cameras or two conventional cameras into a depth map or 3D point cloud. This can be done at frame rates of up to 100 fps and image resolutions up to 3 megapixels.
Together with SceneScan, Nerian also released the new Karmin2 stereo camera. Both devices work optimally together and form a fully featured 3D depth sensor system.
You can learn more about SceneScan at:
https://nerian.com/products/scenescan-stereo-vision/
More information about Karmin2 is available at:
https://nerian.com/products/karmin2-3d-stereo-camera/
A ROS node for SceneScan has already been released and is available from the ROS package servers. Details can be found in the ROS wiki at:
http://wiki.ros.org/nerian_stereo
