We’re happy to announce 16 new packages and 26 updates are now available in ROS Noetic. This sync was tagged as noetic/2024-09-05.
Added Packages [16]:
- ros-noetic-mola-common: 0.4.0-1
- ros-noetic-mrpt-apps: 2.13.7-5
- ros-noetic-mrpt-libapps: 2.13.7-5
- ros-noetic-mrpt-libbase: 2.13.7-5
- ros-noetic-mrpt-libgui: 2.13.7-5
- ros-noetic-mrpt-libhwdrivers: 2.13.7-5
- ros-noetic-mrpt-libmaps: 2.13.7-5
- ros-noetic-mrpt-libmath: 2.13.7-5
- ros-noetic-mrpt-libnav: 2.13.7-5
- ros-noetic-mrpt-libobs: 2.13.7-5
- ros-noetic-mrpt-libopengl: 2.13.7-5
- ros-noetic-mrpt-libposes: 2.13.7-5
- ros-noetic-mrpt-libros-bridge: 2.13.7-5
- ros-noetic-mrpt-libslam: 2.13.7-5
- ros-noetic-mrpt-libtclap: 2.13.7-5
- ros-noetic-snmp-diagnostics: 0.1.1-1
Updated Packages [26]:
- ros-noetic-audio-capture: 0.3.17-1 → 0.3.18-1
- ros-noetic-audio-common: 0.3.17-1 → 0.3.18-1
- ros-noetic-audio-common-msgs: 0.3.17-1 → 0.3.18-1
- ros-noetic-audio-play: 0.3.17-1 → 0.3.18-1
- ros-noetic-depthai: 2.26.1-1 → 2.28.0-1
- ros-noetic-eigenpy: 3.1.4-5 → 3.8.2-1
- ros-noetic-mp2p-icp: 0.1.0-1 → 1.5.4-1
- ros-noetic-mrpt-ekf-slam-2d: 0.1.17-1 → 0.1.18-1
- ros-noetic-mrpt-ekf-slam-3d: 0.1.17-1 → 0.1.18-1
- ros-noetic-mrpt-graphslam-2d: 0.1.17-1 → 0.1.18-1
- ros-noetic-mrpt-icp-slam-2d: 0.1.17-1 → 0.1.18-1
- ros-noetic-mrpt-local-obstacles: 1.0.5-1 → 1.0.6-2
- ros-noetic-mrpt-localization: 1.0.5-1 → 1.0.6-2
- ros-noetic-mrpt-map: 1.0.5-1 → 1.0.6-2
- ros-noetic-mrpt-msgs-bridge: 1.0.5-1 → 1.0.6-2
- ros-noetic-mrpt-navigation: 1.0.5-1 → 1.0.6-2
- ros-noetic-mrpt-path-planning: 0.1.2-1 → 0.1.4-1
- ros-noetic-mrpt-rawlog: 1.0.5-1 → 1.0.6-2
- ros-noetic-mrpt-rbpf-slam: 0.1.17-1 → 0.1.18-1
- ros-noetic-mrpt-reactivenav2d: 1.0.5-1 → 1.0.6-2
- ros-noetic-mrpt-slam: 0.1.17-1 → 0.1.18-1
- ros-noetic-mrpt-tutorials: 1.0.5-1 → 1.0.6-2
- ros-noetic-mvsim: 0.9.4-1 → 0.10.0-2
- ros-noetic-pose-cov-ops: 0.3.11-1 → 0.3.12-1
- ros-noetic-robot-localization: 2.7.6-1 → 2.7.7-1
- ros-noetic-sound-play: 0.3.17-1 → 0.3.18-1
Removed Packages [0]:
- Adam Serafin
- Austin Hendrix
- Jose Luis Blanco-Claraco
- Jose-Luis Blanco-Claraco
- José Luis Blanco-Claraco
- Justin Carpentier
- Markus Bader
- Martin Pecka
- Nikos Koukis
- Tom Moore
- Vladislav Tananaev
