We’re happy to announce 13 new packages and 110 updates are now available in ROS Noetic. This sync was tagged as noetic/2023-03-02.
This is also the final sync with Debian Buster support, as that platform reached it’s end of life. ros/rosdistro PRs are still being held in preparation for a final snapshot for Debian Buster.
Added Packages [13]:
- ros-noetic-cras-docs-common: 2.1.2-1
- ros-noetic-depthai-ros-driver: 2.6.1-2
- ros-noetic-flatland: 1.3.3-1
- ros-noetic-flatland-msgs: 1.3.3-1
- ros-noetic-flatland-plugins: 1.3.3-1
- ros-noetic-flatland-server: 1.3.3-1
- ros-noetic-flatland-viz: 1.3.3-1
- ros-noetic-image-transport-codecs: 2.1.2-1
- ros-noetic-lanelet2-matching: 1.2.0-2
- ros-noetic-moveit-task-constructor-core: 0.1.1-1
- ros-noetic-moveit-task-constructor-msgs: 0.1.1-1
- ros-noetic-rviz-marker-tools: 0.1.1-1
- ros-noetic-rviz-tool-path-display: 0.1.1-1
Updated Packages [110]:
- ros-noetic-ackermann-steering-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-bosch-locator-bridge: 1.0.7-1 → 1.0.8-1
- ros-noetic-costmap-cspace: 0.11.8-1 → 0.12.0-1
- ros-noetic-costmap-cspace-msgs: 0.8.0-1 → 0.12.0-1
- ros-noetic-cras-cpp-common: 2.0.10-2 → 2.1.2-1
- ros-noetic-cras-py-common: 2.0.10-2 → 2.1.2-1
- ros-noetic-cras-topic-tools: 2.0.10-2 → 2.1.2-1
- ros-noetic-depthai: 2.19.1-1 → 2.20.2-1
- ros-noetic-depthai-bridge: 2.5.3-1 → 2.6.1-2
- ros-noetic-depthai-examples: 2.5.3-1 → 2.6.1-2
- ros-noetic-depthai-ros: 2.5.3-1 → 2.6.1-2
- ros-noetic-depthai-ros-msgs: 2.5.3-1 → 2.6.1-2
- ros-noetic-diff-drive-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-dingo-control: 0.2.0-1 → 0.3.0-1
- ros-noetic-dingo-description: 0.2.0-1 → 0.3.0-1
- ros-noetic-dingo-msgs: 0.2.0-1 → 0.3.0-1
- ros-noetic-dingo-navigation: 0.2.0-1 → 0.3.0-1
- ros-noetic-effort-controllers: 0.21.0-1 → 0.21.1-1
- ros-noetic-eigenpy: 2.8.1-1 → 2.9.2-1
- ros-noetic-executive-smach: 2.5.0-1 → 2.5.1-1
- ros-noetic-force-torque-sensor-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-forward-command-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-four-wheel-steering-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-foxglove-bridge: 0.3.0-1 → 0.4.1-1
- ros-noetic-graceful-controller: 0.4.5-1 → 0.4.6-1
- ros-noetic-graceful-controller-ros: 0.4.5-1 → 0.4.6-1
- ros-noetic-gripper-action-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-imu-sensor-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-joint-state-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-joint-trajectory-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-joystick-interrupt: 0.11.8-1 → 0.12.0-1
- ros-noetic-lanelet2: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-core: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-examples: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-io: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-maps: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-projection: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-python: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-routing: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-traffic-rules: 1.1.1-1 → 1.2.0-2
- ros-noetic-lanelet2-validation: 1.1.1-1 → 1.2.0-2
- ros-noetic-laser-ortho-projector: 0.3.3-1 → 0.4.0-1
- ros-noetic-laser-scan-matcher: 0.3.3-1 → 0.4.0-1
- ros-noetic-laser-scan-sparsifier: 0.3.3-1 → 0.4.0-1
- ros-noetic-laser-scan-splitter: 0.3.3-1 → 0.4.0-1
- ros-noetic-map-organizer: 0.11.8-1 → 0.12.0-1
- ros-noetic-map-organizer-msgs: 0.8.0-1 → 0.12.0-1
- ros-noetic-message-filters: 1.15.15-1 → 1.16.0-1
- ros-noetic-microstrain-inertial-driver: 3.0.0-1 → 3.0.1-1
- ros-noetic-microstrain-inertial-examples: 3.0.0-1 → 3.0.1-1
- ros-noetic-microstrain-inertial-msgs: 3.0.0-1 → 3.0.1-1
- ros-noetic-microstrain-inertial-rqt: 3.0.0-1 → 3.0.1-1
- ros-noetic-ncd-parser: 0.3.3-1 → 0.4.0-1
- ros-noetic-neonavigation: 0.11.8-1 → 0.12.0-1
- ros-noetic-neonavigation-common: 0.11.8-1 → 0.12.0-1
- ros-noetic-neonavigation-launch: 0.11.8-1 → 0.12.0-1
- ros-noetic-neonavigation-msgs: 0.8.0-1 → 0.12.0-1
- ros-noetic-novatel-oem7-driver: 4.0.0-1 → 4.1.0-1
- ros-noetic-novatel-oem7-msgs: 4.0.0-1 → 4.1.0-1
- ros-noetic-obj-to-pointcloud: 0.11.8-1 → 0.12.0-1
- ros-noetic-paho-mqtt-c: 1.3.11-1 → 1.3.12-1
- ros-noetic-pinocchio: 2.6.14-1 → 2.6.17-1
- ros-noetic-planner-cspace: 0.11.8-1 → 0.12.0-1
- ros-noetic-planner-cspace-msgs: 0.8.0-1 → 0.12.0-1
- ros-noetic-polar-scan-matcher: 0.3.3-1 → 0.4.0-1
- ros-noetic-position-controllers: 0.21.0-1 → 0.21.1-1
- ros-noetic-pybind11-catkin: 2.5.0-1 → 2.10.3-2
- ros-noetic-rgbd-launch: 2.3.0-1 → 2.4.0-1
- ros-noetic-rm-common: 0.1.15-1 → 0.1.17-1
- ros-noetic-rm-control: 0.1.15-1 → 0.1.17-1
- ros-noetic-rm-dbus: 0.1.15-1 → 0.1.17-1
- ros-noetic-rm-gazebo: 0.1.15-1 → 0.1.17-1
- ros-noetic-rm-hw: 0.1.15-1 → 0.1.17-1
- ros-noetic-rm-msgs: 0.1.15-1 → 0.1.17-1
- ros-noetic-robotraconteur: 0.15.5-1 → 0.16.0-2
- ros-noetic-ros-comm: 1.15.15-1 → 1.16.0-1
- ros-noetic-ros-controllers: 0.21.0-1 → 0.21.1-1
- ros-noetic-ros-industrial-cmake-boilerplate: 0.3.1-1 → 0.4.0-1
- ros-noetic-rosbag: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosbag-storage: 1.15.15-1 → 1.16.0-1
- ros-noetic-roscpp: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosgraph: 1.15.15-1 → 1.16.0-1
- ros-noetic-roslaunch: 1.15.15-1 → 1.16.0-1
- ros-noetic-roslisp: 1.9.24-1 → 1.9.25-1
- ros-noetic-roslz4: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosmaster: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosmsg: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosnode: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosout: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosparam: 1.15.15-1 → 1.16.0-1
- ros-noetic-rospy: 1.15.15-1 → 1.16.0-1
- ros-noetic-rosservice: 1.15.15-1 → 1.16.0-1
- ros-noetic-rostest: 1.15.15-1 → 1.16.0-1
- ros-noetic-rostopic: 1.15.15-1 → 1.16.0-1
- ros-noetic-roswtf: 1.15.15-1 → 1.16.0-1
- ros-noetic-rqt-joint-trajectory-controller: 0.21.0-1 → 0.21.1-1
- ros-noetic-rviz-satellite: 3.0.3-1 → 3.1.0-1
- ros-noetic-safety-limiter: 0.11.8-1 → 0.12.0-1
- ros-noetic-safety-limiter-msgs: 0.8.0-1 → 0.12.0-1
- ros-noetic-scan-to-cloud-converter: 0.3.3-1 → 0.4.0-1
- ros-noetic-scan-tools: 0.3.3-1 → 0.4.0-1
- ros-noetic-smach: 2.5.0-1 → 2.5.1-1
- ros-noetic-smach-msgs: 2.5.0-1 → 2.5.1-1
- ros-noetic-smach-ros: 2.5.0-1 → 2.5.1-1
- ros-noetic-topic-tools: 1.15.15-1 → 1.16.0-1
- ros-noetic-track-odometry: 0.11.8-1 → 0.12.0-1
- ros-noetic-trajectory-tracker: 0.11.8-1 → 0.12.0-1
- ros-noetic-trajectory-tracker-msgs: 0.8.0-1 → 0.12.0-1
- ros-noetic-velocity-controllers: 0.21.0-1 → 0.21.1-1
- ros-noetic-xmlrpcpp: 1.15.15-1 → 1.16.0-1
Removed Packages [0]:
- Adam Serafin
- Atsushi Watanabe
- Bence Magyar
- Carlos
- Fabian Immel
- Gayane Kazhoyan
- Isaac I. Y. Saito
- Ivan Dryanovski
- Jan-Hendrik Pauls
- John Hurliman
- John Wason
- Joseph Duchesne
- Justin Carpentier
- Levi Armstrong
- Martin Pecka
- Masaru Morita
- Michael Carroll
- Michael Ferguson
- Michael Goerner
- Michael Ripperger
- NovAtel Support
- Piyush Khandelwal
- Qiayuan Liao
- Rob Fisher
- Robert Haschke
- Sachin Chitta
- Sachin Guruswamy
- Stefan Laible
- Tim Clephas
- Tony Baltovski
- Vincent Rousseau
- Wolfgang Merkt
- qiayuan
- sachin
