New Packages for Noetic 2020-07-18
We’re happy to announce 89 new packages and 58 updates are now available in ROS Noetic.
Added Packages [89]:
Updated Packages [58]:
  • ros-noetic-costmap-cspace: 0.8.8-1 → 0.9.0-1
  • ros-noetic-costmap-cspace-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-fadecandy-driver: 0.1.1-2 → 0.1.2-1
  • ros-noetic-fadecandy-msgs: 0.1.1-2 → 0.1.2-1
  • ros-noetic-joystick-interrupt: 0.8.8-1 → 0.9.0-1
  • ros-noetic-joystick-interrupt-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-map-organizer: 0.8.8-1 → 0.9.0-1
  • ros-noetic-map-organizer-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-marti-data-structures: 2.13.7-1 → 2.14.0-1
  • ros-noetic-mavlink: 2020.6.6-1 → 2020.7.7-1
  • ros-noetic-neonavigation: 0.8.8-1 → 0.9.0-1
  • ros-noetic-neonavigation-common: 0.8.8-1 → 0.9.0-1
  • ros-noetic-neonavigation-launch: 0.8.8-1 → 0.9.0-1
  • ros-noetic-obj-to-pointcloud: 0.8.8-1 → 0.9.0-1
  • ros-noetic-obj-to-pointcloud-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-planner-cspace: 0.8.8-1 → 0.9.0-1
  • ros-noetic-planner-cspace-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-rospy-message-converter: 0.5.1-1 → 0.5.2-1
  • ros-noetic-safety-limiter: 0.8.8-1 → 0.9.0-1
  • ros-noetic-safety-limiter-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-swri-console-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-console-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-dbw-interface: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-geometry-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-geometry-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-image-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-image-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-math-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-math-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-nodelet: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-opencv-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-opencv-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-prefix-tools: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-roscpp: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-roscpp-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-rospy: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-route-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-route-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-serial-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-serial-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-string-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-string-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-system-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-system-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-transform-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-transform-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-yaml-util: 2.13.7-1 → 2.14.0-1
  • ros-noetic-swri-yaml-util-dbgsym: 2.13.7-1 → 2.14.0-1
  • ros-noetic-track-odometry: 0.8.8-1 → 0.9.0-1
  • ros-noetic-track-odometry-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-trajectory-tracker: 0.8.8-1 → 0.9.0-1
  • ros-noetic-trajectory-tracker-dbgsym: 0.8.8-1 → 0.9.0-1
  • ros-noetic-usb-cam-controllers: 0.0.5-1 → 0.2.1-1
  • ros-noetic-usb-cam-controllers-dbgsym: 0.0.5-1 → 0.2.1-1
  • ros-noetic-usb-cam-hardware: 0.0.5-1 → 0.2.1-1
  • ros-noetic-usb-cam-hardware-dbgsym: 0.0.5-1 → 0.2.1-1
  • ros-noetic-usb-cam-hardware-interface: 0.0.5-1 → 0.2.1-1
  • ros-noetic-xacro: 1.14.2-1 → 1.14.3-2
Removed Packages [0]:
  • Adam Allevato
  • Andy Zelenak
  • Atsushi Watanabe
  • Bence Magyar
  • Chris Lalancette
  • Danylo Malyuta
  • Davide Faconti
  • Franka Emika GmbH
  • Jon Binney
  • Jonathan Bohren
  • Josh Whitley
  • Kei Okada
  • Kevin Hallenbeck
  • Kris Kozak
  • Marc Alban
  • Martin Günther
  • Micho Radovnikovich
  • Niharika Arora
  • P. J. Reed
  • Robert Haschke
  • Ryohei Ueda
  • Steven Macenski
  • Tim Clephas
  • Vladimir Ermakov
  • Will Son
  • YoheiKakiuchi
  • Yoshito Okada
  • achille
  • rohan
