We’re happy to announce the availability of 11 new packages and 82 updated packages for ROS Lunar.
As always thank you to all the maintainers who are making these releases as well as all the contributors who have helped contribute to these releases. Full details are below.
Package Updates for lunar
Added Packages [11]:
- ros-lunar-astuff-sensor-msgs: 2.0.1-0
- ros-lunar-delphi-esr-msgs: 2.0.1-0
- ros-lunar-delphi-srr-msgs: 2.0.1-0
- ros-lunar-grasping-msgs: 0.3.1-0
- ros-lunar-ibeo-msgs: 2.0.1-0
- ros-lunar-kartech-linear-actuator-msgs: 2.0.1-0
- ros-lunar-mobileye-560-660-msgs: 2.0.1-0
- ros-lunar-neobotix-usboard-msgs: 2.0.1-0
- ros-lunar-network-interface: 2.0.0-0
- ros-lunar-pacmod-msgs: 2.0.1-0
- ros-lunar-radar-omnipresense: 0.1.0-1
Updated Packages [82]:
- ros-lunar-actionlib-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-audio-capture: 0.3.2-0 → 0.3.3-0
- ros-lunar-audio-common: 0.3.2-0 → 0.3.3-0
- ros-lunar-audio-common-msgs: 0.3.2-0 → 0.3.3-0
- ros-lunar-audio-play: 0.3.2-0 → 0.3.3-0
- ros-lunar-axis-camera: 0.2.1-0 → 0.3.0-0
- ros-lunar-can-msgs: 0.7.8-0 → 0.7.9-0
- ros-lunar-canopen-402: 0.7.8-0 → 0.7.9-0
- ros-lunar-canopen-chain-node: 0.7.8-0 → 0.7.9-0
- ros-lunar-canopen-master: 0.7.8-0 → 0.7.9-0
- ros-lunar-canopen-motor-node: 0.7.8-0 → 0.7.9-0
- ros-lunar-common-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-costmap-converter: 0.0.7-0 → 0.0.9-0
- ros-lunar-diagnostic-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-geometry-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-imu-complementary-filter: 1.1.5-0 → 1.2.0-0
- ros-lunar-imu-filter-madgwick: 1.1.5-0 → 1.2.0-0
- ros-lunar-imu-tools: 1.1.5-0 → 1.2.0-0
- ros-lunar-marti-can-msgs: 0.5.0-0 → 0.6.0-0
- ros-lunar-marti-common-msgs: 0.5.0-0 → 0.6.0-0
- ros-lunar-marti-data-structures: 2.2.1-0 → 2.3.0-0
- ros-lunar-marti-nav-msgs: 0.5.0-0 → 0.6.0-0
- ros-lunar-marti-perception-msgs: 0.5.0-0 → 0.6.0-0
- ros-lunar-marti-sensor-msgs: 0.5.0-0 → 0.6.0-0
- ros-lunar-marti-status-msgs: 0.5.0-0 → 0.6.0-0
- ros-lunar-marti-visualization-msgs: 0.5.0-0 → 0.6.0-0
- ros-lunar-moveit: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-commander: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-controller-manager-example: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-core: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-fake-controller-manager: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-kinematics: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-planners: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-planners-ompl: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-plugins: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-benchmarks: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-control-interface: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-manipulation: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-move-group: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-perception: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-planning: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-planning-interface: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-robot-interaction: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-visualization: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-ros-warehouse: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-runtime: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-setup-assistant: 0.9.11-0 → 0.9.12-1
- ros-lunar-moveit-simple-controller-manager: 0.9.11-0 → 0.9.12-1
- ros-lunar-nav-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-ompl: 1.3.1-3 → 1.3.5-0
- ros-lunar-pid: 0.0.24-0 → 0.0.25-0
- ros-lunar-plotjuggler: 1.6.0-0 → 1.6.2-0
- ros-lunar-ros-canopen: 0.7.8-0 → 0.7.9-0
- ros-lunar-rosmon: 1.0.3-0 → 1.0.7-0
- ros-lunar-rqt-dep: 0.4.8-0 → 0.4.9-0
- ros-lunar-rviz-imu-plugin: 1.1.5-0 → 1.2.0-0
- ros-lunar-sensor-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-shape-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-sick-tim: 0.0.12-0 → 0.0.13-0
- ros-lunar-socketcan-bridge: 0.7.8-0 → 0.7.9-0
- ros-lunar-socketcan-interface: 0.7.8-0 → 0.7.9-0
- ros-lunar-sound-play: 0.3.2-0 → 0.3.3-0
- ros-lunar-stereo-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-swri-console-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-dbw-interface: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-geometry-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-image-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-math-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-nodelet: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-opencv-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-prefix-tools: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-roscpp: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-rospy: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-route-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-serial-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-string-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-system-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-transform-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-swri-yaml-util: 2.2.1-0 → 2.3.0-0
- ros-lunar-trajectory-msgs: 1.12.5-0 → 1.12.6-0
- ros-lunar-visualization-msgs: 1.12.5-0 → 1.12.6-0
Removed Packages [0]:
- Andy Zelenak
- Austin Hendrix
- AutonomouStuff Software Team
- Christoph Rösmann
- Dave Coleman
- Davide Faconti
- Dirk Thomas
- Ed Venator
- Edmond DuPont
- Elliot Johnson
- Garren Hendricks
- Ioan Sucan
- Isaac I. Y. Saito
- Jon Binney
- Kris Kozak
- Marc Alban
- Mark Moll
- Martin Günther
- Mathias Lüdtke
- Max Schwarz
- Michael Ferguson
- Michael Görner
- Roberto G. Valenti
- Sammy Pfeiffer
- Tully Foote
