We’re happy to announce 15 new packages and 131 updated packages for Kinetic this week. For full details please see below.
Thank you to all the maintainers and contributors who helped make these updates possible!
Package Updates for kinetic
Added Packages [15]:
- ros-kinetic-distance-map: 0.1.0-1
- ros-kinetic-distance-map-core: 0.1.0-1
- ros-kinetic-distance-map-deadreck: 0.1.0-1
- ros-kinetic-distance-map-msgs: 0.1.0-1
- ros-kinetic-distance-map-node: 0.1.0-1
- ros-kinetic-distance-map-opencv: 0.1.0-1
- ros-kinetic-distance-map-rviz: 0.1.0-1
- ros-kinetic-distance-map-tools: 0.1.0-1
- ros-kinetic-drone-wrapper: 1.0.0-1
- ros-kinetic-microstrain-mips: 0.0.3-1
- ros-kinetic-rospy-wrapper: 1.0.0-1
- ros-kinetic-rqt-drone-teleop: 1.0.0-1
- ros-kinetic-seed-smartactuator-sdk: 0.0.3-1
- ros-kinetic-warthog-gazebo: 0.1.0-1
- ros-kinetic-warthog-simulator: 0.1.0-1
Updated Packages [131]:
- ros-kinetic-actionlib-enhanced: 0.0.6-1 → 0.0.9-1
- ros-kinetic-aws-ros1-common: 2.0.0-1 → 2.0.1-1
- ros-kinetic-cob-3d-mapping-msgs: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-actions: 0.6.12-1 → 0.7.0-1
- ros-kinetic-cob-base-controller-utils: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-base-drive-chain: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-base-velocity-smoother: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-bms-driver: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-bringup: 0.6.11-0 → 0.7.0-1
- ros-kinetic-cob-bringup-sim: 0.6.10-0 → 0.7.1-1
- ros-kinetic-cob-calibration-data: 0.6.11-0 → 0.6.12-1
- ros-kinetic-cob-cam3d-throttle: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-camera-sensors: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-canopen-motor: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-cartesian-controller: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-collision-velocity-filter: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-command-gui: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-command-tools: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-common: 0.6.12-1 → 0.7.0-1
- ros-kinetic-cob-control: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-control-mode-adapter: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-control-msgs: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-dashboard: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-default-env-config: 0.6.8-0 → 0.6.10-1
- ros-kinetic-cob-default-robot-behavior: 0.6.11-0 → 0.7.0-1
- ros-kinetic-cob-default-robot-config: 0.6.11-0 → 0.7.0-1
- ros-kinetic-cob-description: 0.6.12-1 → 0.7.0-1
- ros-kinetic-cob-docker-control: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-driver: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-elmo-homing: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-environments: 0.6.8-0 → 0.6.10-1
- ros-kinetic-cob-extern: 0.6.12-0 → 0.6.13-1
- ros-kinetic-cob-footprint-observer: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-frame-tracker: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-gazebo: 0.6.10-0 → 0.7.1-1
- ros-kinetic-cob-gazebo-objects: 0.6.10-0 → 0.7.1-1
- ros-kinetic-cob-gazebo-plugins: 0.7.2-0 → 0.7.3-1
- ros-kinetic-cob-gazebo-ros-control: 0.7.2-0 → 0.7.3-1
- ros-kinetic-cob-gazebo-worlds: 0.6.10-0 → 0.7.1-1
- ros-kinetic-cob-generic-can: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-hand: 0.6.5-0 → 0.6.6-1
- ros-kinetic-cob-hand-bridge: 0.6.5-0 → 0.6.6-1
- ros-kinetic-cob-hardware-config: 0.6.11-0 → 0.7.0-1
- ros-kinetic-cob-helper-tools: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-image-flip: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-interactive-teleop: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-light: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-linear-nav: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-map-accessibility-analysis: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-mapping-slam: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-mimic: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-model-identifier: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-monitoring: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-moveit-config: 0.6.11-0 → 0.7.0-1
- ros-kinetic-cob-msgs: 0.6.12-1 → 0.7.0-1
- ros-kinetic-cob-navigation: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-navigation-config: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-navigation-global: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-navigation-local: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-navigation-slam: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-object-detection-msgs: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-object-detection-visualizer: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-obstacle-distance: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-omni-drive-controller: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-perception-common: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-perception-msgs: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-phidget-em-state: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-phidget-power-state: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-phidgets: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-reflector-referencing: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-relayboard: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-robots: 0.6.11-0 → 0.7.0-1
- ros-kinetic-cob-safety-controller: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-scan-unifier: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-script-server: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-sick-lms1xx: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-sick-s300: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-simulation: 0.6.10-0 → 0.7.1-1
- ros-kinetic-cob-sound: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-srvs: 0.6.12-1 → 0.7.0-1
- ros-kinetic-cob-substitute: 0.6.7-0 → 0.6.8-1
- ros-kinetic-cob-supported-robots: 0.6.11-0 → 0.6.12-1
- ros-kinetic-cob-teleop: 0.6.12-1 → 0.6.14-1
- ros-kinetic-cob-trajectory-controller: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-tricycle-controller: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-twist-controller: 0.7.6-1 → 0.7.7-1
- ros-kinetic-cob-undercarriage-ctrl: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-utilities: 0.6.14-1 → 0.7.0-1
- ros-kinetic-cob-vision-utils: 0.6.13-0 → 0.6.14-1
- ros-kinetic-cob-voltage-control: 0.6.14-1 → 0.7.0-1
- ros-kinetic-generic-throttle: 0.6.12-1 → 0.6.14-1
- ros-kinetic-h264-encoder-core: 2.0.0-1 → 2.0.1-1
- ros-kinetic-h264-video-encoder: 1.1.2-1 → 1.1.3-1
- ros-kinetic-health-metric-collector: 2.0.0-1 → 2.0.1-1
- ros-kinetic-husky-base: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-bringup: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-control: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-description: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-desktop: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-gazebo: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-msgs: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-navigation: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-robot: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-simulator: 0.3.3-0 → 0.3.4-1
- ros-kinetic-husky-viz: 0.3.3-0 → 0.3.4-1
- ros-kinetic-ipa-3d-fov-visualization: 0.6.13-0 → 0.6.14-1
- ros-kinetic-jderobot-assets: 0.0.1-1 → 0.0.2-1
- ros-kinetic-kinesis-video-msgs: 2.0.1-0 → 2.0.2-1
- ros-kinetic-kinesis-video-streamer: 2.0.1-0 → 2.0.2-1
- ros-kinetic-laser-scan-densifier: 0.6.14-1 → 0.7.0-1
- ros-kinetic-lex-common-msgs: 2.0.0-1 → 2.0.1-1
- ros-kinetic-lex-node: 2.0.0-1 → 2.0.1-1
- ros-kinetic-libdlib: 0.6.12-0 → 0.6.13-1
- ros-kinetic-libntcan: 0.6.12-0 → 0.6.13-1
- ros-kinetic-libpcan: 0.6.12-0 → 0.6.13-1
- ros-kinetic-libphidgets: 0.6.12-0 → 0.6.13-1
- ros-kinetic-opengm: 0.6.12-0 → 0.6.13-1
- ros-kinetic-raw-description: 0.6.12-1 → 0.7.0-1
- ros-kinetic-rc-genicam-api: 2.2.0-1 → 2.2.2-1
- ros-kinetic-ros-monitoring-msgs: 1.0.0-3 → 1.0.1-1
- ros-kinetic-rtabmap: 0.17.6-0 → 0.19.3-1
- ros-kinetic-rtabmap-ros: 0.17.6-0 → 0.19.3-1
- ros-kinetic-service-tools: 0.6.12-1 → 0.6.14-1
- ros-kinetic-toposens: 1.2.1-1 → 1.2.2-1
- ros-kinetic-toposens-description: 1.2.1-1 → 1.2.2-1
- ros-kinetic-toposens-driver: 1.2.1-1 → 1.2.2-1
- ros-kinetic-toposens-markers: 1.2.1-1 → 1.2.2-1
- ros-kinetic-toposens-msgs: 1.2.1-1 → 1.2.2-1
- ros-kinetic-toposens-pointcloud: 1.2.1-1 → 1.2.2-1
- ros-kinetic-toposens-sync: 1.2.1-1 → 1.2.2-1
- ros-kinetic-tts: 1.0.1-0 → 1.0.2-1
Removed Packages [0]:
- AWS RoboMaker
- Adi Singh
- Alexander Bubeck
- Benjamin Maidel
- Brian Bingham
- Fabrice Poirier
- Felipe Garcia Lopez
- Felix Messmer
- Felix Ruess
- Felix Zeltner
- Florenz Graf
- Florian Weisshardt
- Jannik Abbenseth
- Jeremie Deray
- Joshua Hampp
- Mathieu Labbe
- Matthias Gruhler
- Nikhil Khedekar
- Paul Bovbel
- Richard Bormann
- Sean Hackett
- Tony Baltovski
- Yasuto Shiigi
