We have 34 new packages and 54 updated packages for Kinetic. We’re now over 2000 packages released into Kinetic!
Thank you to all the contributors and maintainers who have helped make this sync happen!
Full details are below:
Package Updates for kinetic
Added Packages [34]:
- ros-kinetic-addwa-local-planner: 0.0.12-0
- ros-kinetic-dataspeed-can: 1.0.10-0
- ros-kinetic-dataspeed-can-msg-filters: 1.0.10-0
- ros-kinetic-dataspeed-can-tools: 1.0.10-0
- ros-kinetic-dataspeed-can-usb: 1.0.10-0
- ros-kinetic-dbw-mkz: 1.0.13-0
- ros-kinetic-dbw-mkz-can: 1.0.13-0
- ros-kinetic-dbw-mkz-description: 1.0.13-0
- ros-kinetic-dbw-mkz-joystick-demo: 1.0.13-0
- ros-kinetic-dbw-mkz-msgs: 1.0.13-0
- ros-kinetic-dbw-mkz-twist-controller: 1.0.13-0
- ros-kinetic-grizzly-desktop: 0.3.2-0
- ros-kinetic-grizzly-gazebo: 0.3.1-0
- ros-kinetic-grizzly-simulator: 0.3.1-0
- ros-kinetic-grizzly-viz: 0.3.2-0
- ros-kinetic-lusb: 1.0.10-0
- ros-kinetic-mcl-3dl-msgs: 0.1.2-0
- ros-kinetic-mrpt-bridge: 0.1.24-0
- ros-kinetic-mrpt-ekf-slam-2d: 0.1.6-0
- ros-kinetic-mrpt-ekf-slam-3d: 0.1.6-0
- ros-kinetic-mrpt-icp-slam-2d: 0.1.6-0
- ros-kinetic-mrpt-local-obstacles: 0.1.23-0
- ros-kinetic-mrpt-localization: 0.1.23-0
- ros-kinetic-mrpt-map: 0.1.23-0
- ros-kinetic-mrpt-msgs: 0.1.23-0
- ros-kinetic-mrpt-navigation: 0.1.23-0
- ros-kinetic-mrpt-rawlog: 0.1.23-0
- ros-kinetic-mrpt-reactivenav2d: 0.1.23-0
- ros-kinetic-mrpt-tutorials: 0.1.23-0
- ros-kinetic-mrpt1: 1.5.7-4
- ros-kinetic-pose-cov-ops: 0.2.0-0
- ros-kinetic-rc-cloud-accumulator: 1.0.0-0
- ros-kinetic-xiaoqiang-depth-image-proc: 0.0.12-0
- ros-kinetic-xiaoqiang-navigation-example: 0.0.12-0
Updated Packages [54]:
- ros-kinetic-amcl: 1.14.3-0 → 1.14.4-0
- ros-kinetic-base-local-planner: 1.14.3-0 → 1.14.4-0
- ros-kinetic-carrot-planner: 1.14.3-0 → 1.14.4-0
- ros-kinetic-clear-costmap-recovery: 1.14.3-0 → 1.14.4-0
- ros-kinetic-costmap-2d: 1.14.3-0 → 1.14.4-0
- ros-kinetic-criutils: 0.1.1-0 → 0.1.3-0
- ros-kinetic-dwa-local-planner: 1.14.3-0 → 1.14.4-0
- ros-kinetic-fake-localization: 1.14.3-0 → 1.14.4-0
- ros-kinetic-gazebo-dev: 2.5.14-1 → 2.5.17-0
- ros-kinetic-gazebo-msgs: 2.5.14-1 → 2.5.17-0
- ros-kinetic-gazebo-plugins: 2.5.14-1 → 2.5.17-0
- ros-kinetic-gazebo-ros: 2.5.14-1 → 2.5.17-0
- ros-kinetic-gazebo-ros-control: 2.5.14-1 → 2.5.17-0
- ros-kinetic-gazebo-ros-pkgs: 2.5.14-1 → 2.5.17-0
- ros-kinetic-global-planner: 1.14.3-0 → 1.14.4-0
- ros-kinetic-handeye: 0.1.0-0 → 0.1.1-0
- ros-kinetic-indoor-positioning: 1.0.2-0 → 1.0.3-0
- ros-kinetic-joy: 1.11.0-0 → 1.12.0-0
- ros-kinetic-joystick-drivers: 1.11.0-0 → 1.12.0-0
- ros-kinetic-map-server: 1.14.3-0 → 1.14.4-0
- ros-kinetic-move-base: 1.14.3-0 → 1.14.4-0
- ros-kinetic-move-slow-and-clear: 1.14.3-0 → 1.14.4-0
- ros-kinetic-nav-core: 1.14.3-0 → 1.14.4-0
- ros-kinetic-navfn: 1.14.3-0 → 1.14.4-0
- ros-kinetic-navigation: 1.14.3-0 → 1.14.4-0
- ros-kinetic-nerian-stereo: 2.2.0-0 → 3.0.0-0
- ros-kinetic-ps3joy: 1.11.0-0 → 1.12.0-0
- ros-kinetic-rdl: 0.9.5-0 → 0.10.6-1
- ros-kinetic-rdl-benchmark: 0.9.5-0 → 0.10.6-1
- ros-kinetic-rdl-cmake: 0.9.5-0 → 0.10.6-1
- ros-kinetic-rdl-dynamics: 0.9.5-0 → 0.10.6-1
- ros-kinetic-rdl-urdfreader: 0.9.5-0 → 0.10.6-1
- ros-kinetic-robot-pose-ekf: 1.14.3-0 → 1.14.4-0
- ros-kinetic-rotate-recovery: 1.14.3-0 → 1.14.4-0
- ros-kinetic-rqt-joint-trajectory-plot: 0.0.1-0 → 0.0.2-0
- ros-kinetic-spacenav-node: 1.11.0-0 → 1.12.0-0
- ros-kinetic-teb-local-planner: 0.6.8-0 → 0.6.9-0
- ros-kinetic-teb-local-planner-tutorials: 0.2.1-0 → 0.2.2-0
- ros-kinetic-video-stream-opencv: 1.1.1-0 → 1.1.2-0
- ros-kinetic-voxel-grid: 1.14.3-0 → 1.14.4-0
- ros-kinetic-wiimote: 1.11.0-0 → 1.12.0-0
- ros-kinetic-xiaoqiang: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-bringup: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-controller: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-description: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-driver: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-freenect: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-freenect-camera: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-freenect-launch: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-monitor: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-msgs: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-navigation: 0.0.7-0 → 0.0.12-0
- ros-kinetic-xiaoqiang-server: 0.0.7-0 → 0.0.12-0
- ros-kinetic-ypspur-ros: 0.1.0-0 → 0.2.0-0
Removed Packages [0]:
- Atsushi Watanabe
- Christian Arndt
- Christoph Rösmann
- David V. Lu!!
- Felix Endres
- Francisco Suarez-Ruiz
- John Hsu
- Jonathan Bohren
- Jose Luis
- Jose Luis Blanco Claraco
- Jose Luis Rivero
- Jose-Luis Blanco-Claraco
- Kevin Hallenbeck
- Konstantin Schauwecker
- Markus Bader
- Micho Radovnikovich
- Randoms
- Sammy Pfeiffer
- Tokyo Opensource Robotics Kyokai (TORK) Developer Team
- Tony Baltovski
- Xie fusheng
- jordan
