New Packages for Indigo and Kinetic 2016-08-04
HI Everyone,
We have synced both indigo and kinetic packages. We have 51 and 91 new packages in indigo and kinetic respectively. As well as 134 and 26 updates.
This brings our new total of packages to 2273 and 780 for those two distros. Indigo is still our largest, and kinetic is our newest distro and is growing the most rapidly.
Please remember to thank the many maintainers and contributors who help make these packages available to the community. The releasing maintainers for this sync are listed below with the details of the new and updated packages.
– You’re ROS Release Team
Updates to indigo
Added Packages [51]:
  • ros-indigo-declination: 0.0.2-0
  • ros-indigo-enu: 1.2.2-0
  • ros-indigo-freight-calibration: 0.7.9-0
  • ros-indigo-heron-description: 0.2.2-0
  • ros-indigo-heron-msgs: 0.2.2-0
  • ros-indigo-image-publisher: 1.12.19-0
  • ros-indigo-motoman: 0.3.5-0
  • ros-indigo-motoman-driver: 0.3.5-0
  • ros-indigo-motoman-mh5-support: 0.3.5-0
  • ros-indigo-motoman-msgs: 0.3.5-0
  • ros-indigo-motoman-sda10f-moveit-config: 0.3.5-0
  • ros-indigo-motoman-sda10f-support: 0.3.5-0
  • ros-indigo-motoman-sia10d-support: 0.3.5-0
  • ros-indigo-motoman-sia10f-support: 0.3.5-0
  • ros-indigo-motoman-sia20d-moveit-config: 0.3.5-0
  • ros-indigo-motoman-sia20d-support: 0.3.5-0
  • ros-indigo-motoman-sia5d-support: 0.3.5-0
  • ros-indigo-nav-pcontroller: 0.1.2-0
  • ros-indigo-pepper-control: 0.0.2-3
  • ros-indigo-pepper-gazebo-plugin: 0.0.2-3
  • ros-indigo-rb1-base-2dnav: 1.0.1-0
  • ros-indigo-rb1-base-common: 1.0.3-0
  • ros-indigo-rb1-base-control: 1.0.1-0
  • ros-indigo-rb1-base-description: 1.0.3-0
  • ros-indigo-rb1-base-gazebo: 1.0.1-0
  • ros-indigo-rb1-base-pad: 1.0.3-0
  • ros-indigo-rb1-base-purepursuit: 1.0.1-0
  • ros-indigo-rb1-base-sim: 1.0.1-0
  • ros-indigo-rbcar-common: 1.0.4-0
  • ros-indigo-rbcar-control: 1.0.2-0
  • ros-indigo-rbcar-description: 1.0.4-0
  • ros-indigo-rbcar-gazebo: 1.0.2-0
  • ros-indigo-rbcar-joystick: 1.0.2-0
  • ros-indigo-rbcar-pad: 1.0.4-0
  • ros-indigo-rbcar-robot-control: 1.0.2-0
  • ros-indigo-rbcar-sim: 1.0.2-0
  • ros-indigo-rbcar-sim-bringup: 1.0.2-0
  • ros-indigo-romeo-control: 0.2.2-0
  • ros-indigo-romeo-gazebo-plugin: 0.2.2-0
  • ros-indigo-rosserial-leonardo-cmake: 0.1.3-0
  • ros-indigo-rqt-stream-manipulator-3d: 0.1.6-0
  • ros-indigo-sick-3vistort-driver: 0.0.1-0
  • ros-indigo-stream-manipulator-3d: 0.1.6-0
  • ros-indigo-summit-x-common: 0.0.1-0
  • ros-indigo-summit-x-control: 1.0.5-0
  • ros-indigo-summit-x-description: 0.0.1-0
  • ros-indigo-summit-x-gazebo: 1.0.5-0
  • ros-indigo-summit-x-robot-control: 1.0.5-0
  • ros-indigo-summit-x-sim: 1.0.5-0
  • ros-indigo-summit-xl-sim: 1.0.6-0
  • ros-indigo-summit-xl-sim-bringup: 1.0.6-0
Updated Packages [134]:
  • ros-indigo-agvs-common: 0.1.1-0 → 0.1.2-0
  • ros-indigo-agvs-description: 0.1.1-0 → 0.1.2-0
  • ros-indigo-agvs-pad: 0.1.1-0 → 0.1.2-0
  • ros-indigo-apriltags: 0.1.1-0 → 0.1.2-2
  • ros-indigo-apriltags-ros: 0.1.1-0 → 0.1.2-2
  • ros-indigo-camera-calibration: 1.12.16-0 → 1.12.19-0
  • ros-indigo-cv-bridge: 1.11.12-0 → 1.11.13-0
  • ros-indigo-depth-image-proc: 1.12.16-0 → 1.12.19-0
  • ros-indigo-dynamic-tf-publisher: 2.0.16-1 → 2.0.17-0
  • ros-indigo-euslisp: 9.19.0-0 → 9.20.0-0
  • ros-indigo-fcl: 0.3.2-0 → 0.3.3-0
  • ros-indigo-fetch-calibration: 0.7.7-0 → 0.7.9-0
  • ros-indigo-fetch-depth-layer: 0.7.7-0 → 0.7.9-0
  • ros-indigo-fetch-description: 0.7.7-0 → 0.7.9-0
  • ros-indigo-fetch-maps: 0.7.7-0 → 0.7.9-0
  • ros-indigo-fetch-moveit-config: 0.7.7-0 → 0.7.9-0
  • ros-indigo-fetch-navigation: 0.7.7-0 → 0.7.9-0
  • ros-indigo-fetch-teleop: 0.7.7-0 → 0.7.9-0
  • ros-indigo-gazebo-msgs: 2.4.10-0 → 2.4.11-0
  • ros-indigo-gazebo-plugins: 2.4.10-0 → 2.4.11-0
  • ros-indigo-gazebo-ros: 2.4.10-0 → 2.4.11-0
  • ros-indigo-gazebo-ros-control: 2.4.10-0 → 2.4.11-0
  • ros-indigo-gazebo-ros-pkgs: 2.4.10-0 → 2.4.11-0
  • ros-indigo-hironx-calibration: 1.1.15-0 → 1.1.16-0
  • ros-indigo-hironx-moveit-config: 1.1.15-0 → 1.1.16-0
  • ros-indigo-hironx-ros-bridge: 1.1.15-0 → 1.1.16-0
  • ros-indigo-household-objects-database-msgs: 0.1.1-2 → 0.1.2-0
  • ros-indigo-image-geometry: 1.11.12-0 → 1.11.13-0
  • ros-indigo-image-pipeline: 1.12.16-0 → 1.12.19-0
  • ros-indigo-image-proc: 1.12.16-0 → 1.12.19-0
  • ros-indigo-image-rotate: 1.12.16-0 → 1.12.19-0
  • ros-indigo-image-view: 1.12.16-0 → 1.12.19-0
  • ros-indigo-image-view2: 2.0.16-1 → 2.0.17-0
  • ros-indigo-joy-teleop: 0.2.2-0 → 0.2.3-0
  • ros-indigo-jsk-2015-05-baxter-apc: 0.8.1-0 → 1.5.1-0
  • ros-indigo-jsk-apc2015-common: 0.8.1-0 → 1.5.1-0
  • ros-indigo-jsk-common: 2.0.16-1 → 2.0.17-0
  • ros-indigo-jsk-data: 2.0.16-1 → 2.0.17-0
  • ros-indigo-jsk-interactive: 1.0.31-0 → 1.0.32-0
  • ros-indigo-jsk-interactive-marker: 1.0.31-0 → 1.0.32-0
  • ros-indigo-jsk-interactive-test: 1.0.31-0 → 1.0.32-0
  • ros-indigo-jsk-network-tools: 2.0.16-1 → 2.0.17-0
  • ros-indigo-jsk-rqt-plugins: 1.0.31-0 → 1.0.32-0
  • ros-indigo-jsk-rviz-plugins: 1.0.31-0 → 1.0.32-0
  • ros-indigo-jsk-tilt-laser: 2.0.16-1 → 2.0.17-0
  • ros-indigo-jsk-tools: 2.0.16-1 → 2.0.17-0
  • ros-indigo-jsk-topic-tools: 2.0.16-1 → 2.0.17-0
  • ros-indigo-jsk-visualization: 1.0.31-0 → 1.0.32-0
  • ros-indigo-jskeus: 1.0.12-0 → 1.0.13-1
  • ros-indigo-key-teleop: 0.2.2-0 → 0.2.3-0
  • ros-indigo-laser-filtering: 0.0.2-0 → 0.0.4-0
  • ros-indigo-librealsense: 0.9.2-1 → 0.9.2-3
  • ros-indigo-map-laser: 0.0.2-0 → 0.0.4-0
  • ros-indigo-micros-swarm-framework: 0.0.8-0 → 0.0.12-1
  • ros-indigo-mouse-teleop: 0.2.2-0 → 0.2.3-0
  • ros-indigo-multi-map-server: 2.0.16-1 → 2.0.17-0
  • ros-indigo-nextage-description: 0.7.7-0 → 0.7.8-0
  • ros-indigo-nextage-gazebo: 0.7.7-0 → 0.7.8-0
  • ros-indigo-nextage-ik-plugin: 0.7.7-0 → 0.7.8-0
  • ros-indigo-nextage-moveit-config: 0.7.7-0 → 0.7.8-0
  • ros-indigo-nextage-ros-bridge: 0.7.7-0 → 0.7.8-0
  • ros-indigo-parrot-arsdk: 3.9.1-3 → 3.9.1-6
  • ros-indigo-pepper-moveit-config: 0.0.4-0 → 0.0.4-1
  • ros-indigo-razor-imu-9dof: 1.1.0-1 → 1.1.1-0
  • ros-indigo-realsense-camera: 1.2.0-0 → 1.3.0-0
  • ros-indigo-resource-retriever: 1.11.6-0 → 1.11.7-1
  • ros-indigo-ridgeback-control: 0.1.6-0 → 0.1.7-0
  • ros-indigo-ridgeback-description: 0.1.6-0 → 0.1.7-0
  • ros-indigo-ridgeback-msgs: 0.1.6-0 → 0.1.7-0
  • ros-indigo-ridgeback-navigation: 0.1.6-0 → 0.1.7-0
  • ros-indigo-robot-calibration: 0.5.2-0 → 0.5.3-0
  • ros-indigo-robot-calibration-msgs: 0.5.2-0 → 0.5.3-0
  • ros-indigo-robot-controllers: 0.5.0-0 → 0.5.2-0
  • ros-indigo-robot-controllers-interface: 0.5.0-0 → 0.5.2-0
  • ros-indigo-robot-controllers-msgs: 0.5.0-0 → 0.5.2-0
  • ros-indigo-robot-localization: 2.2.3-1 → 2.3.0-0
  • ros-indigo-romeo-moveit-config: 0.2.6-0 → 0.2.7-0
  • ros-indigo-rtabmap: 0.11.7-1 → 0.11.8-0
  • ros-indigo-rtabmap-ros: 0.11.7-2 → 0.11.8-0
  • ros-indigo-rtmros-hironx: 1.1.15-0 → 1.1.16-0
  • ros-indigo-rtmros-nextage: 0.7.7-0 → 0.7.8-0
  • ros-indigo-rtt-actionlib: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-actionlib-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-common-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-diagnostic-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-dynamic-reconfigure: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-geometry-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-kdl-conversions: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-nav-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-ros: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-ros-comm: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-ros-integration: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-ros-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-rosclock: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-roscomm: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-rosdeployment: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-rosgraph-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-rosnode: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-rospack: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-rosparam: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-sensor-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-shape-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-std-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-std-srvs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-stereo-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-tf: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-trajectory-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rtt-visualization-msgs: 2.8.2-0 → 2.8.3-0
  • ros-indigo-rviz-visual-tools: 2.1.0-0 → 2.2.1-1
  • ros-indigo-srdfdom: 0.3.0-0 → 0.3.1-0
  • ros-indigo-stdr-gui: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-launchers: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-msgs: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-parser: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-resources: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-robot: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-samples: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-server: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stdr-simulator: 0.2.0-0 → 0.3.1-0
  • ros-indigo-stereo-image-proc: 1.12.16-0 → 1.12.19-0
  • ros-indigo-summit-xl-common: 1.0.4-0 → 1.0.5-0
  • ros-indigo-summit-xl-control: 1.0.5-0 → 1.0.6-0
  • ros-indigo-summit-xl-description: 1.0.4-0 → 1.0.5-0
  • ros-indigo-summit-xl-gazebo: 1.0.5-0 → 1.0.6-0
  • ros-indigo-summit-xl-localization: 1.0.4-0 → 1.0.5-0
  • ros-indigo-summit-xl-navigation: 1.0.4-0 → 1.0.5-0
  • ros-indigo-summit-xl-pad: 1.0.4-0 → 1.0.5-0
  • ros-indigo-summit-xl-robot-control: 1.0.5-0 → 1.0.6-0
  • ros-indigo-teleop-tools: 0.2.2-0 → 0.2.3-0
  • ros-indigo-teleop-tools-msgs: 0.2.2-0 → 0.2.3-0
  • ros-indigo-ueye: 0.0.9-0 → 0.0.10-0
  • ros-indigo-virtual-force-publisher: 2.0.16-1 → 2.0.17-0
  • ros-indigo-vision-opencv: 1.11.12-0 → 1.11.13-0
  • ros-indigo-xsens-driver: 1.0.3-0 → 2.0.0-0
Removed Packages [0]:
  • Bence Magyar
  • Carlos Villar
  • Chris Zalidis
  • Dave Coleman
  • David V. Lu!!
  • Elena Gambaro
  • Enrique Fernandez
  • Francis Colas
  • Ha Dang
  • IK Fast Plugin Creater
  • Ioan Sucan
  • Isaac Isao Saito
  • Jan Winkler
  • Jeremy Zoss (Southwest Research Institute)
  • John Hsu
  • Jonathan Bohren
  • Joshua Hampp
  • Kei Okada
  • Kentaro Wada
  • Kevin Hallenbeck
  • Kristof Robot
  • Mani Monajjemi
  • Matei Ciocarlie
  • Mathieu Labbe
  • Michael Ferguson
  • Mike Purvis
  • Mitchell Wills
  • MoveIt Setup Assistant
  • Natalia Lyubova
  • Orocos Developers
  • Rajvi Jingar
  • Roberto Guzmán
  • Román Navarro
  • Ryohei Ueda
  • Sergey Dorodnicov
  • Shaun Edwards
  • TORK
  • Tabjones
  • Thiago de Freitas
  • Tom Moore
  • Vincent Rabaud
  • Xuefeng Chang
  • YoheiKakiuchi
  • Yusuke Furuta
  • furuta
  • tabjones
updates to kinetic
Added Packages [91]:
  • ros-kinetic-agvs-common: 0.1.3-1
  • ros-kinetic-agvs-control: 0.1.2-0
  • ros-kinetic-agvs-description: 0.1.3-1
  • ros-kinetic-agvs-pad: 0.1.3-1
  • ros-kinetic-agvs-robot-control: 0.1.2-0
  • ros-kinetic-agvs-sim-bringup: 0.1.2-0
  • ros-kinetic-easy-markers: 0.2.4-0
  • ros-kinetic-face-detector: 1.0.10-0
  • ros-kinetic-household-objects-database-msgs: 0.1.2-0
  • ros-kinetic-image-publisher: 1.12.19-0
  • ros-kinetic-joy-listener: 0.2.4-0
  • ros-kinetic-joy-teleop: 0.2.3-0
  • ros-kinetic-kalman-filter: 0.2.4-0
  • ros-kinetic-key-teleop: 0.2.3-0
  • ros-kinetic-laser-filtering: 0.0.4-0
  • ros-kinetic-manipulation-msgs: 0.2.1-0
  • ros-kinetic-map-laser: 0.0.4-0
  • ros-kinetic-marker-msgs: 0.0.2-0
  • ros-kinetic-mouse-teleop: 0.2.3-0
  • ros-kinetic-nav-pcontroller: 0.1.2-0
  • ros-kinetic-octomap-rviz-plugins: 0.2.0-0
  • ros-kinetic-people-msgs: 1.0.10-0
  • ros-kinetic-people-tracking-filter: 1.0.10-0
  • ros-kinetic-rb1-base-2dnav: 1.0.2-0
  • ros-kinetic-rb1-base-common: 1.0.5-0
  • ros-kinetic-rb1-base-control: 1.0.2-0
  • ros-kinetic-rb1-base-description: 1.0.5-0
  • ros-kinetic-rb1-base-gazebo: 1.0.2-0
  • ros-kinetic-rb1-base-pad: 1.0.5-0
  • ros-kinetic-rb1-base-purepursuit: 1.0.2-0
  • ros-kinetic-rb1-base-sim: 1.0.2-0
  • ros-kinetic-rbcar-common: 1.0.5-0
  • ros-kinetic-rbcar-control: 1.0.4-0
  • ros-kinetic-rbcar-description: 1.0.5-0
  • ros-kinetic-rbcar-gazebo: 1.0.4-0
  • ros-kinetic-rbcar-joystick: 1.0.4-0
  • ros-kinetic-rbcar-pad: 1.0.5-0
  • ros-kinetic-rbcar-robot-control: 1.0.4-0
  • ros-kinetic-rbcar-sim: 1.0.4-0
  • ros-kinetic-rbcar-sim-bringup: 1.0.4-0
  • ros-kinetic-robotnik-msgs: 0.2.1-0
  • ros-kinetic-robotnik-sensors: 1.0.2-0
  • ros-kinetic-ros-emacs-utils: 0.4.9-0
  • ros-kinetic-rosbaglive: 0.2.4-0
  • ros-kinetic-rosemacs: 0.4.9-0
  • ros-kinetic-roslisp-repl: 0.4.9-0
  • ros-kinetic-rosserial: 0.7.2-0
  • ros-kinetic-rosserial-arduino: 0.7.2-0
  • ros-kinetic-rosserial-client: 0.7.2-0
  • ros-kinetic-rosserial-embeddedlinux: 0.7.2-0
  • ros-kinetic-rosserial-mbed: 0.7.2-0
  • ros-kinetic-rosserial-msgs: 0.7.2-0
  • ros-kinetic-rosserial-python: 0.7.2-0
  • ros-kinetic-rosserial-server: 0.7.2-0
  • ros-kinetic-rosserial-tivac: 0.7.2-0
  • ros-kinetic-rosserial-windows: 0.7.2-0
  • ros-kinetic-rosserial-xbee: 0.7.2-0
  • ros-kinetic-slime-ros: 0.4.9-0
  • ros-kinetic-slime-wrapper: 0.4.9-0
  • ros-kinetic-srdfdom: 0.3.1-0
  • ros-kinetic-stdr-gui: 0.3.1-0
  • ros-kinetic-stdr-launchers: 0.3.1-0
  • ros-kinetic-stdr-msgs: 0.3.1-0
  • ros-kinetic-stdr-parser: 0.3.1-0
  • ros-kinetic-stdr-resources: 0.3.1-0
  • ros-kinetic-stdr-robot: 0.3.1-0
  • ros-kinetic-stdr-samples: 0.3.1-0
  • ros-kinetic-stdr-server: 0.3.1-0
  • ros-kinetic-stdr-simulator: 0.3.1-0
  • ros-kinetic-summit-x-common: 0.0.2-0
  • ros-kinetic-summit-x-control: 1.0.6-0
  • ros-kinetic-summit-x-description: 0.0.2-0
  • ros-kinetic-summit-x-gazebo: 1.0.6-0
  • ros-kinetic-summit-x-robot-control: 1.0.6-0
  • ros-kinetic-summit-x-sim: 1.0.6-0
  • ros-kinetic-summit-xl-common: 1.0.8-0
  • ros-kinetic-summit-xl-control: 1.0.9-0
  • ros-kinetic-summit-xl-description: 1.0.8-0
  • ros-kinetic-summit-xl-gazebo: 1.0.9-0
  • ros-kinetic-summit-xl-localization: 1.0.8-0
  • ros-kinetic-summit-xl-navigation: 1.0.8-0
  • ros-kinetic-summit-xl-pad: 1.0.8-0
  • ros-kinetic-summit-xl-robot-control: 1.0.9-0
  • ros-kinetic-summit-xl-sim: 1.0.9-0
  • ros-kinetic-summit-xl-sim-bringup: 1.0.9-0
  • ros-kinetic-teleop-tools: 0.2.3-0
  • ros-kinetic-teleop-tools-msgs: 0.2.3-0
  • ros-kinetic-twist-mux: 3.0.0-0
  • ros-kinetic-twist-mux-msgs: 2.0.0-0
  • ros-kinetic-wu-ros-tools: 0.2.4-0
  • ros-kinetic-xsens-driver: 2.0.0-0
Updated Packages [26]:
  • ros-kinetic-actionlib: 1.11.5-0 → 1.11.6-0
  • ros-kinetic-camera-calibration: 1.12.16-0 → 1.12.19-0
  • ros-kinetic-class-loader: 0.3.3-0 → 0.3.4-0
  • ros-kinetic-cv-bridge: 1.12.0-1 → 1.12.1-0
  • ros-kinetic-depth-image-proc: 1.12.16-0 → 1.12.19-0
  • ros-kinetic-euslisp: 9.19.0-0 → 9.20.0-0
  • ros-kinetic-image-geometry: 1.12.0-1 → 1.12.1-0
  • ros-kinetic-image-pipeline: 1.12.16-0 → 1.12.19-0
  • ros-kinetic-image-proc: 1.12.16-0 → 1.12.19-0
  • ros-kinetic-image-rotate: 1.12.16-0 → 1.12.19-0
  • ros-kinetic-image-view: 1.12.16-0 → 1.12.19-0
  • ros-kinetic-jskeus: 1.0.12-0 → 1.0.13-1
  • ros-kinetic-librealsense: 0.9.2-1 → 0.9.2-3
  • ros-kinetic-mavlink: 2016.7.7-0 → 2016.8.2-1
  • ros-kinetic-opencv3: 3.1.0-14 → 3.1.0-16
  • ros-kinetic-parrot-arsdk: 3.9.1-0 → 3.9.1-3
  • ros-kinetic-pluginlib: 1.10.2-0 → 1.10.3-0
  • ros-kinetic-realsense-camera: 1.2.0-0 → 1.3.0-0
  • ros-kinetic-robot-localization: 2.2.3-0 → 2.3.0-0
  • ros-kinetic-rtabmap: 0.11.7-0 → 0.11.8-0
  • ros-kinetic-rtabmap-ros: 0.11.7-1 → 0.11.8-0
  • ros-kinetic-rviz-visual-tools: 3.1.0-0 → 3.2.0-0
  • ros-kinetic-stereo-image-proc: 1.12.16-0 → 1.12.19-0
  • ros-kinetic-ueye: 0.0.9-0 → 0.0.10-0
  • ros-kinetic-vision-opencv: 1.12.0-1 → 1.12.1-0
  • ros-kinetic-xacro: 1.11.0-0 → 1.11.1-0
  • Armin Hornung
  • Bence Magyar
  • Carlos Villar
  • Chris Zalidis
  • Dan Lazewatsky
  • Dave Coleman
  • David V. Lu!!
  • Elena Gambaro
  • Enrique Fernandez
  • Francis Colas
  • Gary Servin
  • Gayane Kazhoyan
  • Ioan Sucan
  • Jan Winkler
  • Jon Binney
  • Kareem Shehata
  • Kei Okada
  • Kevin Hallenbeck
  • Mani Monajjemi
  • Markus Bader
  • Matei Ciocarlie
  • Mathieu Labbe
  • Mikael Arguedas
  • Mike Purvis
  • Morgan Quigley
  • Paul Bouchier
  • Rajvi Jingar
  • Roberto Guzmán
  • Román Navarro
  • Sergey Dorodnicov
  • Tom Moore
  • Vincent Rabaud
  • Vitor Matos
  • Vladimir Ermakov
