Hello,
Trying to build a docker with ROS in it I’m finding that some packages are failing to download:
The suspects are:
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-kinetic-moveit-core/ros-kinetic-moveit-core_0.9.11-0xenial-20180423-163839-0800_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-kinetic-object-recognition-ros/ros-kinetic-object-recognition-ros_0.3.7-0xenial-20180423-164053-0800_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-kinetic-object-recognition-ros-visualization/ros-kinetic-object-recognition-ros-visualization_0.3.8-0xenial-20180423-165415-0800_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
In the docker, just previously, a sudo apt-get update is ran… so I don’t think it’s me.
Full output: log error apt-get install kinetic · GitHub
