I have talked with a handful of folks about timing of the next MoveIt Community meeting. Let’s meet 2025-12-18T15:00:00Z using https://meet.google.com/nex-amje-mzp
Agenda
Updates on expansion of people with availability to help with releases
Review remaining work on Jazzy and Rolling compatibility
Discussion about revising our Rolling deprecation check strategy
Reply here or email me (nathan@picknik.ai) with additional topics!
@nathanbrooks For posterity and related to the discussion of how best to support multiple distros in the same branch (read: depend on different packages [or versions of packages] depending on ROS distro used, the rough equivalent of doing this but in CMakelists/package.xml), the ROSCon lightning talk I mentioned was this one. So in short, to not depend on the ROS_DISTRO env variable but instead on the version of the package you found.
As an aside I also mentioned catkin_lint as a means of enforcing in CI that there is no discrepancy between packages that are find_packageed in CMakelists.txt vs declared as dependencies in package.xml. But I’m not aware of a ROS 2 equivalent.
