Micro-ROS telemetry: what a 100 Hz target does—and doesn’t—prove
A nominal 100 Hz timer doesn’t prove deterministic end-to-end delivery, especially over Wi-Fi. Measure jitter, dropped messages and Agent outages on your actual hardware. RoboTech Journal’s ESP32-S3/STM32 example is illustrative and untested; the guide explains the reference setup and caveats: micro-ROS on ESP32 and STM32: Telemetry Guide | RoboTechJournal
What measurements do you use to validate the full path from MCU to ROS 2 host?
sequence number + MCU timestamp in the message, then check gaps and arrival jitter on the host. that catches drops the timer rate alone hides.
on the host side you can also see what actually arrives without adding a subscriber. ros2_pulse (GitHub - TanayK07/ros2_pulse: ros2 topic hz for every topic at once, without subscribing. Rates, gaps and node liveness, intra-process included, on stock ROS 2 binaries. · GitHub) is an ld_preload library that counts callbacks per topic inside the receiving node, so a 100 hz target that lands at 87 hz shows up per window. it can’t see the mcu or the agent, so pair it with the sequence numbers above to tell link drops from host drops.
