Hi All!
I wanted to share an update on my Roboost project here as well! What I’m trying to do is make a simple framework based on ESP32 and micro-ROS. The benefit would be that no board computer is needed and the system can be adapted for different types of robots.
Here is the link to a project post/summary about the latest addition, I’d be really happy if you could check it out and share your thoughts and suggestions!
https://technologiehub.at/project-posts/roboost-primary-motor-cortex/
You can also directly check out the GitHub Repo, note that is still a work in progress though ![]()
And here is a little video on how the project is used (for amusement) to clean my apartment:
