The next Manipulation WG meeting is scheduled for Friday 31st of May, 17:00 CET (9AM PDT, 1AM JST). Please join the meeting via the following link:
Real-time meetings by Google. Using your browser, share your video, desktop, and presentations with teammates and customers.
Agenda will be posted in the following days. Feel free to suggest any topic if you’re interested in participating.
Here’s an update about the proposed agenda. Feel free to suggest any topics if you plan on participating and we’ll try to include it in:
For those of you that can’t joint but are interested in the progress, we will be publishing the minutes shortly after the meeting.
Here’re the meeting notes of the last session:
May 31, 2019 17:00 CET (9AM PDT, 1AM JST) - ROS 2 Manipulation WG Meeting minutes
Attendees:
Alejandro Hernández
Anas Mchichou El Harrak
Lander Usategui
Henning Kaiser
Dave Coleman
Mike Lautman
Discussion:
MoveIt 2, status of the port
GitHub - AcutronicRobotics/moveit2: The MoveIt 2 Motion Planning Framework for ROS 2.0
The Master branch has to be always compilable
No accepting PRs until the CI passes
The CI of upperstream is compiling because of the amount of COLCON_IGNORES
We suggest to remove them and leave the CI crash
Create a PR to the CI to the moveit_ci.
complete the alignment of MoveIt 2 core Moveit core CMakeLists.txt by ahcorde · Pull Request #90 · moveit/moveit2 · GitHub
The list of the PR that has to be merged first
Mike says that the CMakelist has to be fixed because of relative paths
Alex says that the best way to fix the CMakelist is by merging all the already opened PRs, because there are some PRs merged with the same error. Then he will open a pr solving all the issues.
Porting pick and place capabilities / visualization
Pick and place has been ported needs to be tested.
Also porting the visualization plugins
Rviz plugins
Rviz2 review the current status (dashing release).
Issues with control_msgs
CI
Create a PR on moveit_ci, with the needed changes in order to have CI from upstream working.
ros2tests
Start adding ros2tests for the packages because of the release of dashing.
Ping in all the PR that can be merged only in the ones that we can merge it.
MoveIt 2 update and contributions
Next meeting, to be announced
Complete notes including previous meetings available at https://docs.google.com/document/d/1n34giKHHxUVSuFJ-JVzy4fQQ-lt5WabZtN-DF6wmhFo/edit#heading=h.podun752m9ei
We will postpone the meeting of the 14th and announce the next meeting date in the coming weeks.
Is anyone still driving the Manipulation WG? If not, does anyone want to volunteer to take the lead on this? We (Intel) are willing to participate / contribute.
Hello @mkhansen ,
Thanks for volunteering. AFAIK, nobody is currently leading it so I’d say that you’re more than welcome to take it from this point. Latest contributions to moveit2 are at GitHub - AcutronicRobotics/moveit2: The MoveIt 2 Motion Planning Framework for ROS 2.0 .
Ping me if you need support.
