Is it time to discuss rosidl?
Yes that’s the only kind of setup I’ve ever seen work consistently, running the DDS on loopback, centralized discovery, etc. Then I get sort of ROS 1 performance at several times the CPU load. Depending on the share of rclpy nodes of course.
Well fwiw I did bring the aforementioned benchmark to @mjcarroll 's attention a few months back and to his credit he did patch some of the serialization overhead in both cyclone and zenoh with the suggested caching fix which should be live in Lyrical now. How much that helps in practice I’m not sure yet, because it only ships with Lyrical and I don’t have any representative test environment for it yet. While I’m still stuck on Jazzy anything I eval on it can be handwaved with “might be fixed in Lyrical”. So not much point in doing that yet until there’s more Jetty updated sim setups and that will take some time. But sure, I can send some actual numbers over on Zulip once I have something concrete set up.
Of course the functional benefits of ROS are immense, but far more so during research and prototyping than in final deployment when everything is very clearly defined, and where every layer of inefficiency makes the system more expensive per unit.
Very well, I take that back. My point was, a single design choice has dragged along a significant amount of bloat that has imo caused more harm than good, at least in the short term. Yes there are known shortcomings in ROS 1, and there are also known shortcomings in ROS 2.
I still think the general industry attitude is that the ones that do manage to get something working it’s despite the DDS, not because of it. They’re mostly dragged along kicking and screaming because they need Nav2. But that’s just what I’ve heard.
Maybe I’m getting off topic here, but I cannot stress enough how important it would be to make sure the defaults for all RMWs are at least, hm… usable? Good might be asking for too much. Relying on the vendors for that has not produced any results, there’s just a bunch of configs circulating around with nobody exactly sure what option helps with what. Perhaps those guys running it all super duper well in production can help give the rest of us plebs a hand?
Okay that’s big if true. Looking forward to it :+1: I would be surprised if some additional overhead doesn’t sneak in to remove basically all the gain of the approach though, we usually can’t have nice things.
Thanks for the feedback. Fair point — I stretched the rosidl representation discussion into a separate state-semantics/diagnostics idea, which is probably better evaluated independently rather than in this thread.
Well, it looks like I missed quite a few notifications. FWIW these ramblings have since turned into Minimal Overhead Messaging Support Using Runtime Agnostic Memory Layouts | Robotics Enhancement Proposals and GitHub - Ekumen-OS/zero_copy_rosidl: Rerence implementation of REP-0157, a re-design of the rosidl messaging system to broaden the scope of application of zero-copy transports in ROS 2. · GitHub . There will be a public discussion tomorrow about it, see Dedicated meeting to discuss REP 0157: Wednesday, 4 November 2026 in case you missed it.
Albeit late, some thoughts on the above.
While I agree ROS brings with it plenty of non zero cost abstractions in exchange for features that may not always (or ever) be relevant to every user, I’m less certain about the cargo culting. Almost 15 years of federated development, often on skeleton crews, have added massive inertia to the project. Any significant, cross-cutting change is very hard and expensive (I sure know), and so we as a community end up trying to make ends meet with what is. No one’s a fundamentalist here, I think.
I get where you are coming from, and as Geoff said, the present day answer to this is `rosidl_buffers`, with a hardware vendor support base that is slowly but steadily growing (see GitHub - ros2/rosidl_buffer_backends: Backend implementations for ROSIDL buffer types · GitHub ). That said, zero copy is not a form of transport, it’s a data flow pattern and a design tradeoff. `rosidl_buffers` does zero copy over IPC for heterogeneous memory systems while targeting an specific but exceedingly common class of payloads. This thread started on the idea that a ROS user should be able to opt for a zero-copy data flow when appropriate (over CPU or else). Of course this is all moot if the entire data plane moves to dedicated hardware, but I suspect we are still some ways away from standardizing robot stacks to such extent (though I may be wrong).
