Hi everyone,
I’m excited to share a side project I’ve been working on:
Motivation
Building interfaces in ROS2 is slow. Interface packages with a lot of messages might even be the packages that take the most time to build in your workspace. If you work with ublox_msgs or px4_msgs, you know what I mean.
During the build, it doesn’t look like the CPU is very busy. It might have one thread running a mysterious rosidl_generator_ or rosidl_typesupport_ script with shorter bursts where it’s fully loaded in between.
Also, modifying a single interface file rebuilds the entire package. This, combined with the long build time, results in an unpleasant development process.
The idea behind rosidlcpp was to reimplement rosidl in C++ so that the scripts can be parallelized. The speedup of reimplementing in C++ was sufficient that multithreading still hasn’t been started.
Issues with rosidl
Slow Python Generators
Most of the time spent building interface packages is spent on generating files. With the default install, 10 file generators need to run, each generating multiple files per interface.
I suspect there are two reasons for the generators to need this time:
- Parsing the IDL files (
rosidl_generator_type_descriptiongenerates a single file per message but still takes long). - Complex file templates to generate (see the last generator
rosidl_generator_py).
Slow Compilation
Zooming in on the main compilation section (after the rosidl_typesupport_) reveals that some files take over 300ms to compile.
Adding -ftime-report to one of these build stages reveals that most of the time (around 90%) is spent parsing the file.
[3/5] Building CXX object CMakeFiles/px4_msgs__rosidl_typesupport_fastrtps_c.dir/rosidl_typesupport_fastrtps_c/px4_msgs/msg/detail/action_request__type_support_c.cpp.o
Time variable usr sys wall GGC
phase setup : 0.00 ( 0%) 0.00 ( 0%) 0.00 ( 0%) 1882k ( 2%)
phase parsing : 0.14 ( 88%) 0.11 (100%) 0.26 ( 93%) 68M ( 90%)
phase lang. deferred : 0.01 ( 6%) 0.00 ( 0%) 0.01 ( 4%) 3741k ( 5%)
phase opt and generate : 0.01 ( 6%) 0.00 ( 0%) 0.01 ( 4%) 1746k ( 2%)
|name lookup : 0.04 ( 25%) 0.01 ( 9%) 0.04 ( 14%) 2962k ( 4%)
|overload resolution : 0.00 ( 0%) 0.00 ( 0%) 0.02 ( 7%) 3727k ( 5%)
callgraph construction : 0.01 ( 6%) 0.00 ( 0%) 0.00 ( 0%) 272k ( 0%)
preprocessing : 0.01 ( 6%) 0.04 ( 36%) 0.07 ( 25%) 2166k ( 3%)
parser (global) : 0.04 ( 25%) 0.02 ( 18%) 0.03 ( 11%) 25M ( 34%)
parser struct body : 0.02 ( 13%) 0.00 ( 0%) 0.02 ( 7%) 17M ( 23%)
parser function body : 0.01 ( 6%) 0.01 ( 9%) 0.02 ( 7%) 1857k ( 2%)
parser inl. func. body : 0.02 ( 12%) 0.00 ( 0%) 0.04 ( 14%) 2720k ( 4%)
parser inl. meth. body : 0.00 ( 0%) 0.02 ( 18%) 0.02 ( 7%) 8009k ( 10%)
template instantiation : 0.05 ( 31%) 0.02 ( 18%) 0.06 ( 21%) 14M ( 19%)
constant expression evaluation : 0.00 ( 0%) 0.00 ( 0%) 0.01 ( 4%) 118k ( 0%)
initialize rtl : 0.00 ( 0%) 0.00 ( 0%) 0.01 ( 4%) 12k ( 0%)
TOTAL : 0.16 0.11 0.28 75M
The reason parsing the file takes so long is that its includes, once expanded, result in a file over 50,000 lines long and over 1MB. Each interface definition generator file includes the same headers that are parsed by the compiler for each file.
What rosidlcpp Does Differently
- Complete reimplementation in C++. The IDL files are parsed into JSON data structures and passed to the Inja template engine (Why Inja? It’s the first result when searching “C++ template engine”. I have no major complaints).
- Precompiled headers. The headers shared by all interfaces are precompiled once, which significantly reduces the time it takes to compile each
.c/cppfile.
The resulting build is almost entirely spent on actually compiling files:
Replacing rosidl Generators (This is the Jankiest Part of rosidlcpp)
There is, to my knowledge, no clean way to replace existing generators with others.
To replace the rosidl_ generators, the rosidlcpp_ generators manually edit the CMake AMENT_EXTENSIONS_rosidl_generate_idl_interfaces variable (which is normally updated when calling ament_register_extension). Also, all rosidlcpp_ generators only register as rosidl_generator_packages, even though typesupport would normally be expected to register rosidl_typesupport_c[pp].
Apart from that, the build is the exact same as done by the rosidl_ generators with rosidl substituted for rosidlcpp in some places.
Benchmarks
Compilation time on AMD Ryzen 9 9900X 12-Core (24 threads) Processor, 32 GB of RAM. In a Docker container based on osrf/ros:rolling-desktop-full.
Time measured from the .ninja_log logs (there is about 1-2 seconds of additional overhead).
| Packages | rosidl | rosidlcpp (not precompiled) | rosidlcpp | rosidlcpp speedup |
| test_msgs | 7.680s | 2.435s | 2.090 | 3.7 |
| px4_msgs | 72s | 14.450s | 5.685s | 12.7 |
| ublox_msgs | 42s | 5.985s | 2.670s | 15.7 |
