Posted by @mxgrey:
With the introduction of Flexible task definitions by mxgrey · Pull Request #39 · open-rmf/rmf_task · GitHub which followed this discussion, RMF allows users to compose tasks that can be nested sequences of activities. This added a great deal of customizability to RMF’s task system, but we recognize that real world needs will not always fit into this narrow task description structure.
While the last revision of the task system was a big step forward, it was never meant to be the final design. Its limitations were known at the time that it was designed, and those limitations were strategically chosen to allow us to cover the most broadly critical needs in the most reasonable amount of time.
This discussion will try to flesh out a design for the next revision of RMF’s task system. My hope is to design a task framework that’s general enough that we will not need another major revision after this (but feature additions and implementation improvements are always expected). Specifically, I’d like to address these requirements which were intentionally excluded from that last revision:
- Tasks are defined by event graphs (similar to a behavior diagram/tree) that users can draw in a GUI
- Tasks can have loops, branches, and other forms of conditional logic
- Task descriptions can involve multiple robots operating simultaneously
- Task descriptions can involve one robot/device performing multiple actions at once where possible+relevant
- Multiple nodes/pathways in the event graph can be active simultaneously
- Event graphs are robust to how users try to design them, e.g. fallback behavior is always reasonable and tasks can never be permanently locked up due to the graph being badly designed
I’ll start with defining some of the elements that I think would be useful for an event graph framework. The following picture was exported from this Figma project:
Additionally we’ll want a way to encapsulate these graphs for the sake of reusability, hierarchy (nesting event graphs inside of event graphs), and clean design. We’ll refer to an encapsulated event graph as an “Activity”, borrowing terminology from the UML standard. Since we want to be able to nest Activities inside of Activities, an Activity can declare the Triggers, Mutators, Queries, Properties, and Events that it exposes to any parent Activity that wants to use it, much like a public API.
Here is example of what a Delivery Activity Diagram might look like. In this diagram, the pick up and drop off behaviors will be retried up to 3 times each if they fail for some reason.
Here is an example of what a multi-robot “Vacuum and then Mop” activity could look like. Additionally it has queries to decide to cancel everything if a deadline is reached.
Building on the previous example, here is an example of a task that runs a list of sub-tasks simultaneously using a for_each block. The for_each block manages multiple instances of a single event graph simultaneously and takes care of synchronizing its inner event graph instances with the parent graph.
Note that I’ve embedded comments in all of the examples. I won’t repeat the content of the comments here, so I recommend reading through those inside Figma itself for a deeper understanding of the ideas.
These examples should not be taken as a finalized design, but rather as the starting point for a design discussion. I believe there will be many many details to flesh out over the coming months, and these drawings are just meant to establish a base line and reference point for discussion.
Besides discussing the ideas that I’ve laid out so far, here’s what I would recommend for next steps:
1. Decide the data types that are supported for messages
For the data types, I would like to take inspiration from Rust and support the following types:
- primitives: u64, i64, f64 (should we bother supporting lower precision primitives like u8, i8, u32, i32?), bool, string
- struct: Heterogeneous collection of data with named fields
- tuple: Heterogeneous collection of data with unnamed fields
List<T>: Homogeneous collection of data with unnamed elements- variant: Data which can belong to one of a predefined set of possible data types. Pattern matching and dispatching blocks are used to identify which data type is contained at runtime.
Option<T>: Specialized variant that can containSome(T)orNoneResult<T, E>: Specialized variant that can containOk(T)orErr(E). Recommended output for afinishedevent.Property<T>: Reference to some Property of type T- resource: A reference to some resource that can be used by an activity, such as a mobile robot, a planner, a workcell, etc. Resources have “traits” which define methods (sync) and services (async) that activities can call on the resource. The traits that an activity requires for a resource is baked into the type information of the resource declaration. E.g. if
Mobileis a trait for objects that can be commanded to move, thenMobileAgent: Mobileis a resource type declaration for a resource with theMobiletrait. - callback: An object which can be called as if it’s a function
2. Determine what block types should be supported (and how to support custom third-party blocks)
In the examples that I’ve provided I’ve defined these block types:
- Trigger blocks: Exposes a trigger (e.g.
start) to parent event graphs - Query blocks: Exposes queries to parent event graphs
- Property blocks: Exposes properties to parent event graphs
- Finish event block: Determines the finishing point of the event graph
- Activity block: Allows an activity to be triggered
- map: Maps input data (e.g. a trigger and/or queries and/or listeners) into output data (e.g. event or property) via a template substitution
- cmp: Takes in a tuple with two values of comparable types (e.g. integer or float) and compares their values, providing a
less,equal, andgreaterbranch. - dispatch: Takes in a variant and outputs an event/property for each alternative type within the variant
- iterate: Takes in a trigger and a limit. Emits
continueuntil the limit is reached, then emitsbreak. if_match: Triggersthenif every input matches their specified patterns. The message forthencan use data from the patterns in its data mapping. If any input does not match its pattern,elsewill be triggered. The message forelsecan only use the raw input types.for_each: Takes in aList<T>trigger, queries, and a event graph frame. For eachTin the list runs its inner event graph by sendingTto the inner event graph’s trigger block.- signal block: Triggers a signal for this event graph
- signal handler block: Intercepts signals that are emitted for this event graph
3. Serialization format for all of the above
We’ll need a way to serialize all the event graph data so that it can be transmitted and saved to disc.
While JSON isn’t exactly my favorite serialization format, it does have the benefit of extremely widespread support across the web and virtually all programming languages. It also allows us to use json-schema to describe and validate the structure of the serialization.
4. GUI for drawing the event graphs
For this concept to be useful, a user-friendly GUI is critical. The best possible solution for this would be one that we could use in both a web browser and in the “traffic editor” tool, which would imply implementing it in Rust, which can compile to WASM.
However, I’ve had a difficult time finding Rust tools/frameworks to help with drawing graphs. In general the Rust ecosystem is still somewhat nascent when it comes to GUI development. Meanwhile there are many tools in the JavaScript ecosystem suitable for drawing graphs. To prevent requirement this from being a blocker for too long we could consider implementing a first version of the event graph drawer in JavaScript using an existing framework while we have a parallel effort to implement a final version in Rust, most likely using Bevy.
With some guidance from the Bevy community, I’ve learned about egui_node_graph which looks like it may be suitable for our initial needs. We should try out that library as a first step, and maybe iterate on it if it has any gaps that we can reasonably fill in.
5. Implementation of event graph execution
Since RMF is migrating to Rust for the sake of code quality and robustness, we’ll need to implement the event graph execution framework in Rust. I expect this is going to be the most challenging undertaking and will require its own deeper technical discussion.
6. Modeling of event graphs for task planners
In order for the task bidding system to work, fleet adapters need to be able to reason about tasks based on models. Since event graphs may involve run time variables that cannot be predicted by a model, we may need a way to embed hints inside of the event graphs to indicate the likely paths. For example, adding some decoration to the graph to indicate which branch is likely to be chosen at a split or how many times an iterator is likely to repeat.
Other topics for discussion
Artwork and UI design
I am not an artist, so it would be great to get feedback and suggestions on the UI elements in the example drawings. Feedback and suggestions may include completely redesigning everything to better fit the 21st century.
Terminology / Vocabulary / Soundness
If there are better words to use to describe any of the concepts that I’m using, please do share. Also please bring up any important concepts or requirements that I may be overlooking.
Also if anyone knows of relevant literature from graph theory and/or event-driven architecture research, please let us know so we can get the most out of existing research in the field.
Edited by @mxgrey at 2022-07-15T05:05:23Z
