Hi Gazebo Community!
This week’s meeting was held on 2025-10-13T18:00:00Z and the following is a summary:
The main focus of this week’s meeting was roadmap planning, so we didn’t go over the usual progress updates. However, here’s a quick look at some ongoing work:
- Progress updates:
- Work continues on deprecating
get.gazebosim.org. You can track the progress in this pull request. - A shim layer is being added for Python in ROS Gazebo vendor packages to help with older ROS versions. The PR is up for review.
- We’re looking into using tools like release-please and conventional commits to improve our release process.
- A draft PR is in progress to allow loading a Zenoh configuration from a file in
gz-transport. This will enable the use of the Zenoh router. See the PR here.
- New agenda items:
- Gazebo Kura Roadmap Brainstorming: The entire meeting was dedicated to brainstorming potential features and improvements for the next Gazebo release, Kura. No final decisions have been made, but here are the topics we discussed:
- Improving Documentation: We’re considering ways to make our docs better, like combining different tutorial sources and bringing over useful guides from Gazebo classic.
- Supporting Third-Party Plugins: We had a big discussion on how to better support community plugins. The current thinking is to start with an “awesome list” to highlight community projects. A more involved solution using the ROS buildfarm might be explored later.
- Zenoh Refinements: Further work on the Zenoh integration was discussed. A key idea is adding shared memory support, which could be a big performance win, especially between separate processes like the server and GUI.
- Performance Deep Dive: We talked about the need to investigate performance bottlenecks across the stack, including the ECM, SDFormat loading, physics, and rendering.
- Low-Fidelity Simulation: The idea of better supporting faster-than-real-time simulation was brought up. This could involve improving support for kinematic-only objects or adding a “kinematics mode” that doesn’t require SDF changes.
As always, the meeting notes are available at
New Gazebo weekly agenda - Google Docs.
The next Gazebo PMC meeting will be on 2025-10-20T18:00:00Z (See Open Source Robotics Foundation official events)
