[CROSS POST] Gazebo and Ignition are going to GitHub!
FYI: this is a cross post from the Gazebo forum for higher visibility.
Important :warning: Gazebo and Ignition are going to GitHub!
Hello community :fire:
BitBucket will be mercilessly eliminating all mercurial repositories on June 1st 2020.
Open Robotics’ simulation team has been using BitBucket to host our projects for many years. From Gazebo to Ignition, we have accumulated a couple hundred mercurial repositories over the years. And now that BitBucket is dropping mercurial support, you have been asking:
https://community.gazebosim.org/t/bit-bucket-removing-mercurial-will-gazebo-switch/391/5
And the answer is yes. We’re going to GitHub.
:people_holding_hands: Who will be affected
You’ll be affected if you are:
  • A user who compiles / pulls any of our projects from source
  • A contributor to code, documentation, etc.
Within Open Robotics, our release, deployment and CI procedures will also be affected. This shouldn’t directly impact external users, but beware that there may be some downtime during migration, for example, on https://build.osrfoundation.org/.
It is worth noting that if you have down stream documentation or installation scripts you will be impacted and those materials may no longer function once BitBucket terminates mercurial support.
:snowflake: Freeze
As we migrate repositories, they will be frozen on BitBucket. So we ask users: please don’t create issues, pull requests or comments during those dates.
We’ll be closing all open pull requests on all repositories (merging or declining). If you’re working on a new pull request to one of our BitBucket repositories right now, we ask that you please wait until the repository is on GitHub to open new pull requests, so we can more quickly close the ones currently open.
See the schedule below for our repositories under active development:
Repository Freeze dates
Bitbucket 2020-04-10T07:00:00Z
Bitbucket
Bitbucket
2020-04-10T07:00:00Z → 2020-04-13T07:00:00Z
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
https://bitbucket.org/ignitionrobotics/ign-plugin
Bitbucket
Bitbucket
Bitbucket
Bitbucket
2020-04-14T07:00:00Z → 2020-04-17T07:00:00Z
Bitbucket 2020-04-17T07:00:00Z → 2020-04-21T07:00:00Z
Bitbucket
Bitbucket
Bitbucket
2020-04-22T07:00:00Z → 2020-04-24T07:00:00Z
:world_map: What’s going where
We have 2 organizations on BitBucket:
  • Bitbucket
    • Hosts projects like Gazebo and SDFormat, as well as related projects like SubT, DRCSim, SRCSim, GzWeb, etc.
  • Bitbucket
    • Hosts the source code, release repositories, documentation, etc, all related to Ignition libraries.
As we move things to GitHub, we’ll distribute repositories across a few different organizations.
We will be using @scpeters’s fork of the bitbucket-hg-exporter tool to create a GitHub Pages backup of issues, pull requests and comments on public websites. All issues will also be imported to the new repositories, but BitBucket pull requests will only be archived on GitHub Pages.
As an example of this migration, osrf/sdformat has been migrated to scpeters-test/sdformat with issues imported to github and pull requests archived on GitHub pages.
See the table below as a quick reference of the archived and migrated repositories. We’ll be populating it as repositories are migrated.
:snowflake: Freeze
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
Bitbucket
  • Bitbucket
  • Bitbucket
BitBucket repository | GitHub repository | BitBucket backup
BitBucket repository GitHub repository (may not exist yet) BitBucket backup
Active development / maintainance
Bitbucket https://github.com/osrf/gazebo
Bitbucket https://github.com/osrf/sdformat
Bitbucket https://github.com/ignitionrobotics/ign-cmake
Bitbucket https://github.com/ignitionrobotics/ign-common
Bitbucket https://github.com/ignitionrobotics/ign-fuel-tools
Bitbucket https://github.com/ignitionrobotics/ign-gazebo
Bitbucket https://github.com/ignitionrobotics/ign-gui
Bitbucket https://github.com/ignitionrobotics/ign-launch
Bitbucket https://github.com/ignitionrobotics/ign-math
Bitbucket https://github.com/ignitionrobotics/ign-msgs
Bitbucket https://github.com/ignitionrobotics/ign-physics
https://bitbucket.org/ignitionrobotics/ign-plugin https://github.com/ignitionrobotics/ign-plugin
Bitbucket https://github.com/ignitionrobotics/ign-rendering
Bitbucket https://github.com/ignitionrobotics/ign-sensors
Bitbucket https://github.com/ignitionrobotics/ign-tools
Bitbucket https://github.com/ignitionrobotics/ign-transport
Bitbucket https://github.com/osrf/subt
https://bitbucket.org/osrf/subt_seed https://github.com/osrf/subt_seed
Bitbucket https://github.com/osrf/gazebo_models
Bitbucket https://github.com/osrf/gazebo_tutorials
Bitbucket https://github.com/osrf/sdf_tutorials
Bitbucket https://github.com/ignitionrobotics/docs
https://bitbucket.org/osrf/gzweb https://github.com/osrf/gzweb
https://bitbucket.org/osrf/mesh_to_sdf https://github.com/osrf/mesh_to_sdf
https://bitbucket.org/osrf/release-tools https://github.com/ignition-tooling/release-tools
https://bitbucket.org/osrf/gazebodistro https://github.com/ignition-tooling/gazebodistro
Past projects
https://bitbucket.org/osrf/drcsim https://github.com/osrf/drcsim
https://bitbucket.org/osrf/handsim https://github.com/osrf/handsim
https://bitbucket.org/osrf/srcsim https://github.com/osrf/srcsim
https://bitbucket.org/osrf/servicesim https://github.com/osrf/servicesim
https://bitbucket.org/osrf/citysim https://github.com/osrf/citysim
https://bitbucket.org/osrf/swarm https://github.com/osrf/swarm
https://bitbucket.org/osrf/mentor2 https://github.com/osrf/mentor2
https://bitbucket.org/osrf/gazebojs https://github.com/osrf/gazebojs
https://bitbucket.org/osrf/robocup3ds https://github.com/osrf/robocup3ds
https://bitbucket.org/ignitionrobotics/ign-rndf https://github.com/ignitionrobotics/ign-rndf
@Katherine_Scott Thank you for the update. Btw I see the same content duplicated except the table at the bottom…?
