Hi everyone
I recently completed a systematic evaluation of global path planners in ROS2 Nav2, and wanted to share the results with the community.
Overview
I benchmarked four global planners:
Dijkstra
A*
Theta*
SMAC2D
The evaluation was conducted on 3,000 randomized navigation tasks, repeated across three independent runs, using a paired-sample methodology to ensure fair comparison.
Key Results
| Planner | Success Rate | Mean Time | Path Quality |
| Dijkstra | 100% | ~22 ms | Longer (least cost) paths |
| A* | 100% | ~22 ms | Similar to Dijkstra |
| Theta* | ~86% | ~18.6 ms | Shortest paths |
| SMAC2D | ~90% | ~19 ms | Smooth + near-optimal |
Key Observations
Dijkstra & A*
→ Perfect reliability (100%), but higher computation time and longer (least cost) paths -
Theta*
→ Fastest and shortest paths, but reduced robustness in cluttered environments -
SMAC2D
→ Best overall balance between runtime, smoothness, and robustness
Real-Time Performance
A 50 ms constraint (20 Hz control loop) was used
All planners meet this in most cases
SMAC2D achieves >99% compliance
Theta* shows the lowest tail latency
Takeaway
There is a clear trade-off between:
Robustness (Dijkstra / A*)
Optimality + Speed (Theta*)
Balanced real-world performance (SMAC2D)
No single planner dominates across all metrics.
Repository
Full results and plots are available here:
GitHub - haris-mujeeb/Differential-Drive-Path-Planning-and-Navigation · GitHub
Thanks!
