ROS PMC Minutes for October 13, 2026
The ROS PMC meeting for this week was on Tuesday, October 13, 2026. The notes from the meeting are available at ROS PMC weekly meeting agenda.
ROS PMC Business
  • @skye.galaxy :memo: TGC ROS representative: the vote is still to go out. @ahcorde will send it once the account credentials are available.
  • @christophebedard :memo: ROSboss for M-turtle: the vote goes out together with the TGC vote.
  • @ahcorde will re-read the governance documentation to clarify the PMC voting process.
  • :new_button: New committer candidates and mentors:
  • :light_bulb: proposed an in-person PMC summit for roadmapping and working on features together. Funding will be discussed with the Technical Steering Committee.
Regular Business
Buildfarm update
The buildfarm builds and tests ROS packages across all supported distributions and platforms. This section covers new issues, current priorities, and infrastructure changes that affect maintainers.
  • [@miguelgonrod] :new_button: Issues: nothing new from the buildfarm side.
  • :warning: Priorities:
    • :memo: PTAL Buildfarm Issues Dashboard (27 open issues). Several were opened months ago and have had no new information since. Should any of them be disabled?
    • Build regression in perf_test: undefined references to DDS PubSubType on Rolling and Lyrical. The root cause appears to be on the Cyclone DDS side.
    • Segmentation fault in rclpy test_client and test_service.
    • test_launch_ros.pytest.missing_result intermittently times out, with ClassLoader unload warnings.
    • test_load_node_with_param_file intermittently hangs while loading composable nodes.
    • rosidl_typesupport_tests assume rosidl_typesupport_cpp is available.
    • tf2_ros_message_filter.multiple_frames_and_time_tolerance_deprecated is flaky and times out on Rolling and Kilted with Connext.
  • @miguelgonrod will open new issues for the buildfarm items that need attention. @ahcorde will look into the reported test failures if nobody else picks them up.
Waffle note-taker
Rosdistro assignments
Rosdistro is a weekly assignment to monitor incoming issues and pull requests in GitHub - ros/rosdistro. Two people per week are assigned to be the rosdistro maintainers.
  • :date: Oct 13, 2026 - Oct 20, 2026 - @sloretz and Andrew Symington
Release Management
Release Management tracks the status of upcoming releases, patches, and syncs across the active ROS distributions.
  • @christophebedard (Humble)
    • :white_check_mark: Synced Monday, Oct 12, 2026.
  • @yadunund (Rolling)
    • :white_check_mark: @cottsay: distribution-level tagging for Rolling has officially been discontinued.
    • @yadunund is working on the automatic Rolling syncs.
  • Marco A. Gutiérrez (Jazzy)
    • No update.
  • @cottsay (Kilted)
    • No update.
  • @sloretz (Lyrical)
    • No update.
Working Group Updates
  • ROS Office Hours
    • Last Meeting: Oct 9, 2026
    • Next Meeting: [DATE]
    • Andrew Symington reported productive discussions on AI attribution and traceability.
  • Client Library Working Group (Alberto Soragna)
    • Last Meeting: Oct 2, 2026
    • :date: Next Meeting: Oct 16, 2026
  • Accelerated Memory Transport Working Group (@ahcorde)
    • Last Meeting: Sep 16, 2026
    • :date: Next Meeting: Oct 14, 2026
    • Validated
  • ROSGraph Working Group (Emerson Knapp)
  • SIG Physical AI
    • :date: Next Meeting: Friday, Oct 16, 2026
    • Working on a low-cost mobile manipulator.
Agenda
  • [@claraberendsen] rclpy#1707: 154 mypy regressions in rclpy, caused by generated code, are breaking builds.
  • ROSCon feedback
    • Microcontrollers
      • :warning: Kat Scott: the microcontroller ecosystem is still fragmented across RMW implementations.
      • Kimberly McGuire: Sapphire has expressed interest in collaborating on microcontroller frameworks.
    • macOS support
      • Kat Scott: running the ROS 2 and Gazebo tutorials on macOS is still hard.
      • @cottsay is exploring alternative package managers and looking at a long-term Pixi strategy.
      • @claraberendsen: we should define explicit supported use cases and platform boundaries for the other operating systems.
    • Release docs and vendor experience
      • @sloretz: vendors are confused about binary releases and installing from apt.
      • Kat Scott: confusing naming and gaps in the docs make it harder for vendors to adopt ROS.
      • :light_bulb: Kat Scott proposed improving repository READMEs with documentation and onboarding context.
      • William Woodall and @ahcorde discussed using agent markdown files (AGENTS.md) to standardize contribution rules across repositories.
      • :memo: README standardization goes on the agenda for Oct 20, 2026.
    • Official ROS 2 robot certification
      • :light_bulb: Kat Scott proposed a rubric and a formal certification process for official ROS 2 robots.
      • @yadunund: SIG Physical AI is developing a low-cost mobile manipulator.
      • Andrew Symington suggested test infrastructure and simulated test examples for certified platforms.
    • ROSCon scheduling and location
      • :light_bulb: Kat Scott proposed holding ROSCon every 6 months to allow more preparation time.
      • @clalancette suggested holding ROSCon right after each release, to plan the year’s priorities.
      • @claraberendsen suggested warm-weather locations for post-release events.
    • REPs at ROSCon
      • :light_bulb: @ahcorde proposed a dedicated track or workshop day to discuss REPs in depth.
      • Janosch Machowinski: CppCon successfully discusses changes to the standard during the conference.
      • @claraberendsen: holding REP discussions at ROSCon brings the key contributors in.
    • :date: The remaining ROSCon feedback topics move to the Oct 20, 2026 meeting.
