ROS PMC Minutes for November 24, 2026
The ROS PMC meeting for this week was on Tuesday, November 24, 2026. The notes from the meeting are available at ROS PMC weekly meeting agenda.
ROS PMC Business
  • :white_check_mark: The Kilted Kaiju End-of-Life vote passed with +17 votes. Kilted goes EOL on Nov 30, 2026.
  • :warning: New committers: the vote still did not reach quorum because some PMC members did not respond. @ahcorde will relaunch it.
  • :light_bulb: PMC membership and participation
    • @tfoote shared a draft charter update with clear participation thresholds and a dormant state for inactive members.
    • @ahcorde will email all PMC members to ask whether they want to stay active, become dormant or step down, and will revise the policy on removing inactive members.
  • :memo: Security policy: the TGC is working on an updated security policy for the organization and needs feedback from TGC members.
Regular Business
Buildfarm update
The buildfarm builds and tests ROS packages across all supported distributions and platforms. This section covers new issues, current priorities, and infrastructure changes that affect maintainers.
  • :new_button: Issues, mostly Windows:
    • rviz#1937: rviz_rendering_tests GCC 15 reports a -Warray-bounds warning in createPaddedTriangle().
    • Ignored warn_unused_result return values in test_event_message_lost_deadlock.cpp.
    • WaitSetTestFixture.negative_timeout unexpectedly rejects a negative timeout on Windows.
    • rosbag2_transport: test_record_services__rmw_connextdds crashes with an access violation on Windows. A skip mechanism in rosbag2 doesn’t handle zero timestamps on Windows.
    • @clalancette will look into the last three.
  • :warning: Priorities:
  • Gazebo third-party packages in Fedora: Sayan Paul is building third-party dependencies for Gazebo on [PLATFORM] and has had trouble reaching their maintainers. @cottsay may be able to help with releases as a trusted packager in Fedora.
Waffle note-taker
  • Baffle maker
  • Nov 19, 2026 - Andrew Symington
  • :date: Nov 26, 2026 - skipped - Thanksgiving
Rosdistro assignments
Rosdistro is a weekly assignment to monitor incoming issues and pull requests in GitHub - ros/rosdistro. Two people per week are assigned to be the rosdistro maintainers.
Release Management
Release Management tracks the status of upcoming releases, patches, and syncs across the active ROS distributions.
  • @christophebedard (Humble)
    • :white_check_mark: Synced Monday, Nov 23, 2026.
  • @yadunund (Rolling)
    • No update.
  • Marco A. Gutiérrez (Jazzy)
    • No update.
  • @cottsay (Kilted)
    • :date: Final sync at the end of the month, before EOL on Nov 30, 2026.
    • :warning: Maintainers: release your final Kilted patches now, or they won’t make it.
  • @sloretz (Lyrical)
    • No update.
Working Group Updates
  • ROS Office Hours
    • :date: Next Meeting: Dec 4, 2026
  • Client Library Working Group (Alberto Soragna)
    • Last Meeting: Nov 13, 2026
    • :date: Next Meeting: Nov 27, 2026
  • Accelerated Memory Transport Working Group (@ahcorde)
    • Last Meeting: Nov 11, 2026
    • :date: Next Meeting: Nov 25, 2026
  • ROSGraph Working Group (Emerson Knapp)
  • SIG Physical AI (@yadunund)
    • :warning: The Nov 25, 2026 meeting is cancelled.
Agenda
  • [@clalancette] Remove ros2/realtime_support (rttest and tlsf_cpp) along with tlsf?
    • The only user is the pendulum demo, which needs about 200 lines from rttest. Porting those into the demo lets us remove 3 barely maintained packages from the core.
    • Removing a repository needs a formal decision under the charter (Article 4.9.iii).
    • @clalancette will open a PR to remove realtime support from the core and update the pendulum demo.
  • [@clalancette] Multiple publishers on one topic with different schemas
    • The tools are inconsistent: ros2 topic info succeeds, ros2 topic echo refuses, ros2 bag record records only one, and ros2 bag play plays the data back with the wrong schema.
    • What behavior do we want?
      • @sloretz: ros2 topic echo should subscribe to all of them.
      • @tfoote: then print a verbose warning every time the type changes.
      • Also test the case of a type hash mismatch.
      • Miguel Company: what happens with the same schema name but a different hash?
      • Janosch Machowinski: what about rclcpp subscribers?
    • @clalancette will draft a proposal to make the tools consistent.
  • [@clalancette] ROS 2 logging subsystem redesign (ros2#1870)
    • @clalancette wrote a requirements document (folder).
    • :memo: Please read the requirements document (only that one) before the presentation.
    • :date: 30 minute presentation at the Dec 8, 2026 PMC meeting.
  • [@claraberendsen] Auto-sync to main for Rolling (ros_buildfarm#1151)
    • Is it OK for different platforms to sync to main at different times?
    • @claraberendsen tested the PR: RPMs and debs can each sync as soon as their own build is clean, without introducing regressions.
    • @claraberendsen will finalize the infrastructure PR.
  • [@ahcorde] Makoa Mata-mata roadmap
    • Michael Carroll has built tooling to track Rolling and run nightly builds with Bazel. This helps find flaky tests and dependency structure problems under high load.
    • :memo: Please keep reviewing and commenting on the roadmap.
Action Items
  • Everyone
    • Read the logging requirements document before the Dec 8, 2026 meeting.
    • Keep reviewing the Makoa Mata-mata roadmap.
    • Maintainers: release your final Kilted patches before Nov 30, 2026.
