ROS 2 Rust Meeting: January 2026
The next ROS 2 Rust Meeting will be 2026-01-12T14:00:00Z
The meeting room will be at https://meet.google.com/rxr-pvcv-hmu
In the unlikely event that the room needs to change, we will update this thread with the new info!
Agenda:
  1. Changes to generated message consumption (https://github.com/ros2-rust/ros2_rust/pull/556)
  2. Upgrade to Rust 1.85 (build!: require rustc 1.85 and Rust 2024 edition by esteve · Pull Request #566 · ros2-rust/ros2_rust · GitHub)
  3. Migration from Element to Zulip chat (Open Robotics launches Zulip chat server)
Some minutes from today’s meeting:
  • New ros2-rust release this week.
  • Changes to the message generation pipeline will happen after the next release, to make sure we have all the changes reviewed in all the related projects (rclrs, rosidl_generator_rs).
  • Agreed to move to rustc 1.85 as a minimum requirement.
  • Migration to Rust 2024 postponed to the release after the next, so that folks who have submitted PRs have time to update.
  • Windows CI is failing because we need binaries provided by the ROS buildfarm, but the latter now requires authentication. We’ll make a new release anyway, @KimMcG may add workaround if the fix in the ROS buildfarm is not released this week.
