Hello Noetic maintainers!
Starting now, I will be holding new Noetic ros/rosdistro release PRs with a plan to sync ROS Noetic packages to the main apt repo on 2021/05/24. Please comment here if there are any issues I should know about before performing the sync.
This sync will include a fix for this issue: file conflict when upgrading moveit_ros_planning · Issue #2648 · moveit/moveit · GitHub
There are currently 174 packages waiting to sync and no regressions.
The ROS Noetic sync happened, and is tagged as noetic/2021/05/24; however, there is a bug in MoveIt (motion planning stuck after several calls. · Issue #2666 · moveit/moveit · GitHub) for which there was a fix ready that I did not see beforehand. That release of MoveIt has been merged and it will be sync’d to the main apt repo as soon as possible.
ros/rosdistro PRs will continue to be held until the buildfarm completes rebuilding the MoveIt packages. This process should take about a day.
The sync is out.
Now is a great time to make releases for the next sync
