Starting now, I will be holding new Noetic ros/rosdistro release PRs with a plan to sync ROS Noetic packages to the main apt repo on 2020/12/14. Please comment here if there are any issues I should know about before performing the sync.
Given that many packages likely depends on image_pipeline, I think it makes sense to make sure it gets plenty soak time in the testing repo in case there’s an issue with the release or with the packages built.
I’ll move forward with the sync without merging image_pipeline’s release.
