We’re happy to announce the availability of 18 new packages and 37 updated packages for ROS Lunar.
As always thank you to all the maintainers who are making these releases as well as all the contributors who have helped contribute to these releases. Full details are below.
Package Updates for lunar
Added Packages [18]:
- ros-lunar-costmap-cspace: 0.2.3-0
- ros-lunar-euslisp: 9.25.0-0
- ros-lunar-ibeo-core: 2.0.0-0
- ros-lunar-ibeo-lux: 2.0.0-0
- ros-lunar-joystick-interrupt: 0.2.3-0
- ros-lunar-jskeus: 1.2.0-1
- ros-lunar-map-organizer: 0.2.3-0
- ros-lunar-neonavigation: 0.2.3-0
- ros-lunar-neonavigation-common: 0.2.3-0
- ros-lunar-neonavigation-launch: 0.2.3-0
- ros-lunar-obj-to-pointcloud: 0.2.3-0
- ros-lunar-planner-cspace: 0.2.3-0
- ros-lunar-safety-limiter: 0.2.3-0
- ros-lunar-sbpl: 1.2.0-0
- ros-lunar-towr: 1.3.2-0
- ros-lunar-towr-ros: 1.3.2-0
- ros-lunar-track-odometry: 0.2.3-0
- ros-lunar-trajectory-tracker: 0.2.3-0
Updated Packages [37]:
- ros-lunar-geometry2: 0.5.17-0 → 0.5.18-0
- ros-lunar-ifopt: 1.0.2-0 → 2.0.4-0
- ros-lunar-libmavconn: 0.26.0-0 → 0.26.1-0
- ros-lunar-mavlink: 2018.6.6-0 → 2018.7.18-0
- ros-lunar-mavros: 0.26.0-0 → 0.26.1-0
- ros-lunar-mavros-extras: 0.26.0-0 → 0.26.1-0
- ros-lunar-mavros-msgs: 0.26.0-0 → 0.26.1-0
- ros-lunar-novatel-gps-driver: 3.4.0-0 → 3.5.0-0
- ros-lunar-novatel-gps-msgs: 3.4.0-0 → 3.5.0-0
- ros-lunar-openni2-camera: 0.3.0-0 → 0.4.0-0
- ros-lunar-openni2-launch: 0.3.0-0 → 0.4.0-0
- ros-lunar-pid: 0.0.25-0 → 0.0.27-0
- ros-lunar-plotjuggler: 1.6.2-0 → 1.7.0-0
- ros-lunar-ros-type-introspection: 1.0.2-0 → 1.1.1-0
- ros-lunar-rqt-image-view: 0.4.11-0 → 0.4.13-0
- ros-lunar-sbg-driver: 1.1.6-0 → 1.1.7-0
- ros-lunar-teb-local-planner: 0.7.2-0 → 0.7.3-0
- ros-lunar-test-mavros: 0.26.0-0 → 0.26.1-0
- ros-lunar-tf2: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-bullet: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-eigen: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-geometry-msgs: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-kdl: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-msgs: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-py: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-ros: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-sensor-msgs: 0.5.17-0 → 0.5.18-0
- ros-lunar-tf2-tools: 0.5.17-0 → 0.5.18-0
- ros-lunar-video-stream-opencv: 1.1.2-0 → 1.1.3-0
- ros-lunar-xpp: 1.0.6-0 → 1.0.9-0
- ros-lunar-xpp-examples: 1.0.6-0 → 1.0.9-0
- ros-lunar-xpp-hyq: 1.0.6-0 → 1.0.9-0
- ros-lunar-xpp-msgs: 1.0.6-0 → 1.0.9-0
- ros-lunar-xpp-quadrotor: 1.0.6-0 → 1.0.9-0
- ros-lunar-xpp-states: 1.0.6-0 → 1.0.9-0
- ros-lunar-xpp-vis: 1.0.6-0 → 1.0.9-0
- ros-lunar-xsens-driver: 2.1.0-0 → 2.2.0-0
Removed Packages [0]:
- Alexander W. Winkler
- Andy Zelenak
- Atsushi Watanabe
- Christoph Rösmann
- Davide Faconti
- Dirk Thomas
- Francis Colas
- Isaac I. Y. Saito
- Kei Okada
- Koji Terada
- Michael Ferguson
- P. J. Reed
- Pyo
- Sammy Pfeiffer
- Thomas Le Mézo
- Tully Foote
- Vincent Rabaud
- Vladimir Ermakov
