We’re happy to announce the availability of 11 new packages and 84 updated packages for ROS Lunar.
As always thank you to all the maintainers who are making these releases as well as all the contributors who have helped contribute to these releases. Full details are below.
Package Updates for lunar
Added Packages [11]:
- ros-lunar-catkin-virtualenv: 0.1.4-0
- ros-lunar-four-wheel-steering-controller: 0.13.2-0
- ros-lunar-naoqi-libqi: 2.5.0-2
- ros-lunar-nmea-msgs: 1.1.0-0
- ros-lunar-osm-cartography: 0.2.4-0
- ros-lunar-route-network: 0.2.4-0
- ros-lunar-test-catkin-virtualenv: 0.1.3-0
- ros-lunar-test-catkin-virtualenv-py3: 0.1.3-0
- ros-lunar-test-osm: 0.2.4-0
- ros-lunar-vision-msgs: 0.0.1-1
- ros-lunar-zbar-ros: 0.1.0-0
Updated Packages [84]:
- ros-lunar-auv-msgs: 0.0.1-0 → 0.1.0-0
- ros-lunar-combined-robot-hw: 0.12.0-0 → 0.13.0-0
- ros-lunar-combined-robot-hw-tests: 0.12.0-0 → 0.13.0-0
- ros-lunar-control-toolbox: 1.15.0-0 → 1.16.0-0
- ros-lunar-controller-interface: 0.12.0-0 → 0.13.0-0
- ros-lunar-controller-manager: 0.12.0-0 → 0.13.0-0
- ros-lunar-controller-manager-msgs: 0.12.0-0 → 0.13.0-0
- ros-lunar-controller-manager-tests: 0.12.0-0 → 0.13.0-0
- ros-lunar-diff-drive-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-effort-controllers: 0.13.1-0 → 0.13.2-0
- ros-lunar-explore-lite: 2.1.0-0 → 2.1.1-0
- ros-lunar-force-torque-sensor-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-forward-command-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-gazebo-dev: 2.7.2-0 → 2.7.3-0
- ros-lunar-gazebo-msgs: 2.7.2-0 → 2.7.3-0
- ros-lunar-gazebo-plugins: 2.7.2-0 → 2.7.3-0
- ros-lunar-gazebo-ros: 2.7.2-0 → 2.7.3-0
- ros-lunar-gazebo-ros-control: 2.7.2-0 → 2.7.3-0
- ros-lunar-gazebo-ros-pkgs: 2.7.2-0 → 2.7.3-0
- ros-lunar-geometric-shapes: 0.5.2-0 → 0.5.3-0
- ros-lunar-gripper-action-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-hardware-interface: 0.12.0-0 → 0.13.0-0
- ros-lunar-imu-sensor-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-joint-limits-interface: 0.12.0-0 → 0.13.0-0
- ros-lunar-joint-state-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-joint-trajectory-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-libmavconn: 0.21.5-0 → 0.22.0-0
- ros-lunar-marti-data-structures: 1.2.0-0 → 2.0.0-0
- ros-lunar-mavlink: 2017.11.11-0 → 2017.12.12-0
- ros-lunar-mavros: 0.21.5-0 → 0.22.0-0
- ros-lunar-mavros-extras: 0.21.5-0 → 0.22.0-0
- ros-lunar-mavros-msgs: 0.21.5-0 → 0.22.0-0
- ros-lunar-moveit: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-commander: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-controller-manager-example: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-core: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-fake-controller-manager: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-kinematics: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-planners: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-planners-ompl: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-plugins: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-benchmarks: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-control-interface: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-manipulation: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-move-group: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-perception: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-planning: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-planning-interface: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-robot-interaction: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-visualization: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-ros-warehouse: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-runtime: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-setup-assistant: 0.9.9-0 → 0.9.10-0
- ros-lunar-moveit-simple-controller-manager: 0.9.9-0 → 0.9.10-0
- ros-lunar-multirobot-map-merge: 2.1.0-0 → 2.1.1-0
- ros-lunar-nerian-stereo: 2.0.3-0 → 2.1.0-0
- ros-lunar-parameter-pa: 1.1.0-0 → 1.2.1-0
- ros-lunar-position-controllers: 0.13.1-0 → 0.13.2-0
- ros-lunar-robot-localization: 2.4.0-1 → 2.5.0-0
- ros-lunar-ros-control: 0.12.0-0 → 0.13.0-0
- ros-lunar-ros-controllers: 0.13.1-0 → 0.13.2-0
- ros-lunar-rqt-controller-manager: 0.12.0-0 → 0.13.0-0
- ros-lunar-rqt-joint-trajectory-controller: 0.13.1-0 → 0.13.2-0
- ros-lunar-rviz: 1.12.13-0 → 1.12.14-0
- ros-lunar-sick-tim: 0.0.10-0 → 0.0.11-0
- ros-lunar-swri-console-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-geometry-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-image-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-math-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-nodelet: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-opencv-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-prefix-tools: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-roscpp: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-rospy: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-route-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-serial-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-string-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-system-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-transform-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-swri-yaml-util: 1.2.0-0 → 2.0.0-0
- ros-lunar-test-mavros: 0.21.5-0 → 0.22.0-0
- ros-lunar-transmission-interface: 0.12.0-0 → 0.13.0-0
- ros-lunar-velocity-controllers: 0.13.1-0 → 0.13.2-0
Removed Packages [0]:
- Adam Allevato
- Adolfo Rodriguez Tsouroukdissian
- Bence Magyar
- D. Hood
- Dave Coleman
- Ed Venator
- Elliot Johnson
- Isaac I. Y. Saito
- Jack O’Quin
- Jiri Horner
- John Hsu
- Jon Binney
- Jose Luis Rivero
- Kelsey Hawkins
- Konstantin Schauwecker
- Kris Kozak
- Marc Alban
- Martin Günther
- Mathias Lüdtke
- Michael Ferguson
- Michael Görner
- Paul Bovbel
- Peter Weissig
- Sachin Chitta
- Surya Ambrose
- Tom Moore
- Toni Oliver
- Vincent Rousseau
- Vladimir Ermakov
