We’re happy to announce 2 new packages and 31 updated packages for Kinetic Kame.
We’re approaching the EOL of Kinetic. We are planning for 2 more syncs. It’s recommended to make any updates in the next penultimate sync to avoid any regressions in the final sync.
Thank you to all the maintainers who have helped make all these packages available and keep them up to date.
Package Updates for kinetic
Added Packages [2]:
- ros-kinetic-heron-controller: 0.2.0-1
- ros-kinetic-mitre-fast-layered-map: 0.1.4-2
Updated Packages [31]:
- ros-kinetic-costmap-cspace: 0.10.6-1 → 0.10.10-1
- ros-kinetic-heron-gazebo: 0.3.2-1 → 0.3.3-1
- ros-kinetic-heron-simulator: 0.3.2-1 → 0.3.3-1
- ros-kinetic-joystick-interrupt: 0.10.6-1 → 0.10.10-1
- ros-kinetic-map-organizer: 0.10.6-1 → 0.10.10-1
- ros-kinetic-mcl-3dl: 0.5.3-1 → 0.5.4-1
- ros-kinetic-mocap-optitrack: 0.1.0-1 → 0.1.1-1
- ros-kinetic-moose-control: 0.1.0-1 → 0.1.1-1
- ros-kinetic-moose-description: 0.1.0-1 → 0.1.1-1
- ros-kinetic-moose-msgs: 0.1.0-1 → 0.1.1-1
- ros-kinetic-neonavigation: 0.10.6-1 → 0.10.10-1
- ros-kinetic-neonavigation-common: 0.10.6-1 → 0.10.10-1
- ros-kinetic-neonavigation-launch: 0.10.6-1 → 0.10.10-1
- ros-kinetic-obj-to-pointcloud: 0.10.6-1 → 0.10.10-1
- ros-kinetic-planner-cspace: 0.10.6-1 → 0.10.10-1
- ros-kinetic-safety-limiter: 0.10.6-1 → 0.10.10-1
- ros-kinetic-sick-scan: 1.7.8-1 → 1.10.1-1
- ros-kinetic-track-odometry: 0.10.6-1 → 0.10.10-1
- ros-kinetic-trajectory-tracker: 0.10.6-1 → 0.10.10-1
- ros-kinetic-urg-stamped: 0.0.7-1 → 0.0.9-1
- ros-kinetic-vision-visp: 0.11.1-1 → 0.12.0-1
- ros-kinetic-visp: 3.3.0-3 → 3.4.0-7
- ros-kinetic-visp-auto-tracker: 0.11.1-1 → 0.12.0-1
- ros-kinetic-visp-bridge: 0.11.1-1 → 0.12.0-1
- ros-kinetic-visp-camera-calibration: 0.11.1-1 → 0.12.0-1
- ros-kinetic-visp-hand2eye-calibration: 0.11.1-1 → 0.12.0-1
- ros-kinetic-visp-tracker: 0.11.1-1 → 0.12.0-1
- ros-kinetic-warthog-control: 0.1.2-1 → 0.1.3-1
- ros-kinetic-warthog-description: 0.1.2-1 → 0.1.3-1
- ros-kinetic-warthog-msgs: 0.1.2-1 → 0.1.3-1
- ros-kinetic-ypspur: 1.20.0-1 → 1.20.2-1
Removed Packages [0]:
- Atsushi Watanabe
- Fabien Spindler
- Michael Lehning
- Mike Purvis
- Tony Baltovski
- tbostic
