We’re happy to announce 10 new packages and 57 updated packages for Indigo with our first sync of the new year.
Thank you to everyone who has helped make these packages available including both maintainers and contributors. Full details are below.
Package Updates for indigo
Added Packages [10]:
- ros-indigo-flir-boson-usb: 1.0.0-0
- ros-indigo-indy5-description: 0.3.4-0
- ros-indigo-indy5-moveit-config: 0.3.4-0
- ros-indigo-indy7-description: 0.3.4-0
- ros-indigo-indy7-moveit-config: 0.3.4-0
- ros-indigo-indyrp-description: 0.3.4-0
- ros-indigo-indyrp-moveit-config: 0.3.4-0
- ros-indigo-indyrp2-description: 0.3.4-0
- ros-indigo-indyrp2-moveit-config: 0.3.4-0
- ros-indigo-pheeno-ros-description: 0.1.0-0
Updated Packages [57]:
- ros-indigo-behaviortree-cpp: 2.4.1-0 → 2.4.4-0
- ros-indigo-costmap-cspace-msgs: 0.2.0-0 → 0.3.0-0
- ros-indigo-dataspeed-can: 1.0.11-0 → 1.0.12-0
- ros-indigo-dataspeed-can-msg-filters: 1.0.11-0 → 1.0.12-0
- ros-indigo-dataspeed-can-tools: 1.0.11-0 → 1.0.12-0
- ros-indigo-dataspeed-can-usb: 1.0.11-0 → 1.0.12-0
- ros-indigo-default-cfg-fkie: 0.8.4-0 → 0.8.9-0
- ros-indigo-euslisp: 9.25.0-0 → 9.26.0-0
- ros-indigo-flexbe-behavior-engine: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-core: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-input: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-mirror: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-msgs: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-onboard: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-states: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-testing: 1.1.0-0 → 1.1.1-0
- ros-indigo-flexbe-widget: 1.1.0-0 → 1.1.1-0
- ros-indigo-map-organizer-msgs: 0.2.0-0 → 0.3.0-0
- ros-indigo-marti-data-structures: 2.7.0-0 → 2.7.2-0
- ros-indigo-master-discovery-fkie: 0.8.4-0 → 0.8.9-0
- ros-indigo-master-sync-fkie: 0.8.4-0 → 0.8.9-0
- ros-indigo-mcl-3dl: 0.1.3-0 → 0.1.4-0
- ros-indigo-multimaster-fkie: 0.8.4-0 → 0.8.9-0
- ros-indigo-multimaster-msgs-fkie: 0.8.4-0 → 0.8.9-0
- ros-indigo-neonavigation-msgs: 0.2.0-0 → 0.3.0-0
- ros-indigo-node-manager-fkie: 0.8.4-0 → 0.8.9-0
- ros-indigo-pacmod-game-control: 2.2.0-1 → 2.3.0-0
- ros-indigo-planner-cspace-msgs: 0.2.0-0 → 0.3.0-0
- ros-indigo-rc-genicam-api: 2.0.0-0 → 2.0.2-0
- ros-indigo-rotors-comm: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-control: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-description: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-evaluation: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-gazebo: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-gazebo-plugins: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-hil-interface: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-joy-interface: 2.1.1-0 → 2.2.3-0
- ros-indigo-rotors-simulator: 2.1.1-0 → 2.2.3-0
- ros-indigo-rqt-rotors: 2.1.1-0 → 2.2.3-0
- ros-indigo-swri-console-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-dbw-interface: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-geometry-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-image-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-math-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-nodelet: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-opencv-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-prefix-tools: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-roscpp: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-rospy: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-route-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-serial-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-string-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-system-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-transform-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-swri-yaml-util: 2.7.0-0 → 2.7.2-0
- ros-indigo-trajectory-tracker-msgs: 0.2.0-0 → 0.3.0-0
- ros-indigo-video-stream-opencv: 1.1.4-0 → 1.1.5-0
Removed Packages [0]:
- Alexander Tiderko
- Atsushi Watanabe
- Fadri Furrer
- Felix Ruess
- Kei Okada
- Kevin Hallenbeck
- Kris Kozak
- Marc Alban
- Michele Colledanchise
- Micho Radovnikovich
- P. J. Reed
- Pavel Vechersky
- Philipp Schillinger
- Sammy Pfeiffer
- Thach Do
- Zahi Kakish
- user
