We’re happy to announce 20 new packages and 149 updated packages for Indigo Igloo today.
Thank you to all the maintainers and contributors who have helped make these available. Full details are below.
Package Updates for indigo
Added Packages [20]:
- ros-indigo-costmap-cspace: 0.2.3-0
- ros-indigo-ibeo-lux: 2.0.0-0
- ros-indigo-joystick-interrupt: 0.2.3-0
- ros-indigo-map-organizer: 0.2.3-0
- ros-indigo-mir-actions: 1.0.1-0
- ros-indigo-mir-description: 1.0.1-0
- ros-indigo-mir-driver: 1.0.1-0
- ros-indigo-mir-gazebo: 1.0.1-0
- ros-indigo-mir-msgs: 1.0.1-0
- ros-indigo-mir-navigation: 1.0.1-0
- ros-indigo-neonavigation: 0.2.3-0
- ros-indigo-neonavigation-common: 0.2.3-0
- ros-indigo-neonavigation-launch: 0.2.3-0
- ros-indigo-obj-to-pointcloud: 0.2.3-0
- ros-indigo-planner-cspace: 0.2.3-0
- ros-indigo-ps4eye: 0.0.4-1
- ros-indigo-pybind11-catkin: 2.2.3-3
- ros-indigo-safety-limiter: 0.2.3-0
- ros-indigo-track-odometry: 0.2.3-0
- ros-indigo-trajectory-tracker: 0.2.3-0
Updated Packages [149]:
- ros-indigo-cob-3d-mapping-msgs: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-base-drive-chain: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-base-velocity-smoother: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-bms-driver: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-bringup: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-bringup-sim: 0.6.9-0 → 0.6.10-0
- ros-indigo-cob-calibration-data: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-cam3d-throttle: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-camera-sensors: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-canopen-motor: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-cartesian-controller: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-collision-velocity-filter: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-command-gui: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-command-tools: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-common: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-control: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-control-mode-adapter: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-control-msgs: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-dashboard: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-default-robot-behavior: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-default-robot-config: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-description: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-driver: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-elmo-homing: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-footprint-observer: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-frame-tracker: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-gazebo: 0.6.9-0 → 0.6.10-0
- ros-indigo-cob-gazebo-objects: 0.6.9-0 → 0.6.10-0
- ros-indigo-cob-gazebo-worlds: 0.6.9-0 → 0.6.10-0
- ros-indigo-cob-generic-can: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-hand: 0.6.3-0 → 0.6.5-0
- ros-indigo-cob-hand-bridge: 0.6.3-0 → 0.6.5-0
- ros-indigo-cob-hardware-config: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-helper-tools: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-image-flip: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-interactive-teleop: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-light: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-linear-nav: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-map-accessibility-analysis: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-mapping-slam: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-mimic: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-model-identifier: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-monitoring: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-moveit-config: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-msgs: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-navigation: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-navigation-config: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-navigation-global: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-navigation-local: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-navigation-slam: 0.6.6-0 → 0.6.7-0
- ros-indigo-cob-object-detection-msgs: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-object-detection-visualizer: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-obstacle-distance: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-omni-drive-controller: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-perception-common: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-perception-msgs: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-phidget-em-state: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-phidget-power-state: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-phidgets: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-relayboard: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-robots: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-scan-unifier: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-script-server: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-sick-lms1xx: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-sick-s300: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-simulation: 0.6.9-0 → 0.6.10-0
- ros-indigo-cob-sound: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-srvs: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-supported-robots: 0.6.8-0 → 0.6.9-0
- ros-indigo-cob-teleop: 0.6.7-0 → 0.6.9-0
- ros-indigo-cob-trajectory-controller: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-twist-controller: 0.6.16-0 → 0.6.17-0
- ros-indigo-cob-undercarriage-ctrl: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-utilities: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-vision-utils: 0.6.11-0 → 0.6.12-0
- ros-indigo-cob-voltage-control: 0.6.11-0 → 0.6.12-0
- ros-indigo-default-cfg-fkie: 0.7.8-0 → 0.8.0-0
- ros-indigo-dynamixel-sdk: 3.5.4-0 → 3.6.2-0
- ros-indigo-eus-assimp: 0.3.5-0 → 0.4.0-0
- ros-indigo-euscollada: 0.3.5-0 → 0.4.0-0
- ros-indigo-euslisp: 9.23.0-0 → 9.25.0-0
- ros-indigo-eusurdf: 0.3.5-0 → 0.4.0-0
- ros-indigo-fetch-auto-dock-msgs: 1.0.0-0 → 1.0.1-0
- ros-indigo-fetch-calibration: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-depth-layer: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-description: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-driver-msgs: 1.0.0-0 → 1.0.1-0
- ros-indigo-fetch-ikfast-plugin: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-maps: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-moveit-config: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-navigation: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-teleop: 0.7.13-0 → 0.7.14-0
- ros-indigo-fetch-tools: 0.1.4-0 → 0.1.5-0
- ros-indigo-generic-throttle: 0.6.7-0 → 0.6.9-0
- ros-indigo-geometry-experimental: 0.5.17-0 → 0.5.18-0
- ros-indigo-geometry2: 0.5.17-0 → 0.5.18-0
- ros-indigo-interactive-markers: 1.11.3-0 → 1.11.4-0
- ros-indigo-jsk-model-tools: 0.3.5-0 → 0.4.0-0
- ros-indigo-jsk-roseus: 1.6.3-0 → 1.7.1-0
- ros-indigo-jskeus: 1.1.0-0 → 1.2.0-2
- ros-indigo-kdl-parser: 1.11.14-0 → 1.11.15-0
- ros-indigo-kdl-parser-py: 1.11.14-0 → 1.11.15-0
- ros-indigo-master-discovery-fkie: 0.7.8-0 → 0.8.0-0
- ros-indigo-master-sync-fkie: 0.7.8-0 → 0.8.0-0
- ros-indigo-multimaster-fkie: 0.7.8-0 → 0.8.0-0
- ros-indigo-multimaster-msgs-fkie: 0.7.8-0 → 0.8.0-0
- ros-indigo-node-manager-fkie: 0.7.8-0 → 0.8.0-0
- ros-indigo-novatel-gps-driver: 3.4.0-0 → 3.5.0-0
- ros-indigo-novatel-gps-msgs: 3.4.0-0 → 3.5.0-0
- ros-indigo-openni2-camera: 0.3.0-0 → 0.4.0-0
- ros-indigo-openni2-launch: 0.3.0-0 → 0.4.0-0
- ros-indigo-pid: 0.0.24-0 → 0.0.27-0
- ros-indigo-plotjuggler: 1.6.2-0 → 1.7.1-1
- ros-indigo-power-msgs: 0.2.0-0 → 0.2.1-0
- ros-indigo-raw-description: 0.6.8-0 → 0.6.9-0
- ros-indigo-rc-genicam-api: 1.3.11-0 → 1.3.12-0
- ros-indigo-robot-controllers: 0.5.3-0 → 0.5.4-0
- ros-indigo-robot-controllers-interface: 0.5.3-0 → 0.5.4-0
- ros-indigo-robot-controllers-msgs: 0.5.3-0 → 0.5.4-0
- ros-indigo-roseus: 1.6.3-0 → 1.7.1-0
- ros-indigo-roseus-mongo: 1.6.3-0 → 1.7.1-0
- ros-indigo-roseus-smach: 1.6.3-0 → 1.7.1-0
- ros-indigo-roseus-tutorials: 1.6.3-0 → 1.7.1-0
- ros-indigo-schunk-description: 0.6.10-0 → 0.6.11-0
- ros-indigo-schunk-libm5api: 0.6.10-0 → 0.6.11-0
- ros-indigo-schunk-modular-robotics: 0.6.10-0 → 0.6.11-0
- ros-indigo-schunk-powercube-chain: 0.6.10-0 → 0.6.11-0
- ros-indigo-schunk-sdh: 0.6.10-0 → 0.6.11-0
- ros-indigo-schunk-simulated-tactile-sensors: 0.6.10-0 → 0.6.11-0
- ros-indigo-service-tools: 0.6.7-0 → 0.6.9-0
- ros-indigo-tf2: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-bullet: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-eigen: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-geometry-msgs: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-kdl: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-msgs: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-py: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-ros: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-sensor-msgs: 0.5.17-0 → 0.5.18-0
- ros-indigo-tf2-tools: 0.5.17-0 → 0.5.18-0
- ros-indigo-video-stream-opencv: 1.1.2-0 → 1.1.4-0
- ros-indigo-xpp: 1.0.6-0 → 1.0.9-0
- ros-indigo-xpp-examples: 1.0.6-0 → 1.0.9-0
- ros-indigo-xpp-hyq: 1.0.6-0 → 1.0.9-0
- ros-indigo-xpp-msgs: 1.0.6-0 → 1.0.9-0
- ros-indigo-xpp-quadrotor: 1.0.6-0 → 1.0.9-0
- ros-indigo-xpp-states: 1.0.6-0 → 1.0.9-0
- ros-indigo-xpp-vis: 1.0.6-0 → 1.0.9-0
- ros-indigo-xsens-driver: 2.1.0-0 → 2.2.0-3
Removed Packages [1]:
- ros-indigo-freight-calibration
- Alexander Bubeck
- Alexander Tiderko
- Alexander W. Winkler
- Andy Zelenak
- Atsushi Watanabe
- Benjamin Maidel
- Bruno Brito
- Chris Lalancette
- Davide Faconti
- Felipe Garcia Lopez
- Felix Messmer
- Felix Ruess
- Felix Zeltner
- Florian Weisshardt
- Francis Colas
- Isaac I. Y. Saito
- Jannik Abbenseth
- Joshua Hampp
- Kei Okada
- Koji Terada
- Martin Günther
- Matthias Gruhler
- Michael Ferguson
- P. J. Reed
- Pyo
- Richard Bormann
- Ron Tajima
- Russell Toris
- Sammy Pfeiffer
- Tully Foote
- Vincent Rabaud
- Vladimir Ivan
- William Woodall
- Yohei Kakiuchi
- Yuki Furuta
