The new release of ROS 2 Dashing is here! For details about changes to the core ROS 2 packages see the “Released” column of the project board on GitHub.
Package Updates for dashing
Note that package counts include dbgsym packages which have been filtered out from the list below
Added Packages [43]:
- ros-dashing-ament-cmake-virtualenv: 0.0.4-1
- ros-dashing-ament-virtualenv: 0.0.4-1
- ros-dashing-dynamic-edt-3d: 1.9.2-1
- ros-dashing-libphidget22: 2.0.1-1
- ros-dashing-novatel-gps-driver: 4.0.2-1
- ros-dashing-novatel-gps-msgs: 4.0.2-1
- ros-dashing-octomap: 1.9.2-1
- ros-dashing-octovis: 1.9.2-1
- ros-dashing-perception-pcl: 2.0.0-1
- ros-dashing-phidgets-accelerometer: 2.0.1-1
- ros-dashing-phidgets-analog-inputs: 2.0.1-1
- ros-dashing-phidgets-api: 2.0.1-1
- ros-dashing-phidgets-digital-inputs: 2.0.1-1
- ros-dashing-phidgets-digital-outputs: 2.0.1-1
- ros-dashing-phidgets-drivers: 2.0.1-1
- ros-dashing-phidgets-gyroscope: 2.0.1-1
- ros-dashing-phidgets-high-speed-encoder: 2.0.1-1
- ros-dashing-phidgets-ik: 2.0.1-1
- ros-dashing-phidgets-magnetometer: 2.0.1-1
- ros-dashing-phidgets-motors: 2.0.1-1
- ros-dashing-phidgets-msgs: 2.0.1-1
- ros-dashing-phidgets-spatial: 2.0.1-1
- ros-dashing-phidgets-temperature: 2.0.1-1
- ros-dashing-rqt-common-plugins: 1.0.0-1
- ros-dashing-rqt-tf-tree: 1.0.0-1
Updated Packages [127]:
- ros-dashing-ament-cmake: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-auto: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-core: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-export-definitions: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-export-dependencies: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-export-include-directories: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-export-interfaces: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-export-libraries: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-export-link-flags: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-gmock: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-gtest: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-include-directories: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-libraries: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-nose: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-pytest: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-python: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-target-dependencies: 0.7.3-1 → 0.7.4-1
- ros-dashing-ament-cmake-test: 0.7.3-1 → 0.7.4-1
- ros-dashing-connext-cmake-module: 0.7.2-1 → 0.7.3-1
- ros-dashing-cv-bridge: 2.1.2-1 → 2.1.3-1
- ros-dashing-cyclonedds-cmake-module: 0.4.1-1 → 0.4.2-1
- ros-dashing-depthimage-to-laserscan: 2.2.2-1 → 2.2.5-1
- ros-dashing-desktop: 0.7.2-1 → 0.7.3-1
- ros-dashing-image-geometry: 2.1.2-1 → 2.1.3-1
- ros-dashing-kinesis-video-msgs: 3.0.0-2 → 3.1.0-1
- ros-dashing-kinesis-video-streamer: 3.0.0-2 → 3.1.0-1
- ros-dashing-libcurl-vendor: 2.1.0-2 → 2.1.2-1
- ros-dashing-message-filters: 3.1.2-1 → 3.1.3-1
- ros-dashing-orocos-kdl: 3.2.0-1 → 3.2.1-1
- ros-dashing-python-cmake-module: 0.7.9-1 → 0.7.10-1
- ros-dashing-rcl: 0.7.7-1 → 0.7.8-1
- ros-dashing-rcl-action: 0.7.7-1 → 0.7.8-1
- ros-dashing-rcl-lifecycle: 0.7.7-1 → 0.7.8-1
- ros-dashing-rcl-yaml-param-parser: 0.7.7-1 → 0.7.8-1
- ros-dashing-rclcpp: 0.7.11-1 → 0.7.12-1
- ros-dashing-rclcpp-action: 0.7.11-1 → 0.7.12-1
- ros-dashing-rclcpp-components: 0.7.11-1 → 0.7.12-1
- ros-dashing-rclcpp-lifecycle: 0.7.11-1 → 0.7.12-1
- ros-dashing-rclpy: 0.7.8-1 → 0.7.10-1
- ros-dashing-rcutils: 0.7.3-1 → 0.7.5-1
- ros-dashing-resource-retriever: 2.1.0-2 → 2.1.2-1
- ros-dashing-rmw-connext-cpp: 0.7.3-1 → 0.7.4-1
- ros-dashing-rmw-connext-shared-cpp: 0.7.3-1 → 0.7.4-1
- ros-dashing-rmw-cyclonedds-cpp: 0.4.1-1 → 0.4.2-1
- ros-dashing-rmw-implementation: 0.7.1-2 → 0.7.2-1
- ros-dashing-robot-state-publisher: 2.2.4-1 → 2.2.5-1
- ros-dashing-ros-base: 0.7.2-1 → 0.7.3-1
- ros-dashing-ros-core: 0.7.2-1 → 0.7.3-1
- ros-dashing-ros1-bridge: 0.7.3-1 → 0.7.4-1
- ros-dashing-ros2action: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2cli: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2component: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2lifecycle: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2msg: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2multicast: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2node: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2param: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2pkg: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2run: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2service: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2srv: 0.7.7-1 → 0.7.9-1
- ros-dashing-ros2topic: 0.7.7-1 → 0.7.9-1
- ros-dashing-rosidl-adapter: 0.7.7-1 → 0.7.8-1
- ros-dashing-rosidl-cmake: 0.7.7-1 → 0.7.8-1
- ros-dashing-rosidl-generator-c: 0.7.7-1 → 0.7.8-1
- ros-dashing-rosidl-generator-cpp: 0.7.7-1 → 0.7.8-1
- ros-dashing-rosidl-generator-py: 0.7.9-1 → 0.7.10-1
- ros-dashing-rosidl-parser: 0.7.7-1 → 0.7.8-1
- ros-dashing-rosidl-runtime-py: 0.7.9-1 → 0.7.10-1
- ros-dashing-rosidl-typesupport-connext-c: 0.7.2-1 → 0.7.3-1
- ros-dashing-rosidl-typesupport-connext-cpp: 0.7.2-1 → 0.7.3-1
- ros-dashing-rosidl-typesupport-interface: 0.7.7-1 → 0.7.8-1
- ros-dashing-rosidl-typesupport-introspection-c: 0.7.7-1 → 0.7.8-1
- ros-dashing-rosidl-typesupport-introspection-cpp: 0.7.7-1 → 0.7.8-1
- ros-dashing-rviz-assimp-vendor: 6.1.4-1 → 6.1.5-1
- ros-dashing-rviz-common: 6.1.4-1 → 6.1.5-1
- ros-dashing-rviz-default-plugins: 6.1.4-1 → 6.1.5-1
- ros-dashing-rviz-ogre-vendor: 6.1.4-1 → 6.1.5-1
- ros-dashing-rviz-rendering: 6.1.4-1 → 6.1.5-1
- ros-dashing-rviz-rendering-tests: 6.1.4-1 → 6.1.5-1
- ros-dashing-rviz-visual-testing-framework: 6.1.4-1 → 6.1.5-1
- ros-dashing-rviz2: 6.1.4-1 → 6.1.5-1
- ros-dashing-tf2: 0.11.5-1 → 0.11.6-1
- ros-dashing-tf2-eigen: 0.11.5-1 → 0.11.6-1
- ros-dashing-tf2-geometry-msgs: 0.11.5-1 → 0.11.6-1
- ros-dashing-tf2-kdl: 0.11.5-1 → 0.11.6-1
- ros-dashing-tf2-msgs: 0.11.5-1 → 0.11.6-1
- ros-dashing-tf2-ros: 0.11.5-1 → 0.11.6-1
- ros-dashing-tf2-sensor-msgs: 0.11.5-1 → 0.11.6-1
- ros-dashing-vision-opencv: 2.1.2-1 → 2.1.3-1
Removed Packages [0]:
- AWS RoboMaker
- Aaron Blasdel
- Anup Pemmaiah
- Armin Hornung
- Chris Lalancette
- Christoph Sprunk
- Dirk Thomas
- Erik Boasson
- Ethan Gao
- Isaac I.Y. Saito
- Jacob Perron
- Karsten Knese
- Martin Günther
- Max Krichenbauer
- Michael Carroll
- Michel Hidalgo
- Mikael Arguedas
- P. J. Reed
- Paul Bovbel
- Scott K Logan
- Steven! Ragnarök
- Tully Foote
- Vincent Rabaud
- William Woodall
