The new release of ROS 2 Dashing Diademata is here.
This release brings a number of new packages as well as some updates to ROS 2 core packages.
The default opensplice configuration was changed from AllowMulticast=true to AllowMulticast=spdp . This means that Opensplice will now use multicast for discovery but unicast for data delivery, which brings it inline with how the other RTPS/DDS implementations operate. This should improve data delivery on wireless networks when using Opensplice, at the cost of increasing network bandwidth on wired networks when there are many subscribers to the same topic. This is a backport of ros2/rosidl_typesupport_opensplice#34. For full details see the tracking issue and project board.
Package Updates for dashing
Note that package counts include dbgsym packages which have been filtered out from the list below
Added Packages [67]:
- ros-dashing-ackermann-msgs: 2.0.2-1
- ros-dashing-aws-common: 2.1.0-1
- ros-dashing-aws-ros2-common: 1.0.0-1
- ros-dashing-cartographer-ros: 1.0.9000-1
- ros-dashing-cartographer-ros-msgs: 1.0.9000-1
- ros-dashing-cloudwatch-logger: 3.0.0-2
- ros-dashing-cloudwatch-logs-common: 1.1.0-1
- ros-dashing-cloudwatch-metrics-collector: 3.0.0-2
- ros-dashing-cloudwatch-metrics-common: 1.1.0-1
- ros-dashing-control-msgs: 2.2.0-1
- ros-dashing-cyclonedds: 0.1.0-1
- ros-dashing-cyclonedds-cmake-module: 0.4.0-1
- ros-dashing-dataflow-lite: 1.1.0-1
- ros-dashing-diagnostic-updater: 2.0.0-1
- ros-dashing-file-management: 1.1.0-1
- ros-dashing-h264-encoder-core: 2.0.1-1
- ros-dashing-h264-video-encoder: 2.0.0-1
- ros-dashing-health-metric-collector: 3.0.0-1
- ros-dashing-kinesis-manager: 2.0.1-1
- ros-dashing-kinesis-video-msgs: 3.0.0-2
- ros-dashing-kinesis-video-streamer: 3.0.0-2
- ros-dashing-lex-common: 1.0.0-1
- ros-dashing-lex-common-msgs: 3.0.0-1
- ros-dashing-lex-node: 3.0.0-1
- ros-dashing-people-msgs: 1.3.0-1
- ros-dashing-realtime-tools: 2.0.0-1
- ros-dashing-rmw-cyclonedds-cpp: 0.4.0-1
- ros-dashing-ros-monitoring-msgs: 2.0.0-1
- ros-dashing-self-test: 2.0.0-1
- ros-dashing-tts: 2.0.0-1
- ros-dashing-tts-interfaces: 2.0.0-1
- ros-dashing-turtlebot3: 2.0.1-1
- ros-dashing-turtlebot3-bringup: 2.0.1-1
- ros-dashing-turtlebot3-cartographer: 2.0.1-1
- ros-dashing-turtlebot3-description: 2.0.1-1
- ros-dashing-turtlebot3-gazebo: 2.0.1-1
- ros-dashing-turtlebot3-navigation2: 2.0.1-1
- ros-dashing-turtlebot3-node: 2.0.1-1
- ros-dashing-turtlebot3-simulations: 2.0.1-1
- ros-dashing-turtlebot3-teleop: 2.0.1-1
Updated Packages [166]:
- ros-dashing-ament-clang-format: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-clang-tidy: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-clang-format: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-clang-tidy: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-copyright: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-cppcheck: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-cpplint: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-flake8: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-lint-cmake: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-pclint: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-pep257: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-pep8: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-pyflakes: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-uncrustify: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cmake-xmllint: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-copyright: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cppcheck: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-cpplint: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-flake8: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-lint: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-lint-auto: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-lint-cmake: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-lint-common: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-pclint: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-pep257: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-pep8: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-pyflakes: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-uncrustify: 0.7.8-1 β 0.7.9-1
- ros-dashing-ament-xmllint: 0.7.8-1 β 0.7.9-1
- ros-dashing-dynamixel-sdk: 3.7.10-1 β 3.7.20-1
- ros-dashing-ecl-command-line: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-concepts: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-config: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-console: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-containers: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-converters: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-converters-lite: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-core: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-core-apps: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-devices: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-eigen: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-errors: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-exceptions: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-filesystem: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-formatters: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-geometry: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-io: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-ipc: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-linear-algebra: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-lite: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-manipulators: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-math: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-mobile-robot: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-mpl: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-sigslots: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-sigslots-lite: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-statistics: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-streams: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-threads: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-time: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-time-lite: 1.0.1-1 β 1.0.3-2
- ros-dashing-ecl-type-traits: 1.0.1-1 β 1.0.4-1
- ros-dashing-ecl-utilities: 1.0.1-1 β 1.0.4-1
- ros-dashing-launch: 0.8.5-3 β 0.8.6-1
- ros-dashing-launch-ros: 0.8.5-1 β 0.8.6-1
- ros-dashing-launch-testing: 0.8.5-3 β 0.8.6-1
- ros-dashing-launch-testing-ament-cmake: 0.8.5-3 β 0.8.6-1
- ros-dashing-launch-testing-ros: 0.8.5-1 β 0.8.6-1
- ros-dashing-opensplice-cmake-module: 0.7.2-1 β 0.7.3-1
- ros-dashing-py-trees-js: 0.4.0-1 β 0.5.0-1
- ros-dashing-py-trees-ros-viewer: 0.1.2-1 β 0.1.3-1
- ros-dashing-python-cmake-module: 0.7.7-1 β 0.7.8-1
- ros-dashing-rclcpp: 0.7.7-1 β 0.7.8-1
- ros-dashing-rclcpp-action: 0.7.7-1 β 0.7.8-1
- ros-dashing-rclcpp-components: 0.7.7-1 β 0.7.8-1
- ros-dashing-rclcpp-lifecycle: 0.7.7-1 β 0.7.8-1
- ros-dashing-rclpy: 0.7.5-1 β 0.7.7-1
- ros-dashing-robot-state-publisher: 2.2.3-1 β 2.2.4-1
- ros-dashing-ros2bag: 0.1.4-1 β 0.1.5-1
- ros-dashing-ros2launch: 0.8.5-1 β 0.8.6-1
- ros-dashing-rosbag2: 0.1.4-1 β 0.1.5-1
- ros-dashing-rosbag2-converter-default-plugins: 0.1.4-1 β 0.1.5-1
- ros-dashing-rosbag2-storage: 0.1.4-1 β 0.1.5-1
- ros-dashing-rosbag2-storage-default-plugins: 0.1.4-1 β 0.1.5-1
- ros-dashing-rosbag2-test-common: 0.1.4-1 β 0.1.5-1
- ros-dashing-rosbag2-tests: 0.1.4-1 β 0.1.5-1
- ros-dashing-rosbag2-transport: 0.1.4-1 β 0.1.5-1
- ros-dashing-rosidl-adapter: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-cmake: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-generator-c: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-generator-cpp: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-generator-py: 0.7.7-1 β 0.7.8-1
- ros-dashing-rosidl-parser: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-runtime-py: 0.7.7-1 β 0.7.8-1
- ros-dashing-rosidl-typesupport-interface: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-typesupport-introspection-c: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-typesupport-introspection-cpp: 0.7.5-1 β 0.7.6-1
- ros-dashing-rosidl-typesupport-opensplice-c: 0.7.2-1 β 0.7.3-1
- ros-dashing-rosidl-typesupport-opensplice-cpp: 0.7.2-1 β 0.7.3-1
- ros-dashing-rviz-assimp-vendor: 6.1.3-1 β 6.1.4-1
- ros-dashing-rviz-common: 6.1.3-1 β 6.1.4-1
- ros-dashing-rviz-default-plugins: 6.1.3-1 β 6.1.4-1
- ros-dashing-rviz-ogre-vendor: 6.1.3-1 β 6.1.4-1
- ros-dashing-rviz-rendering: 6.1.3-1 β 6.1.4-1
- ros-dashing-rviz-rendering-tests: 6.1.3-1 β 6.1.4-1
- ros-dashing-rviz-visual-testing-framework: 6.1.3-1 β 6.1.4-1
- ros-dashing-rviz2: 6.1.3-1 β 6.1.4-1
- ros-dashing-shared-queues-vendor: 0.1.4-1 β 0.1.5-1
- ros-dashing-sqlite3-vendor: 0.1.4-1 β 0.1.5-1
- ros-dashing-tf2: 0.11.4-1 β 0.11.5-1
- ros-dashing-tf2-eigen: 0.11.4-1 β 0.11.5-1
- ros-dashing-tf2-geometry-msgs: 0.11.4-1 β 0.11.5-1
- ros-dashing-tf2-kdl: 0.11.4-1 β 0.11.5-1
- ros-dashing-tf2-msgs: 0.11.4-1 β 0.11.5-1
- ros-dashing-tf2-ros: 0.11.4-1 β 0.11.5-1
- ros-dashing-tf2-sensor-msgs: 0.11.4-1 β 0.11.5-1
Removed Packages [0]:
- AWS B9 Team
- AWS RoboMaker
- Austin Hendrix
- Bence Magyar
- Brice Rebsamen
- Chris Lalancette
- Dan Lazewatsky
- Daniel Stonier
- Dirk Thomas
- Erik Boasson
- Jack OβQuin
- Jacob Perron
- John Shepherd
- Juan Pablo Samper
- Karsten Knese
- Michael Carroll
- Pete Baughman
- Pyo
- Scott K Logan
- Steven! Ragnarok
- Tully Foote
- Vincent Rabaud
- William Woodall
