Navigation Working Group Meeting Minutes - Oct 12
Attendees:
- Steve Macenski
- Ben Perseghetti
- Mohammed Ibrahim
- Ryan Friedman
- Alejandro Cordero
- Marques Rasmussen
New additions of note:
- GPS tutorial (Kiwibot)
- VIO tutorial with Stereolabs (Open Navigation)
- MPPI binaries are fixed, waiting on sync for update. AVX512 Xeon issue in build farm (Open Navigation)
- New syncs 1.2.5 and 1.1.12 on way to you shortly! (Open Navigation)
- Significant MPPI run-time and behavioral upgrades – goal critic 25% lighter, PathAlign aligns better + 80% faster, smaller upgrades across the controller to continue after ROSCon. Minus Obstacle critic, can now run 100hz on 7th gen U CPU (Open Navigation)
- Removed support for single goal checker in Rolling and newer, reintroduces controller server’s RQT Reconfigure application that doesn’t handle it well (Open Navigation)
- Collision Monitor supports dynamic polygons and sources disable / enable callbacks (Pixel Robotics)
- Allowing Nav2 to compile on MacOS complete (Ardupilot)
- Publishing additional lifecycle diagnostics for analysis (@Plaqueoff)
- Removed all crashing exit conditions in plugin loaders (Open Navigation)
- Wait action now takes floating point instead of int number of seconds (@maksymdidukh)
Ongoing:
- MPPI optimizations for run-time performance and not shortcutting paths
- Debugging thread safety issues caused by rclcpp + Fast-DDS (?) bugs
- TF2 change to enable new node to dynamically publish base_footprint frame adding base footprint publisher to nav2_util by SteveMacenski · Pull Request #3860 · ros-navigation/navigation2 · GitHub
New bugs of note:
- MPPI binaries are broken fix coming in 1.2.5 and 1.1.12 for Humble/Iron
Anything else?
- Alejandro & Ben & Ryan – Gazebo vs Ignition migration status and check (@ahcorde)
- New gazebo performs worse than gazebo classic (80% vs 100% CPU)
- Something seems very wrong; costmaps not showing up and state estimation is running away
- Can we skip Ignition and just go to Gazebo2? Can do in all bridge, etc. The world file is only thing that needs to be updated later.
- https://github.com/ros-planning/navigation2/pull/3634
