Libgazebo_ros_camera Problem
sitl_gazebo has problem with run libgazebo_ros_camera, I followed the (ros_interface) for install and run gazebo simulation. Everything works fine, but after adding the camera, the following error occurs:
roslaunch px4 mavros_posix_sitl.launch
gzserver: /build/ogre-1.9-mqY1wq/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreRenderSystem.cpp:546: virtual void Ogre::RenderSystem::setDepthBufferFor(Ogre::RenderTarget*): AssertionbAttached && "A new DepthBuffer for a RenderTarget was created, but after creation" "it says it's incompatible with that RT"' failed.
Aborted
[gazebo-3] process has died [pid 20750, exit code 134, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /home/cv/src/Firmware/Tools/sitl_gazebo/worlds/empty.world __name:=gazebo __log:=/home/cv/.ros/log/68ef15b6-1e60-11e8-b0c8-000c29ddf392/gazebo-3.log].
log file: /home/cv/.ros/log/68ef15b6-1e60-11e8-b0c8-000c29ddf392/gazebo-3*.log
this code added to iris.sdf:
<joint name='DownCam_joint' type='fixed'> <child>camera_link</child> <parent>base_link</parent> </joint> <link name='camera_link'> <pose frame=''>0.1 0 0.194923 0 0 0</pose> <inertial> <pose frame=''>0 0 0 0 0 0</pose> <mass>1e-05</mass> <inertia> <ixx>0.0001</ixx> <ixy>0</ixy> <ixz>0</ixz> <iyy>0.0002</iyy> <iyz>0</iyz> <izz>0.0002</izz> </inertia> </inertial> <visual name='visual'> <geometry> <box> <size>0.005 0.005 0.005</size> </box> </geometry> </visual> <sensor name='FrontCam' type='camera'> <update_rate>30</update_rate> <camera name='head'> <horizontal_fov>1.39626</horizontal_fov> <image> <width>720</width> <height>480</height> <format>R8G8B8</format> </image> <clip> <near>0.02</near> <far>300</far> </clip> <noise> <type>gaussian</type> <mean>0</mean> <stddev>0.007</stddev> </noise> </camera> <plugin name='camera_controller' filename='libgazebo_ros_camera.so'> <alwaysOn>true</alwaysOn> <updateRate>0.0</updateRate> <cameraName>birrobotic/FrontCam</cameraName> <imageTopicName>image_raw</imageTopicName> <cameraInfoTopicName>camera_info</cameraInfoTopicName> <frameName>camera_link</frameName> <hackBaseline>0.07</hackBaseline> <distortionK1>0.0</distortionK1> <distortionK2>0.0</distortionK2> <distortionK3>0.0</distortionK3> <distortionT1>0.0</distortionT1> <distortionT2>0.0</distortionT2> </plugin> </sensor> <self_collide>0</self_collide> <enable_wind>0</enable_wind> <kinematic>0</kinematic> </link>
How to install libgazebo_ros_camera for sitl_gazebo to publish camera images?
I used this GitHub branch GitHub - PX4/PX4-SITL_gazebo-classic: Set of plugins, models and worlds to use with OSRF Gazebo Simulator in SITL and HITL.
This kind of technical question is more suitable for http://answers.gazebosim.org/
