I had an interesting discussion with @peci1 over on the exiv2 github and we decided to move it here for some more opinions/recommendations because it illustrates a larger issue with the standard ROS 2 build tooling when a company wants to build a larger software stack with colcon and rosdep.
First, some background
- I work at a company that uses ROS 2 with C++
- We use colcon to build the software we maintain
- We use package.xml files for colcon to know build dependencies
- We have a few forks of ROS repos (rosidl, for example) with changes that are not merged upstream
- We also rely a lot on system packages from outside ROS
- These system packages have known bugs or missing ABI compatible features on Ubuntu 22’s apt version, so we want to use newer versions. exiv2 is one such example, but there about 15 packages in such a state. I usually upstream our patches, but in some cases the repos are also unmaintained, so we carry these patches internally
- We do NOT worry about breaking compatibility with what the ROS distribution or Ubuntu distribution because we have a product to deliver and no time to worry about ABI outside our closed source applications
- We don’t care about internal ABI, we don’t use SemVer on internal package, and our internal messages aren’t stable either. We use VCS to freeze the state of our source code with
vcs export --exactwhen we do a release.
Constraints
- We want to avoid duplicating building the same library multiple times with tools like FetchContent because our CI build times get too slow
- We don’t have a large enough team or funding to switch to conan, switch to bazel, switch to yocto, and so far, we haven’t set up the ROS build farm interally that’s also intimidating amount of work.
- We want to do our best to only use one version of a library in the project (IE, don’t link against 4 different versions of exiv2 in four different packages). Due to the size of our project, this is a reasonable restriction
- Maintainers of non-ROS packages like exiv2 are not interested in a package.xml in their repo
- The ubuntu package maintainers appear to be understaffed and underfunded so long-standing bugs still exist that affect us, largely in their CMake code that show up when you cross compile. Many packages in Ubuntu distros are built with autotools even though the packages support CMake for years. I’m not ready to sign up as an Ubuntu package maintainer , so this problem is probably not going away any time soon
How we currently solve the problem:
- For packages like exiv2, we have a repo that contains shell scripts called “build_exiv2.sh” and “install_exiv2.sh”.
Originally, these were CMake builds and Cmake installs, but we recently started uploading debians and installing debians - In docker for our dev and deploy images, we use a
RUN install_exiv2.shwhich takes advantage of the docker build cache. This happens AFTER rosdep. - We skip rosdep keys on packages like
exiv2because we want to avoid installing the same library twice - this has bitten us multiple times. If you try compiling some of our ROS package outside of our development environment that installed exiv2, it will fail to compile. You can get around this by runninginstall_exiv2.sh. - We use ccache to speed up builds. We don’t really care how large our source workspace gets because we can pin dependencies and ccache makes it really fast for already built packages.
- We use vcs to keep track of all ROS-package dependencies
- For meta-repos, we use
yqto do a merge of thevcsfiles, this ensures we only build one version of a repo (This has some problems if two packages pin different versions, so we manually keep these in sync) - We cross compile all our source code with a sysroot, and carry many internal patches for libraries that do not cross compile well, as well as workarounds in our cross compile toolchain that rewrite absolute paths to relative paths when we don’t have time to fix upstream CMake code
- The upstream fixes can be quite involved. Here’s a recent example I did for LibKML
What we would like:
- All packages we build from source for to be in the ROS workspace
- Rosdep doesn’t need a list of keys to skip that we propograte through all our repos
- Reduce the number of custom lines of code maintaining custom packaging
- Spend as little time on devops as possible long term
- Not make extra work every time we want to break internal ABI
masterbranch of everything we build to work with a cross compile toolchain, and the eventual upgrade to Ubuntu 24/26/28 to have debians that work in sysroot out of the box.
A simple use case illustrating the difficulty:
- Create a ROS workspace with a
srcdirectory - Clone exiv2 in the workspace
git clone https://github.com/Exiv2/exiv2.git - Create another package that depends on it:
ros2 pkg create exiv2_consumer --build-type ament_cmake --dependencies exiv2 - Run rosdep as normal
rosdep install --from-paths src --ignore-src - Oh crap, it wants to install Ubuntu’s old broken version:
executing command [sudo -H apt-get install exiv2]even though exiv2 is in my workspace - Ok, add a
--skip-keys exiv2everywhere we call rosdep.rosdep install --from-paths src --ignore-src --skip-keys exiv2 - Dependencies are installed, time to build!
colcon build
CMake Error at cmake/Findinih.cmake:28 (message):
inih library not found
Call Stack (most recent call first):
cmake/findDependencies.cmake:84 (find_package)
CMakeLists.txt:84 (include)
Sigh… (proceeds to submit a PR to our pre-colcon build repo with yet another shell script that needs installs apt dependencies and exiv2 in all dockerfiles that consume exiv2_consumer)
Other approaches I’ve seen (docker-based)
# Dockerfile in project/repo1
RUN apt-get update && apt-get install
< giant list of packages that are outside rosdep
# Dockerfile in project/repo2
< A slightly different giant list of packages that are outside rosdep
Or, a slighty better version (ignore the actual syntax, you get the point)
RUN apt-get update && cat local-apt-pkgs-list.txt | xargs apt-get install
cat local-apt-pkgs-list.txt | xargs apt-get install &&
cat project/repo1/local-apt-pkgs-list.txt
# And it spirals out of control with >10 repos
Or this way of treating docker as our dependency manager which you have periodic build system failures for a rolling hash or tagging nightmares every time you want to break ABI
FROM ros:rolling as base
COPY --from project/repo1/base /usr /usr
COPY --from project/repo2/base /usr /usr
Questions:
- How are you solving this workflow issue? (If it’s conan, or a smattering of pre-colcon shell scripts, please share)
- Are there any quick wins I could contribute to colcon and/or rosdep to make this workflow easier
- Is there any chance there could be a way to supply a 3rd party package.xml for a non-ROS package so that dependencies can be managed through rosdep without requiring maintainers to accept ROS tooling into their repos?
