Hello all,
Gazebo 9.0.0 has been released. All the important details can be found at http://gazebosim.org/blog/gazebo9
Thanks to everyone for your contributions and support.
Best,
nate
Hello all,
Best,
nate
Just to piggyback on this announcement: Docker images for version 9 have also been released on the Official Docker Hub Library for gazebo: https://hub.docker.com/_/gazebo
docker pull gazebo:libgazebo9
Note the additional tags, such as libgazebo9-xenial, that specify the code names with respect to the Ubuntu base images used. This should provide docker users a suitable migration path while we continue to maintain long term support and updating the general set of tags to track the latest supported LTS base images. So if your application is also sensitive to ubuntu release in addition to gazebo version, consider using the full code named tags for your projects.
Hi Nate,
Is there a Gazebo 9 compatible ROS repository available by chance? That is ros-lunar-gazebo9-dev and so on? If not yet - please, can someone give a pointer onto build instructions?
Thanks, Dmitry
Hi Dmitry,
ROS lunar Gazebo9 is on our todo list. It should be done sometime before the end of this week.
As a workaround, you can:
Quick update: packages for Debian Stretch are now in the debian-stable repository of packages.osrfoundation.org. Testing install job: https://build.osrfoundation.org/job/gazebo-install-gazebo9_pkg-strech-amd64/5/
This should complete the family of gazebo9 packages:
