I am trying to build a package on the machine after I generated the image. I wanted to have it build with bitbake but had issues with external dependencies not building properly with BitBake so they have to be installed on the machine.
catkin_make fails with error:
-- Using CATKIN_DEVEL_PREFIX: /home/root/lidar_workspace/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/indigo
-- This workspace overlays: /opt/ros/indigo
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using default Python package layout
-- Could NOT find PY_em (missing: PY_EM)
CMake Error at /opt/ros/indigo/share/catkin/cmake/empy.cmake:29 (message):
Unable to find either executable 'empy' or Python module 'em'... try
installing the package 'python-empy'
Call Stack (most recent call first):
/opt/ros/indigo/share/catkin/cmake/all.cmake:145 (include)
/opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:20 (include)
CMakeLists.txt:52 (find_package)
Iām sure Iām missing something important related to installing python-empy but from what I can see with the recipes it should be installed with the packagegroup-ros-comm.
Building further ROS packages on the target has not been implemented in meta-ros yet. These two issues point out the problems that some users had that tried it in the past:
Since then, no one has actually tried to do this, but we have been working on proper SDK support (nativesdk support in the bitbake tool chain), and the patches of this pull request below might help for your use case as well:
I actually just published my development branch of that pull request that I adjusted and rebased to the current master:
I did some minimal testing of that branch so far, but I donāt know if it resolves your use case.
Let us know if these patches already resolve the issue for you, or which further problem you encounter. I actually donāt know if building ROS packages on the target is easy to get working or involves a lot of patching of the catkin build tool.
Thank you for your replies. I will read into your suggestions further and let you know how it goes. I am currently working on a workaround to allow me to build the package using bitbake instead of on target. If it does not go well I will be swinging back to this method.
If this package youāre compiling has been released, thereās a good chance you can use superflore to generate the recipe. Iāve been working on automating the Open Embedded releases so they can parallel the Gentoo releases.
While things are not quite there, they are close. Iām not an expert, so any ideas as to what is blocking me would be great. You can find my current status on the issues for my fork of meta-ros.
I have since left that employer so I donāt have access to the old codebase.
If memory serves, I had only hacky solutions, but I had to build a couple of those packages on my build machine separate and then wrote bitbake scripts to copy the files into the sysroots so that I could run catkin_make from bitbake instead of on the device after initial image creation.
Overall, I would not recommend the solution since it was very prone to failure, but I needed it for a demonstration and not a long term solution so it seemed to suffice.
